Can Not Boot Into Safe Mode
My Windows Vista Home premium will bring me to the safe mode menu whenbooting up after pressing F8, but will not go into safe mode screen. It looks like drivers are being loaded but it reboots like it isrestarting and goes into normal Windows mode. Does anyone know a fix for this?
  • Anonymous Mar 16, 2014
    Hi my internet seams to go very slow on normal mode i cant use it at all everything is slow and not loading ive currently been havn to stay in safe mode which is annoying as there is no sound would you know why it is doing this Thanks lasharn
  • 716 Answers
You can usually get into safe mode by powering on the unit to desktop then holding the power off till the unit powers off then on startup it should give you an option for safe mode.
Posted on Jan 13, 2009
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Microsoft Windows Vista and Windows 7 users
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
Computer wont start
You may try this; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the NB.
If same problem persist, boot from safe mode. Here's how;
  • Turn the computer on or Restart the computer
  • Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected, not Repair Your Computer
  • Press Enter. The computer then begins to start in Safe mode.
  • When you are finished with troubleshooting, close all programs and restart the computer as you normally would
If same problem persist, try reloading the Vista again.
Hope this works.
Mar 15, 2011 | Microsoft Windows Vista Home Premium...
How do you put windows into safe mode?
Power on or Restart your computer, keep tapping F8 on the keyboard while it boots up. After few seconds, you'll be taken to the "Advanced Boot Options" with "Safe Mode" in the lists. Use the Up-Down arrow keys to highlight the "Safe Mode" and press enter on the keyboard to confirm the selected boot options. Black Screen with white texts will be displayed on the display, wait for few seconds until you see the windows logon Screen. You'll also see a confirmation message box asking you to confirm to boot into Safe Mode, click "yes" or "Ok" and proceed forward. There now you are in the Safe Mode.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 26, 2010 | Computers & Internet
I have lost my admin password, how can I get access to the computer. Windows vista.
You should be able to re-boot in safe mode and log in as the built-in administrator. This account generally doesn't have a password and is only available in safe mode.
From there, you can get to User Accounts and change passwords.
When your restart your computer, press F8 right before you see the Windows splash screen. This will bring up the Advanced Boot Options menu, from which you can select Safe Mode.
or
click on de link given below
http://www.petri.co.il/forgot_administrator_password.htm
Feb 23, 2010 | Microsoft Windows? Vista Home Basic...
Uncompatible software creates problem in WindowVista Home Premium
Before you format your drive try to boot to safe mode and see if you can try to uninstal the uncompatiable software.
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Jan 16, 2009 | Microsoft Windows Vista Home Premium with...
Windows recovery problems
If you still have the recovery discs available then press F11 or F12 depending on which one is the boot menu and boot from the CD and reinstall Vista from it onth the hard drive.
Apr 18, 2008 | Acer Aspire 5520-5908 Notebook
Loggin on
1.       Boot the computer in Safe mode( To Boot in safe mode you need to keep hitting the f8 keys while the computer Restart and you will prompt a screen which reads as Advanced boot Menu . in the windows please select safe mode with network ). An then try to login . and open misconfig and disable all the thrid party services and Restart the computer .
If you still have the problem  boot the computer using vista Dvd . And select the option to startup repair option . That will fix the problem
Oct 11, 2007 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
249 people viewed this question
David Payne
David Payne
