Question about RCA TruFlat 27F520T 27" TV
My digital tuner does not work
If you hook up the coaxial cable to the tv it does not work.
  • Anonymous Jan 16, 2009
    Yeah I tried that and it didn't pick up any channels. Thanks for the help. Any other suggestions?
    Scholar:
  • 48 Answers
Are you sure your cable coax source is broadcasting any unencrypted digital channels, and is the signal strenth relatively good? In the Channel Scan, you need to also specify the source/input type as digital, and be sure to use the coax connector marked DIGITAL Cable (or similar). Begin the autoscan--it will take a while as the TV tries to tune any/all digital signals--most of which, if you're cable provider is like 90% out there (interested in profits), this might take 15-20 minutes, and will likely end up in lotsa black non-broadcasting detections (placeholders for on demand content), but hopefully, you'll find a 1/2 dozen or so 'clear' unencrypted. If you know the channel of a KNOWN digital local, tune to it, even if the picture is not initially visible. The lock-on takes a few seconds and if a signal is weak, it may take a long while if it can lock on at all. Usually, you'll find your local PBS stations on unencrypted channels from your cable provider, along with major network tv stations (NBC,ABC,FOX,CBS), but it all depends on what the cable provider allows. Don't expect them to tell you what exactly is free either! Underground webs will list your provider, Google to find out what to expect, and don't expect what you find to be all accurate. If you're in a decent reception area, and have any sort of an antenna, you'd likely pick up some of the OTA HD broadcasts, maybe even with just a coathanger :), just to verify that your QAM/OTA tuner is functioning.
Posted on Mar 14, 2009
    Scholar:
    New Friend:
  • 70 Answers
Have you tried entering the "tuning mode" and scan for possible channels?
if not , check for screen "menu" go to "tuning mode" and select auto scan
Posted on Jan 16, 2009
How do i select the channel menu
Many times the re-scan tune option goes away if you've selected an input on the TV other than the "tuner", "Antenna" or similar (ie: AV1, HDMI1, Sat, Cable, etc.do not make use of your TV's internal tuner).
Make sure you select an input on your TV, ( tuner, etc.) that will use the tuner and have an antenna or non-digital Cable TV coaxial cable connected. Then attempt to scan again.
Dec 15, 2014 | Televison & Video
No signal cable TV
if you hooked up the coaxial in the RF tuner then you can not get signal, the cause will be the tuner has problem.
Aug 15, 2012 | Panasonic Viera TC-L37U22 37" 1080p...
What can a tv tuner do, dose it work on a blank
A tv tuner card is a device usually inserted into a computer screen or tower. this device has a "Coaxial Cable" jack in the back so that "Cable" can be hooked into the monitor. Along with this most come with an input selector. this enables you to switch between tv and computer with the push of a button.
My Sources ( I simply Google'd "What does a tv tuner card do") (lol just so i dont answer incorrectly and look like a fool lol.
OK GL!
and btw i have one and love it! it came in my monitor and i didnt think of it much till my TV went out on me. after hooking up the coaxial i havent gone without for a while :)
PS ive got built in speakers in my monitor. when i turn cable on it comes through them. the nice thing is my USB headset stays sending sound from my PC (so if im running a scan ill heard the BEEP at the end and know its done :)
GL
any further clarification required just comment and ill check back
***A TV Tuner Card NEEDS cable to be input into it. You cannot connect to the net or run it off your pc :S
Apr 09, 2009 | Dell Televison & Video
Hot to hook up cable
This monitor with a television tuner does not have a coaxial connection. I was able to get cable by connecting (buying if you don't have) to my dvd/vcr which had the coaxial connectors. Then I ran the video component cable (green, blue & red - had to buy that) from the tv to the dvd/vcr. Then I ran the audio cable (red & white) from the tv to the dvd/vcr. A little tricky figuring out where on the tv to actually connect but eventually got it. YUV2 on the side.
Dec 24, 2008 | TruTech PLV16320 Television
Hook up
Purchased a rf modulator and hooked in to the tuner out to modulator and from modulator to tv that made everything work
Apr 12, 2008 | Philips Magnavox DVD/VCR Dual Player
TV channels
If cable is hooked through cable box with a coaxial cable, then turn tv to ch 3 or ch 4 as appropriate.
If cable is hooked through any other type of cord (red/green/blue or red/white/yellow) use the AV+ or Source button to change your source to Av1, AV2, HDMI, or however you have the cable box hooked to TV (I am assuming your TV is a Philips).
Feb 24, 2008 | Philips TV Tuner Video Capture PCI Card -...
How to hook up to cable television
you will need a component or hdmi cable/satellite tuner for this tv.
Nov 17, 2007 | Akai PDP4225M 42 in. Plasma Television
Teac USB2 TV TUNER Video Capture
Hi Betty, First of all, this tuner requires that your laptop support USB 2.0, if your laptop is fairly new (made within the last 2 years) you should have no problem. Make sure you install the software first, and then plug in the USB cable from the tuner to your laptop. Your laptop should see it, and install it automatically. Then plug the s-video cable from your VCR to your TV tuner. Also connect the audio cables (white and red cables) from the VCR to the tuner. That's it. Please let us know how this works for you, and if you need any additional troubleshooting. Best regards, nightdiver
Jul 21, 2006 | Teac USB2 TV TUNER (USB2TVTUNER) Video...
RCA TruFlat  27F520T 27" TV Logo
306 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
