Question about Vtech V.Smile TV Learning System
V-smile not working once cartridge is placed in slot
When we turn the v-smile on it does show the v-smile logo,when we place the cartridge it stops working(we just get a empty screen)
  • 6 Answers
Here's the solution to your V smile: Oxidized connectors! Remeber the original Nintendo back in the 80s? You had to repeatedly reinsert the cartridge so that it would work properly. The V smile has the same problem. They use tin plated copper contacts on the game cartridges as well as the internal connector. All newer electronics use gold plated contacts because gold does not oxidize (rust, corrode). You'll need a very fine sheet of sandpaper. Start by lightly sanding the game cartridge connector (you have to expose the contacts by pushing the plastic part in). Make sure you wipe the contacts clean with a rag, and do not touch the contacts with your fingers! Then you have to do the same with the console's internal connector. The danger here is bending one of the pins inside so be very careful. The real solution to this would be to replace the connector but no one sells it (checked ebay, Vtech). Should last a couple of months to a few years, depending on relative humidity and use. If your V smile turns on normally without a game cartridge, then this is your problem. Symptoms vary from no power to corrupted graphics to no sound as well as random turn off (with a cartridge, no problems without a cartridge). I've done a few lately and all are working like new. Let me know how it goes, but I take no responsability for bent pins, damaged connectors, fire, earthquake,...
Posted on Sep 14, 2009
  • Bethany Ford
    Bethany Ford Nov 21, 2014
    I LOVE YOU!!! this works amazingly!
  • 3 Answers
I followed the solution posed by pizzachaude, however instead of using sandpaper, I just rubbed both sides of the cartridge contacts with a plastic rubber (the white type that is used in schools). Worked brilliantly, and no worries about damaging the contacts or the console pins.
Posted on Dec 23, 2009
Cheers worked a treat I use a nail file that had a fine grit. Too easy love your work I was going to throw the unit away. Recycled for the kids to have more fun with AAAA+++++ I love google...
Posted on Sep 18, 2011
It might be the batteries. Had a similar problem with a different product. I was using rechargeables without issue. Then our product did the same.... Vtech recommeds not using rechargeables... so I put in standard batteries and voila.
Posted on Nov 30, 2011
When trying to print the screen shows Error 5110. The manual shows 5100 as an object stopping the Print Head from moving. I can find nothing that is stopping the print head from moving which can be done...
was it was turned off while the lid was open and an ink cartridge was out
If you accidentally turned it of while the lid was open and the ink cartridge was out of place, you can try to push the cartridge gently back to shift it to it's place.
Aug 23, 2011 | Canon PIXMA MX310 All-In-One Printer
My Brother MFC-685CW Printer Wireless doesn't recognise a new colour cartridge despite having cleaned the printer head. It also is not recognised by the PC despite reloading it. Help!! Troubleshooter...
If the message "NO CARTRIDGE" remains on the LCD after you have installed the ink cartridge(s), it is possible another ink cartridge is empty and needs to be replaced or one or more of the cartridges are not installed properly. Complete the following steps:
  1. Unplug the machine from the AC power outlet, wait approximately 10 seconds and then plug it back in.
    1a. If the display continues to show NO CARTRIDGE, verify the cartridges are installed properly by uninstalling and reinstalling all four ink cartridges. Follow Steps 2a through 2f.
    1b. If "INK EMPTY XXXXX" (Xs = color, i.e. INK EMPTY CYAN) is displayed on the LCD, the specified ink cartridge is empty and needs to be replaced. Follow Steps 2a through 2f.
  2. To resolve an INK EMPTY message or to confirm the ink cartridges are installed properly, complete the following steps:
    2a. Open the ink cartridge cover. Pull the lock release lever(s) down and take out the ink cartridge(s). While you have the ink cartridge(s) out of the machine, verify the cartridge(s) are genuine Brother supplies with the Brother logo embossed into the side of cartridge.
    2b. Reinstall the ink cartridge(s). Lift and push the lock release lever(s) until it clicks into place and close the ink cartridge cover.
    2c. The LCD may then display:
    Did you change xxxxxx? Yes No.
    for the color(s) that was replaced. If this message appears, BE SURE to follow the instructions on the LCD to correctly select Yes or No. Select Yes if you installed a new cartridge(s) to automatically reset the ink dot counter for that color. Select No if you did not install a NEW ink cartridge(s).
    2d. After all the correct selections are made, the machine will then enter a cleaning cycle.
    2e.If the display again shows INK EMPTY XXXX, go back to Step 2 and follow the instructions to install a NEW ink cartridge.
    2f.If the machine did not enter a cleaning cycle and the display continues to show NO CARTRIDGE after reinstalling new genuine Brother ink cartridges, your machine may require service.
If your computer is not recognizing the printer you should uninstall and reload the drivers. You might consider downloading a new driver for your operating system from this site:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_list.html?reg=us&c=us&lang=en&prod=mfc685cw_us_as&Cat=112
I recommend bookmarking thihs site for future reference.
I hope this is helpful. :)
Dec 08, 2010 | Brother Office Equipment & Supplies
The red light on left is blinking. What does that indicate? I have a deskjet 904C. There are three light The left one is blinking, the middle is okay and the right is the green one, that shows me the...
Hi:
If you open the door on the top of the printer, while it is powered on, the ink cartridges will move to a spot that shows you the status of your ink.. There are little cartoon pictures of the cartridges with smiles or frowns to tell you if you have an empty color or black cartridge.
Nov 04, 2009 | HP DeskJet 940c InkJet Printer
Various Smartridges stopped working
You may need to inspect the inside of the cartridge slot for dust/dirt - swab it with a tiny amount of cleaning alcohol and see if you get better results.
Jan 03, 2009 | Vtech V.Smile TV Learning System
Epson stylus photo 1290 'bk ink cartridge not installed properly'
Ameter:
Remove the black ink cartridge.
Check the place where the new cartridge should go. Check for a round small piece like a bushing or a little piece of pipe, stuck at the ink entrance of the printing head. This is a piece from the old cartridge, that sometimes gets loose and remains in place,and when the new one is placed, it doesnot go down to the right place to make contact with the electric connectors in the printing head.
If nothing solves...reinstall the printer drivers.
Good luck and Merry Christmas
Emiliosan
Dec 09, 2008 | Epson Stylus Photo 1290 InkJet Printer
Archos 704 wifi not starting up
If you enter recovery mode then connect to a computer, you can then use windows drive checker to verify the drive. If all is OK, copy firmware to the root then disconnect and reboot
Apr 09, 2008 | Archos 704 WiFi Digital Media Player
All Cartridges show as empty though I know they are full.
You had it for 7, they have a 12month warranty, take it in for free repair.
Dec 17, 2007 | Epson Stylus Photo R260 InkJet Printer
Screen reads "Near empty Cyan" but I just replaced the Cyan ink cartridge, its full.
If the firmware update doesn't work, you can reset this error.
Unplug unit. Remove offending cartridge. Plug unit back in, wait until all startup noises have stopped. Open lid and reinstall cartridge. This will solve the fault as long as the sensor is working.
Also, please be aware, you should not have to change a cartridge if it says "Near Empty", only if it says "Ink Empty Magenta".
Also, please make sure none of your other cartridges are empty. I have seen this over and over. Two cartridges empty at the same time, and the person replaces one of them but thinks they actually replaced the other one.
Turn the power off and pull all the cartridges out. Look a the side of the cartridge, you should see a window with a little plastic tab sticking out. This tab should be blocked by a black float inside the cartridge. If you cannot see the float, and the tab is clear with no ink in it and no float tab blocking it, it means the cartridge is empty even if you still see some ink in the bottom.
To be sure plug the machine in without any cartridges. When all the noises have stopped, open the lid and install the cartridges. If you're still getting an error saying either a cartridge is not installed or is empty, then one of your cartridges is empty. Redo the previous paragraph.
Oct 05, 2006 | Brother MFC-5440CN All-In-One InkJet...
Vtech V.Smile TV Learning System Logo
4,610 people viewed this question
Top Vtech Toys Experts
Nikki  Mclean
Nikki Mclean
GI Consulting
relojmesa
Are you a Vtech Toy Expert? Answer questions, earn points and help others
