Question about Amana ALW480DA Top Load Washer
Broken belt on a Whirlpool dryer
Does the belt go around the tub and then around the pulley? If so how do you get it around the these two? When I put the broken belt around the tub and pulley, it seems to be too long (maybe 4-5 inches too long). Would the belt stretch that much or should there be that much slack?
Does the tub have to come out to replace the belt and would there be any pictorials to actually show me what to do?
Can I fix this myself or do I need an expert?
    President:
  • 1,902 Answers
Fix it yourself, and you do not need to remove the tub. Put the belt around the pulley and pull the tub towards the belt. You may have bought a belt that is too short. But upon a belt breaking they will stretch pretty bad also
Posted on Feb 07, 2009
How to fit a belt
The way to visually see if the belt has broken or not is to 1) unplug the dryer. 2) Remove the lint screen on the top of the dryer. 3) take the two phillips head screws out where the lint trap is. 4) with a flat head screwdriver pop the top of the dryer up by sliding the driver inbetween the top and front of the dryer and pry upwards a little. 5) You'll now see the drum, if the belt is not around it its broken, and if it's visible try to lift it. If it taught, its good. IF THE BELT IS BROKEN OR LOOSE CONTINUE TO NEXT STEPS 6) on the left and right upper inner sides of the dryer you will find two screws, one on each side, remove these and the front should be easlily remove. 7) once off you'll be able to easily see the motor, the belts idler pulley, and everything else.
Leave the drum in the machine. Now, directly in front of the motor on the floor of the dryer you will see two slots. This is where the idler pulley will go. You'll notice on the pulley at the bottom of the bracket a piece of metal sticks downward. This will sit in the slot closest to the dryer wall, and the end of the bracket will slide into the other. You'll want to slide the end in first. Now with the pulley in place take the belt and put it around the drum tread side down. To hook the belt around the motor pulley you'll have to pull the idler pulley towards closest dryer wall and place the belt around the motor pulley. Slowly release the idler pulley and thats it. Put it together and your done.
Jun 01, 2012 | Whirlpool Dryers
How do you replace the drive belt in a kenmore dryer model 88042
Pull the fron off. Remove tub, should have a spring loaded idler pulley next to the motor. Make sure that it is not broke and spins freely. Also check tub support rolers on each side. They shoule spin freely. If ok, put belt around tub, install tu. Put belt around spring loaded pulley. May need a hand holding tub while you install pulley. Put front on. Make sure the fron of cover fits inside the tub seal. Good luck. email me with issues, bobby.crochet@lyondellbasell,com.
May 14, 2011 | Kenmore Dryers
Have to replace broken belt on a whirlpool awz 7813 tumble dryer and wondered what way the belt runs around tensioners
Double the belt and slide it between the two arms of the tension pulley. Then slip the belt over the drive motor pulley. The belt will be pushing against the tension pulley from underneath.
Sep 30, 2010 | Whirlpool Dryers
Changing dryer belt on kirkland/whirlpool dryer took apart dryer but dont see where belt suppose to mount.
Hello. The belt goes around the tub and the tension pulley. In fact, it is always a good idea to replace both the belt and the idler/tension pulley at the same time. J.
If you want a schematic go to searsdirect.com and enter your model number. J.
Jun 27, 2010 | Whirlpool LER4634J Electric Dryer
How do you replace the belt on a Maytag clothes dryer
frist unplug dryer then take front panel off dry then take lint housing off there 4 screw on both side take that off remove broken belt put new belt on around dryer drum an loop belt over white idler pulley an around motor pulley idler pulley put tension on the belt
Apr 24, 2010 | Dryers
THE SPIN DRYER IS MAKING NOISE BUT NOT SPINNING
Hi, if the tub is not spinning, you have either broken the belt, or the motor has burned out. If you are a handy person, you can pull off the back panel to get a look at the tub and the belt will be wrapped all the way around the tub and motor pulley. Turn it on if the belt isn't broken to see if the motor is trying to turn at the pulley. If the belt is broken that's the problem, but also make sure the motor runs because if it if froze up due to loss of bearings it will break the new belt if you decide you are going to try and replace it on your own. You will have to wrap it around the tub and run it over the belt tentioner and around the pulley. You can get a belt at a appliance parts house. Take the model, serial, numbers and brand name, and the old belt may have a part number on it. Keep me posted please.
I will check back in the morning.
Sincerely,
Shastalaker7
Mar 17, 2010 | Washing Machines
Whirlpool dryer tub not moving, motor sounds like it is running. Have top and back off. The narrow blt around the middle of the outside tub has slack in it. Do not know how to access motor. Need help
Sounds like you have a broken belt, or the belt may have slipped off the motor pulley, or idler arm pulley.
If your machine is a front loader, then if you remove the front of the machine this will expose the drum and belt. You can then remove the drum and this will expose the drum rollers, motor, and idler arm with pulley.
While you got the machine apart, go ahead and check you drum rollers to make sure they are in good condition. Also lubricate the shaft of the drum rollers with a good grade of machine oil such as 3 in one Oil, this will save you some problems later.
I hope this helps
Oct 03, 2009 | Whirlpool Dryers
My Whirlpool dryer belt broke.
You should be able to reuse the idler pulley unless it is physically broken.
The idler pulley fits in the slots on the bottom of the cabinet (in front of the motor) with the wheel or glide facing the left side. Place the belt (grooves inward) around the drum. Pull the belt through the middle of the idler pulley from the left side and loop it around the motor pulley.
Let me know if you need more assistance.
Mar 28, 2009 | Whirlpool LER5636P Electric Dryer
Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Whirlpool Dryer Motor Removal
stand that baby up!!! acess is from front, try removeig 2 screws from under lint filter and then pop top with screw driver lean top back.. youll see the tub and belt(if not broken right there),no belt??? order a 341241 whirlpool dryer belt. 2 5/16screws on either side of iside facade remoivefront caver, disconnect door switch and remove front panel. belt slips over drum , you need to reset tension pulley and wrap around motor shaft. .
Feb 26, 2008 | Whirlpool LER5636P Electric Dryer
Amana ALW480DA Top Load Washer Logo
116 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
