Question about Philips Magnavox 51MP392H Rear Projection Television
Blue out of focus; casting blue "glow"
I have a 51" rear projection TV. (Phillips Magnavox 51mp392h) When viewing a "Dot Hatch" pattern (a predominantly black field, with criss-cross white lines, and white dots), I can cover up two of the guns to get a look at what is going on. With only the red, OR only the green gun showing this pattern by themselves, the black background is very black, the lines are sharp and distinct. But when I leave just the blue gun showing, the pattern is visible and fairly sharp, but the black background is flooded with a mild blue. Not pure black, like it should be. I can manually adjust the physical lens focus, which allows me to bring the lines in and out of focus, but the background never approaches pure black. I can use the focus knob, with the same results. I can also adjust the screen button, which adjusts the overall fill of blue in the background, but the only way to use this control to make the background pure black results in the lines and dots being nearly invisible. I performed both a simple and 'manual' convergence using the basic user menu, with no change. [Another problem, which I suspect to be linked, is that when viewing a completely white screen, the sides of the screen become progressively more yellow the further from the center. I'm hoping that "focusing" the blue gun, the blue light will compensate this yellowness, but I could be way off]
  • Ben Davis Jun 12, 2007
    After further research elsewhere, it seems as though this problem may be due to bacteria growth in the coolant inside the blue CRT. I will replace the fluid and report the results.
    Here is a link to much detail on the subject of replacing coolant fluid in CRTs for Rear Projection TVs:
    http://www.tv-forums.com/forum/TV_Equipm...
  • Ben Davis Jul 09, 2007
    I replaced the coolant using the tips found at the link above. I was careful about leaks during the procedure, and monitoring the CRT afterwards. The picture, though good before, became about 1000% better. The colors are now totally uniform. The TV looks just like brand-new. The coolant I removed looked about like runny applesauce. The stuff I put back in was crystal clear. What a Difference!
    Scholar:
  • 150 Answers
Be very carefull replacing the fluid as leaks will short stuff out and are messy.
Posted on Jul 06, 2007
We have a philips 52" projection tv that my son
If it has a blue cast someone likley turned up the blue brightness inside the TV...there are 6 knobs...2 for each color..try turning that down. Its not the PIP or bad tube...
Jan 06, 2011 | Philips Magnavox 51MP392H Rear Projection...
I have a 51 inch magnavox projection tv, the color started with a blue tint but now the red and green has gotten weird also. the screen is starting to have half circle or look bent also on top and bottom...
Ur convergence it dead,Know how to solders?Can buy a convergence kit,replaced what in the kit.Tries websites.Tv repair World.com,Tvrepairkits.com.To repair ur self.Cost u about $300 to repair by the the shop.
Dec 15, 2009 | Philips Magnavox 51MP392H Rear Projection...
Picture has red and blue shadow images
thats a fairly easy fix. You need the DPTV305-DPTV345 convergence repair kit available at the following link.
http://servicemanuals.vstore.ca/
The kit contains the parts and the CD with instructions
Sep 29, 2009 | Philips Magnavox 51MP392H Rear Projection...
Converge seeing double red and blue
That will be a convergence issue that needs to be repaired by a technician.
Jul 23, 2009 | Philips Magnavox 51MP392H Rear Projection...
Bad color 51" projection philips hdtv
need to cahnge the coolant in the Blue CRT thats a very common problem with phillips in the blue and green CRTs
Mar 15, 2009 | Philips 51PP9910 51" Rear Projection HDTV
Rear projector tv rear blue projector wont focus
Look into the top of the tube. Probably has fungus growth. Do a search. I posted that solution many times this week for that. Normally, focus don't go out on T.V's by themself. Either the tube is bad or has fungus or the screen control is bad.....but very rare will focus part fail...usually brightness/screen is at fault. Don't forget to check the green tube as well when looking. Take the back off and see if your head will fit. If not, a large mirror will do just fine. Put something on with writing displayed....easier to tell that way.
Dec 10, 2008 | Philips Magnavox 51MP392H Rear Projection...
Try changing the coolant in the blue tube. Contaminated coolant will give a halo look to the affected tube and you will experience difficulty focusing that color.Phillips/magnavox's blue is the tube most often affected with the contaminated coolant issues.
Mar 01, 2008 | Televison & Video
How to replace the crt on a phillips rear projection tv
No trick... It's a difficult task for most techs. On a scale between 1 - 10 and 10 being the most difficult you have a 10.5 there and the fun is just beginning..
Nov 24, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
611 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
