Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Was running fine, then shut off and smoked like out of fuel.
The heater had 3 gallons of fresh kerosene in it. It ran for about 15 minutes and then just shut off. It smoked like crazy as though it was spraying fuel on the hot baffle in the front.
I have two of them that are down this same way.
The other one would not start unless I took a heat gun and blew heat in the back end for a couple of minutes before trying to start it. It has been this way for some time. Weak spark? The spark looked good. The last time I ran it it ran for about 15 minutes and quit like the other one. Temp was down around zero. Possible water in kerosene??
  • mickensbrkly Jan 15, 2009
    heater runs and then shuts down plus smoke, don't know how to adjust fuel and filter. would like help asap....
THERE ARE THREE OR FOUR REASONS FOR THIS. DIRTY FUEL FILTER, FUEL PRESSURE INCORRECT, DIRTY AIR AND LINT FILTER, THE ELECTRIC EYE THAT SEES THE FLAME IS BAD, OR THE CONTROL BOARD IS BAD. THESE ARE MANUFACTURED BY MESA OUT OF BOWLING GREEN, KY AND THEY HAVE A WEBSITE. I GOT MY NEW PARTS AT MY LOCAL RURAL KING STORE.
Posted on Jan 15, 2009
Heater comes on fine runs 5 to 10 minutes and quits. sometimes it doesn't run that long
Are you using old fuel from last year? If so, drain/clean tank. Check/replace fuel filter. Refuel with fresh fuel & test again.
Dec 09, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
I have a master 150000 btu kerosene direct fire heater that runs for 5 minutes then shuts down and blows white smoke. what is the problem?
The white smoke is the kerosene fuel hitting the hot combustion chamber. Your flame has went out. The cause for this could be many. The first thing you need to do is check your fuel. Remove your fuel cap and look at the bottom of the tank for trash or water. Use a good flash light. It will all settle to the bottom. If so, drain and clean out your tank. Add fresh kerosene. Check your fuel filter. Replace if dirty. Test again. If problem continues, It is possible that your photo eye could be deffective or just dirty. It is located next to the ignitor or spark plug. It sees the flame. If the flame goes out, the unit shuts down. The flame has to be smooth (not sputtering). Water in the fuel will make it sputter and the unit will shut down. When the water/moisture in tank settles to the bottom, your suction fuel line is just off the bottom which results in it picking up the water instead of good fuel. Always disgard the old fuel from previous year and start with fresh fuel. This will cut down alot of your problems in the future.
Dec 07, 2010 | Master Heaters B155DST
Heater runs a few minutes then blows smoke and cuts off
Are you using the old fuel from last year? If so, drain and clean the tank. Replace with fresh fuel and replace the fuel filter. Check or replace the air filters. Check your ignitor for proper operation. Test again. Good luck.
Dec 01, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Runs for about 15 minutes then shuts off and smokes
It shoulds like the filters may need to be replaced. If you have done that it may contaminted fuel or not enough air flow, or a dirt nozzel. You can go to manufacturers technical support site and they offer service manuals. www.desatech.com I hope this helps you!
Jan 27, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
Ready heater forced air runs few minutes then shuts off
Sounds like a full services like its getting too much air,and blowing out the flame. Check your fuel filter,and add a new spark plug ,also change the vanes on the pump, thus aFuu service. these sould be performed every fall before .
Dec 16, 2009 | Reddy HEATER R115 115,000-BTU PORTABLE...
Pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Feb 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Blows cloud of smoke
thin your fuel mix with about a gallon of kerosene to 5 gallon of heating oil.could also be a semi clogged fuel line filter.
Nov 21, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
All pro multi fuel
This may sound dumb, but is it full? i have a simupar one and if i start it out at 1/4 tank or ness it will not run long before it shuts off.
Dec 12, 2007 | All-Pro Forced Air Kerosene Space Heater...
Clicks but wont fire
make sure the high voltage lead to the sparkplug isn't touching anything metal on its way to the plug. the clicking may be the high voltage discharging to a metal part, not the plug. those wires age during use.
Dec 01, 2007 | Reddy R70ET Utility Heater
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
199 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
