Question about Samsung S850 Digital Camera
Samsungs850 no pic in view finder
Please help only had camara 2 days ive just turn on camara and all i get on the lcd screen is black with a puple color across the top no image of what i want to take a picture of all the menus work on the lcd just no image of what you pointing camara hope some one can help thank you
  • Anonymous May 08, 2008
    screen is pitch black and I cant see anything
    Genius:
  • 2,985 Answers
This is new. I see that according to the illustration, there is no Optical Viewfinder- thus you need the the screen to compose the images - Is this correct? As this camera is new to you carefully read up the instruction manual - especially the set up routine. If after a day or so you are still in trouble - take it back to the store for replacement. Do not interfere with the camera.
Posted on Jun 12, 2007
When I turn on my Canon PC 1130 to take a picture, the lcd screen and view finder just show a black screen. Camera is working fine in the play mode. Please help.
Set the camera in TV mode, (delayed shutter mode) set the shutter at 15 sec, click to take a picture and during that 15 secs (like, after 7 seconds) open the battery compartment which cuts contact with the battery circuit. Close the battery cover. At this point the camera works fine ... but only temporarily.... Here is the key to the permanent fix. While the camera is working via the temporary fix, take many, many pictures. Hundreds! I probably snapped 400-600 pics. The idea is to wear down the little patches of hardened oil on the shutter blades. For the next three days I took hundreds of pics each day. Basically, I just aimed the camera at the wall or whatever and snapped off several hundred pics.
Jan 05, 2011 | Canon Cameras
The led screen is black as is the video being recorded. Everything else seems to working. yes the lense cap is off. It as if no images are coming through the lense.
First, Please confirm that if LCD is blank then can you see the images in view finder ? If not then the CCD IMAGER is faulty and if LCD is blank and you can see the image in view finder then then a Flexible board which connect the LCD with the main unit is broken, Please replace these parts according to the symptom. Moreover, for your ease pics are shown below of both parts with part number.
First pic is for CCD IMAGER
second pic is for flexible board.
Thanks
Oct 22, 2010 | Sony Handycam DCR-TRV33 Mini DV Digital...
The LCD screen does not display when the camera is turned on. I have installed new batteries. The screen works to see pics in the memory but does not work when taking a new pic. Also when using the view...
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Nov 16, 2009 | Canon PowerShot A60 Digital Camera
Image blacked out on LCD and can not see image in view finder
Try this, it may or may not work. Insert the Video cable plug in and out of its slot a few times. The cable when inserted turns the screen off. But sometimes corrosion can build up on the internal plug switch, also causing the screen to turn off. Inserting and removing the cable a few times can sometimes knowck off this corrosion.
Mar 27, 2009 | Canon PowerShot SD10 / IXUS I Digital...
Megxon e303
Hi,Try adjusting the LCD brightness. I guess you can do it by pressing the UP button (may be different in your camera).
Hope this works, :)
Sep 21, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Lcd screen
Please go to nearest Sony Service Center for replacement of borken LCD in your camera. You can ask an estimate befor repair. Sony UK website is as follows...
http://www.sony.co.uk/section/support
Bye
Aug 04, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
Black screen when camera is on
Thanks for the assistance. It is a problem that the mfg will have to fix.
Jun 21, 2008 | Fuji FinePix F700 Digital Camera
Black screen when camera is on...did you get an answer?
One configuration option for the F700 is to turn off the LCD when taking pictures and use the view finder-- this saves battery power. If you press the DISP button to the right of the LCD should turn on.
To turn the LCD back on-- Press MENU/OK (you should see the SELF TIMER screen). Press RIGHT ARROW to select the SET option. Press UP ARROW to select the SETUP option. Press MENU/OK. You should see the SET-UP screen. Use the UP/DOWN Arrows to navigate the options; use the LEFT/RIGHT Arrows to cycle through the options. The IMAGE DISP and the LCD options control when the LCD is powered on.
Nikon coolpix 5700
at the back of the camera next to the view finder (bottom right hand corner) is a button and icon marked SEL. pressing this button toggles the lens image from the view finder to the lcd screen and back again. IF neither view is available then I suspect your camera needs some TLC at a repair shop. hope this helps.
Jun 26, 2007 | Nikon Coolpix 5700 Digital Camera
Black screen when camara is in photo mode
anyone else had this? or know what to do. whatever best you can do is to take the camera to a good repairer as you can't fix the problem by yourself. there may be two possible reasons for the problem. 1) bad image sensor i.e. damaged CCD or 2)shutter blade are not working. the shutter blades may be jammed due to friction are no signal.
Jun 24, 2006 | Fuji FinePix S304 Digital Camera
Samsung S850 Digital Camera Logo
101 people viewed this question
Top Samsung Cameras Experts
Jerry Z
Andy Bale
Andy Bale
Are you a Samsung Camera Expert? Answer questions, earn points and help others
