Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Started washing machine; suddenly stopped drawing water
When I was starting a load of laundry, the water suddenly stopped coming in. Water line to the unit is good. Has power. Making a humming noise like it is attempting to pump water in, however, no water is going in to drum. It is an older top loader. I use cold water only.
  • patsy417 Jan 19, 2009
    It was the water pressure. I need to replace my expansion tank. Thanks for the help.
  • Maytag Master
  • 3,463 Answers
If you are certain there is water up to the inlet valve, and you can hear it humming, then there are 3 possible reasons.
  • The valve is not opening because it is stuck.Replace valve.
  • Check inlet of valve for a possible clogged filter, remove and clean.
  • Insuficient water pressure to open valve.
  • Plz rate my solution.
  • Thanks.
Posted on Jan 13, 2009
Kenmore washing machine will not stop filling
There is a water level sensor in the tube and it might be plugged. IT could also be the load selector or the control module.
Feb 10, 2014 | Kenmore 22642 Top Load Washer
I got an hotpoint wma64 front loading washing machine and my water intake has stopped working i am filling the machine with a hosepipe what can i do to fix the problem?
water goes through softner and powder draw hole gets gunged up stopping water supply take drawer out and clean then clean inside where draw fits black gunge blocks small hole where water comes through should do the trick
May 15, 2010 | Hotpoint WMA64 Front Load Washer
We have a ge washing machine model number WJRE5500G1WW. We were starting a new load of laundry and the washer was just filling with water. There was a loud noise we stopped the machine and it looks as if...
We have a ge washing machine model number WJRE5500G1WW. We were starting a new load of laundry and the washer was just filling with water. There was a loud noise we stopped the machine and it looks as if the entire central component that holds the washer separated from the metal shell. It is no longer suspended from the outer support framework
and is floating unsupported. Do you know what we should do to fix this
May 13, 2010 | Washing Machines
Front loading ge washing machine only 2 months old. door locks,
take water lines off of water valve at rear of unit and clean dirt out of screens.
Jun 19, 2009 | GE WSXH208A Front Load Washer
Bosch washing machine not drawing water
you probably have the "burst free" hoses, this machine draws water too fast so the hoses think they burst, change the hoses to the original or get new ones that aren't burst free and this should solve your problem
Apr 29, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
Water keep refilling
Hi my name is joyce
you have a water valve problem just as you suspected its not shutting off your water when its supposed to it is just continually letting water come in your machine, also if you are on a well system check the back of your machine where your lines come into your machine their is a wire mesh filter that protects trash from getting into this valve, but sometimes it gets through this, so just uncrew the pipes and check this. I had this problem, if you dont have a filtration system on your house I would stongly recomend one to prevent this from happening again. I have a well and this has been a problem for me.
let me know if I can help with anything else,
joyce
Feb 05, 2009 | Washing Machines
Not quite enough water getting into the machine. Some washes coming out with dry patches on the laundry
hi when doing wash are you sure wash load button is set for full load and not half load ? as half load is less water used and wash time can you hear water entering machine clearly when on ? also check the tun on/off tap for wash machine pipes are fully open as well as the main water supply stop **** for your abode ?
Nov 01, 2008 | Washing Machines
Kenmore Elite Calypso Wassher
Peace,
All of the above should be true!
But I recommend having hands on service , because there are to many variables!
Try unplugging the machine for 5 minutes and then restarting it and see if it is a reset situation!
Is this a solenoid problem, sensor problem or other....can I fix it... and
if I were to pour water into the machine would it recognize the water level and start to agitate and function properly so I could get some laundry done?
Sep 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
106 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
