Question about GN Netcom Remote Handset Lifter GN-1000RHL Wireless Headset
Quick Red Flashing Light on Lifter
All of a sudden today I noticed a quick red flashing light.  It's not flashing on the base only on the lifter.
  • Anonymous Mar 04, 2009
    I also get an irritating buzzing noise when the lifter tries to lift (can't even do it if the phone isn't on the lifter).
I think I just fixed the same problem on mine...
My phone has a headset button. It took a couple tries - but 2nd attempt it worked & I see no more flashing red.
I pushed my speakerphone button on the phone, then hit the lifter button on my headset...then hit the sensor button...and voila!
Posted on May 05, 2009
Amber flashing light while on home base. New, pulled tab, placed on dock. First time said charge err1, took out battery and replaced. Now just flashes amber. Is this correct?
Your manuals are here. Flashing lights must be covered. A quick look at the site says flashing red is bin full. In fact, I found it. Flashing Amber is CHARGING.
Roomba 600/500 Battery and Charging Overview On some robots, the CLEAN light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged . homesupport.irobot.com homesupport.irobot.com/.../roomba-600%2F500-battery-and-charging- overview LabeledSupport ... clipped from Google - 12/2015 iRobot: Customer Care - Roomba 700 Anatomy homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy images?q=tbn:and9gcss8oogw3vmcv_uom0z_pxoi9q5tq9n4aqrcwbsxn0zd1blfvnacictdbyn iRobot: Customer Care - Roomba 700 Anatomy Solid Red = Battery Discharged; Amber Pulse = Charging; Solid Green = Fully Charged; Quick ... The battery indicator blinks when there is a charging issue. homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy LabeledSupport ... clipped from Google - 12/2015 iRobot Roomba 500 Series Battery Maintenance homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib iRobot Roomba 500 Series Battery Maintenance Roombas "CLEAN" light should pulse red/amber while charging. ... Green - fully charged; Amber - partially discharged; Red - nearly discharged; Flashing Red - ... homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib LabeledSupport ... clipped from Google - 12/2015 Roomba 400 Series/Discovery Battery and Charging Overview homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview Roomba 400 Series/Discovery Battery and Charging Overview Your Roomba's POWER light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged. homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview LabeledSupport ...
iRobot Owner Manuals and Quick Start Guides
Dec 31, 2015 | Roomba Vacuums
Red light flashing
The lifter is a piece of junk. The red light means its time to get another. If the lifter will not lift the handset then it's time to get another - the best thing is do not get one to start!
Nov 11, 2013 | Sennheiser HSL10 Headset Lifter - BW900...
Adjust valves on 2oo4 electra glide
Hi Jd21860, the OEM push rods on your year and model are non adjustable but you do have 4 options for noisy lifters:
1. with engine at operating temperature do a quick series of 5 throttle revs to 1000 RPM'S below red line.
2. Try an engine oil additive Liquid Molly Tappet Stop Noise or Risoline Engine Treatment.
3. Cut out stock push rods with bolt cutters, remove suspect lifter, disassemble lifter and clean with carb cleaner and compressed air especially under the lifter check plate, reassemble and install, replace push rods with Taper Lite Adjustable push rods.
4. Buy new lifters.
Good luck and have nice day.
Apr 27, 2013 | Harley Davidson Motorcycles
Quick rince light is flashing..but nothing work
To clear the indicators
Press CANCEL before starting the dishwasher to clear all options
and cycles.
Sep 16, 2009 | Kenmore 24 in. 16332 / 16334 / 16339...
Plantronics CS55 requires lifting handset on phone
Please note that your hand receiver has to be off the hook when using the headset.
This is correct, additionally you can use a handset lifter accessory, such as the HL1 or HL10.
Subscribing Headset to Base:
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
7. If this procedure does not resolve your issue to try a system reset.
May 28, 2009 | Plantronics CS55 Wireless Headset
Quick green light, red flashing, 3 beeps
i need help with that......... i think i might phone sony but all my friends say u have to pay about 150 bucks but theres only a 1% chance of that happening lol.
Mar 31, 2009 | Sony Playstation 3 (PS3) Console
Tefal Quick Cup
ALERT :- Tefal Quick Cup can TURN IT SELF ON. Tefal know about this but it is a potential fire hazard. Mine turned itself on and dispensed the water reservoir over my kitchen. Dread to think if I had been out shopping what could have happened. Tefal know about this problem but are not doing anything to advertise the fault!!
Jan 19, 2009 | Kitchen Appliances - Others
Plantronics CS55/HL10 Wireless Office Headset System with Lifter won't lift headset
You may need to re-subscribe the headset.
NOTE: Before re-subscribing the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
To Re-Subscribe:
Jan 12, 2009 | Plantronics CS55/HL10 Wireless Office...
Will not power up, light flashing
you are probably experiencing a bad flyback transformer
Feb 12, 2008 | Sony KP-51WS510 51" Rear Projection...
GN Netcom Remote Handset Lifter GN-1000RHL Wireless Headset Logo
2,310 people viewed this question
Top GN Netcom Radio Communications Experts
TO Lady
bigdawg7299
Tom Chichester
Are you a GN Netcom Radio Communication Expert? Answer questions, earn points and help others
