Question about Dell Inspiron 6400 Notebook
IT SHOWS 0.00.0
    Problem Solver:
  • 8 Answers
Really there is a multitude of things that could be causing the problem. Some trouble shooting steps however.
1: Verify that the radio on the wireless router is on.
2: Check to see if the laptop has a hardware switch to physically turn on and off the wireless, (most made within the past 4 - 5 years do, if not a switch then a Fn Key + ___ Key combination usually)
3: Some Dells come with a wireless connection utility. If it does, disable this as XP and Vista do just fine on their own and a wireless utility just takes up resources and is one more thing to cause connection problems that does not need to be there.
4: Check the device manager (rt click "My Computer" scroll down to properties, click on "Hardware" tab, click on "Device Manager" (assuming this is XP, although Vista is much similar) ) Once in device manager check to make sure it sees the wireless adapter and that it does not have a yellow question mark or a red X through it. If it has an X right click to re-enable it. If it has a yellow question mark download the drivers from the manufacturers website.
5: If all else fails reinstall the driver
6: USE AT YOUR OWN RISK (although I have never had a problem with using this): If none of this works, google LSP Winsock Fix. Download the program, run it, restart the system and test.
7: If none of this works, then there is a possibility that the wireless adapter has a hardware problem and needs to be replaced.
Posted on Jan 13, 2009
  • 258 Answers
First try connecting with a Network (Ethernet cable)
If it accesses the internet double click on the Local Araea Connection, then click support
Use these values for the Wireless Network Connection
Right Click Wireless Connection --> Properties
Scroll down to TCP/IP clickonce --> Properties
Enter the values you found above when wired
it should now connect
2 Suggested Answers
  • 476 Answers
SOURCE: Acer 3000 builtin Wireless adapter says disconnected
update the drivers and run the wizard again to set up fresh settings
are you networking this unit or direct of the modem
Posted on Feb 17, 2009
Download nic
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Aug 31, 2012 | Dell OptiPlex GX150 PC Desktop
How to enable wireless connection on dell latitude e4300
I have had this issue on DSL troubles.The most common issue is the settings for the IP address.A computer in a business location will often be set for a static IP.You can change it,but don't forget to write down the static IP settings(as soon as you click on the "bullet" for "obtain IP address automatically" ,the static info is GONE,and there's no way to retrieve it.Go to control panel/network connections,right click on the NIC or Wi-Fi connection being used,click properties,highlight Internet Protocol TCP/IP,click properties.This will show auto or static IP.
May 31, 2012 | NetGear WGR614 Wireless Router
I cant connect to the internet through using the wireless connection
Hi Wayne,
I see that you are having difficulties with your wireless connection, have you tried checking if the wireless on your laptop is turned on? there should be a switch on the side of your Laptop some other Laptops may have that switch on the front.
  • Check the computer Icon in the lower right side of your taskbar it should be beside near the time, check if there are any red X or yellow Exclamation points on the computer Icon or if you have the wireless bars.
  • If you see a wireless signal but says limited or no connectivity when you point the mouse cursor on it then we just may need to check some settings on you system.
  • Also we can check you IP address on the Laptop by clicking on Start, All Program/Programs then Accessories under Accessories look for Command Prompt, once the Command Prompt window appears you will see a black box and a blinking cursor type in IPCONFIG then press enter this will show us you Laptops IP address or IPV 4, the IP should begin with 192.168.x.x but if it shows 169.254.x.x then this is a bad IP address, try recreating the wireless network in your laptop to renew the IP address.
  • First check the Router for any indication if the wireless light is turn on or not if not check the router settings and turn on or enable the wireless signal of your Router.
  • If the wireless light is turned ON then check the Router settings for any security options and if your Router has a security key enabled on it then you should copy and set that security in your Laptops wireless network settings in Network and Sharing Center.
  • if still the wireless connection doesn't connect we can try to uninstall and reinstall the Wireless driver for your Laptop which would require you to check first if you have a copy of the wireless driver inside your hard rive if you don't have the Installer for the driver then you may need to use a different computer to be able to download the wireless driver from your computer manufacturers website.
I hope that this will be helpful in resolving you Laptops wireless connection.
Have a nice day.
Apr 06, 2011 | Averatec 3200 Notebook
Cannot get wireless internet to work. Set up wireless connection. Icon shows connected, excellent strength. There is another computer icon next to it on the task bar however that shows a red X through it,...
find that ip of the router e.g or something like that
gott to the lan network connection of pc
got tcip option
in ther enter the ip addree ( anything but ther router address)
subnet mansk
defualut gateway the routers ip address
primary dns router router ip address
leave the secondary ip blank
Mar 05, 2011 | Computers & Internet
Intel Proset wireless just drops connection
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default DNS server address type the default gateway in primary DNS and in secondary your connection won`t drop after this.
Jul 02, 2009 | Intel 3945ABG (WM3945AGM1WB) 802.11a/g/b...
Dell Laptop is not pulling IP address
Connect it directly to the modem with the ethernet cable first...Windows will configure the Dell...then the wireless should work.
Feb 27, 2009 | Dell Inspiron 6000 Notebook
We have Linksys G wireless router for our 2 home pc's and would like to get our laptop also connected - please help..
- Let me know what is the configuration of your wireless?
- If your configuration have no IP address included to access your Wireless connection?
- You need to obtain the Network IP configuration for automatically connection the Wireless Point.
- Let me know The Operating System of your Laptop?
- The same Procedure if your Settings Wireless Connection or IP Address needed.
- If you are using Windows XP Please Follow the Instruction.
1. Select [START] =>
4. Select your Wireless Connection if you have or your local Area Network then PROPERTIES.
5. On GENERAL = Use Scroll down Under: This connection use the following items Select Internet Protocol {TCP/IP) then Click Properties.
6. Select Obtain for automatically connection or add IP address if needed then apply.
Sep 23, 2008 | Linksys Wireless-G WRT54G Router
1394 LAN connection - no IP address
r u configure the ipaddress to the wireless router
Aug 30, 2008 | Computers & Internet
IP address
Did you just install this card??
If so did you install the software first?
How far away is the this from the router??
Feb 13, 2008 | D-Link AirPlus G DWL-G510 802.11g/b...
Internet connection
install your wireles driver and any data card buy it and enjoy your internet
best connection is airtel
Oct 26, 2007 | Samsung V25 XVC 2800 Notebook
Dell Inspiron 6400 Notebook Logo
175 people viewed this question
Alun Cox
