Question about Gateway Computers & Internet
Can you have to much Ram for a processor?
Motherboard is a Gateway D865GLC currently has 2-256MB DDR PC2700 and 2 open slots. Online diognostic Crucial memory stick thing says each slot can handle a max 1gb card. I am looking at put 2- 1GB DDR400 PC3200 or DDR333/PC2700 in the empties for a total of 2.5 GB. My Processor is a Pentium 4 2.60 GB 800 MHZ FSB w/ HT. Is quintupling the RAM like this outdoing what the processor is capable of, or should cause no problems? All of the RAM is Non-ECC and unbuffered. Intel 865G Chipset is on the motherboard. Thanks for the time and input.
    President:
  • 1,901 Answers
You'll be fine. If you have been on crucial you know then whether the modules need to be in matched pairs, which is what it looks like you are doing. The only limitations on RAM are when you go to 4GB using 32-bit processing. It will most likely not all show. But with 2.5GB, you should be humming along quite nicely.
Posted on Jan 13, 2009
System reguirements to inrease ram memory
Ram Memory typically operates at half of the frequency rate, ('Speed'), that the Processor's -> FSB does.
Your motherboard supports Processors that have either a 400MegaHertz Front Side Bus, (400MHz FSB), or 533MHz FSB, or 800MHz FSB.
(Northwood Core for 400MHz FSB. The rest is in the other solution I provided)
Processor has a 400MHz FSB?
You can use DDR Sdram ram memory that is 266MHz.
(PC2100)
Processor has a 533MHz FSB?
You can use DDR Sdram ram memory that is either 266MHz, Or 333MHz.
(PC2100 and PC2700 respectively)
Processor has an 800MHz FSB?
You can use DDR Sdram that is either 266MHz, or 333Mhz, or 400Mhz.
(PC2100, PC2700, and PC3200, respectively)
NOTE*
When using a processor that has an 800MHz FSB, and using PC2700, (DDR at 333MHz), the PC2700 ram memory will run at ->
320MHz.
JEDEC has set the voltage requirements for DDR Sdram at 2.5 Volts.
'Performance' ram memory that is DDR Sdram may use higher voltages.
Not recommended unless you know how to overclock.
Although the motherboard, and the ram memory module may have SPD, it doesn't always work,
http://en.wikipedia.org/wiki/Serial_presence_detect
A lot of times you are faced with going into BIOS Setup, and changing the ram memory voltage, IF BIOS Setup has this feature.
This is why I say overclocking experience helps tremendously.
You want Low Density, Unbuffered, Non-ECC, and a CL of 2.5 for PC2700, and a CL of 3.0, (3) for PC3200.
[Why would anyone want to run PC2100> Lol! ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 11, 2012 | Computers & Internet
How can I find out exactly which model of MPC ClientPro I have? The model # on the sticker is D865GLC-0DYD (note, that is a "zero," not the letter O, before the DYD at the end). I can't find...
System memory for D865GLC-0DYD
The Desktop Board D865GLC has four DIMM sockets and supports the following memory features:
  • 2.6V (only) 184-pin DDR SDRAM DIMMs with gold-plated contacts
  • Unbuffered, single-sided, or double-sided DIMMs with the following restriction: Double-sided DIMMs with x16 organization are not supported
  • 4 GB maximum total system memory
  • Minimum total system memory: 64 MB
  • Non-ECC DIMMs
  • Serial Presence Detect
  • DDR400, DDR333, and DDR266 SDRAM DIMMs
Jul 06, 2011 | Computers & Internet
I need to know the correct ram speed for the Asus P4B533 board, thanks.I have 3 slots. I want to install the maximum possible.
here you go mate:
Memory Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 266 MHz Max Supported RAM 2 GB
Dec 01, 2009 | ASUS P4B533-VM Motherboard
Finding Intel 845GVSR & 915GLVG Compatible Motherboard & Proc
you can use intel dg41 mbd , dualcore processor,1 gb ram,160 gb hdd or use intel atom for support contact 91-9645071021
Aug 11, 2009 | Intel D845GVSR Motherboard
Can you add to much Ram for the processor to handle?
That additional RMA will be good for your computer so it will be much faster and don't worry everything should work fine there after adding new RAM to your computer....
Jan 13, 2009 | Intel Computers & Internet
Can I put to much RAM in the motherboard for the Processor?
That additional RAM will be good for your computer so it will be much faster and don't worry everything should work fine there after adding new RAM to your computer....
Jan 13, 2009 | Intel (C733) Celeron A, 700 MHz Processor
Gigabyte GA-81EXW memory chips
Any 184-pin ddr ram should work on this. You can actually use pc3200 (ddr 400) ram as well. Pc2700 ram is ddr333, and a higher speed ddr ram like pc3200 will work just as well if not better than pc2700, it will simply go down to the speed that the processor requests the ram run at. It's all backwards compatible, faster ram can run slower if the computer needs it to run at the slower speed. Depending on the price you can find as long as you get 184 pin ddr ram either pc2700 or pc3200 with work fine with your motherboard. Peter
Oct 02, 2007 | Intel Motherboard
Computers & Internet Logo
102 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
