Question about Dayton E51 Oil Filled Utility Heater
Heater starts up but quits after 20 seconds?
I have put in a new igniter, clean fuel and cleaned fuel filter.
  • 181 Answers
What is the air pressure set at.very important it is set exactly or the unit will not work properly.need to have a pressure gauge to set the pressure....
Posted on Feb 23, 2009
Kerosene Heater starts up and then shuts down
David, you need a copy of the Troubleshooting Manual here:
http://www.toyotomiusa.com/OwnersManuals/Portable%20Heaters/Name%20begins%20with%20LR%20or%20LS/LR-350%20LR-450%20Troubleshooting%20manual.pdf
It sure sounds like a failure during pre-ignition. Page 5 covers both of your burn times with two different Flow charts.
A yellowish flame can mean a warped flame ring or incorrect air flow.
Dec 29, 2014 | Heating & Cooling
Remington 35 portable forced air heater parts
Top cover is shorting out the spark plug wire.
Jan 10, 2014 | Heating & Cooling
Fuel filter replacement 7.3 liter diesel
I'm not too uppety-up on diesels but I have changed a few. My description is pretty basic.
BEFORE doing anything, make sure you have at least a quart (or more) of FRESH CLEAN diesel in separate container.
Locating the filter is usually in site when opening hood and fairly easy to get to. The ones I've done, look simular to a spin on oil filter. Usually there is a valve on the bottom to drain fuel and/or water out out of the filter.
First, drain fuel out of filter,may need a hose and a catch pan so is not to make too much of a mess.
Second, spin old filter off.
Third, take your fresh clean diesel and pour it in the new filter up to being full but not running over, make sure you wet the o-ring with clean diesel also.
Fourth, spin new filter in place.
Fifth, turn ignition key to on for at least 10 seconds or more, NOT starting the engine. You should hear a pulsing sound, that's the pump priming the new filter, can't have any trapped air in system. If there is too much trapped air the engined will not start or stay running. This has worked for me quite a few times but if you want more information go to http://www.ford-trucks.com/forums/index.php and put your question in the search box in the forums section. Hope this helps.
Nov 28, 2011 | Ford Cars & Trucks
Heater will not start
Does the blower motor start when you plug it in/turn it on? It may take around 5 seconds if your heater has a HSI(hot surface igniter). If it does you need to check the igniter and the fuel flow. Either way, remove the top of the heater. You will be able to see the fan, igniter, and fuel nozzle. Turn the fan by hand to see if it turns freely. If it does, watch out for the fan and turn the heater on. Look for the igniter to start sparking (spark plug type) or glowing (HSI type). Next, use a flashlight to look for fuel spraying from the nozzle. If fuel isn't spraying, try cleaning the fuel nozzle and check the fuel filter. Watch out for the HSI, if you have one, they are very brittle and easily broken. If you still don't have fuel flow after cleaning the nozzle and the fuel filter, you may have an air pressure problem. Let me know and I will tell you how to check it. Don't forget to rate the answer if it works.
Jan 03, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
125btu reddy heater, somene mixed some gas in the heater and now it won't ignite. how to fix??
Drain it clean it out real good clean out the fuel system end to end. From the line in to the tank thru the filter and so on remove the nozzle clean the screen and nozzle put it all back together. with the top section removed try to start the heater. You should have a fine mist of fuel and spark if it lights shut it down and clean the photo electric eye with a soft cloth and windex. make sure the igniter is clean and close to the fuel mist for ignition, put the top on and turn on your heater.
Dec 14, 2010 | Reddy Heater RH125T Kerosene Forced Air...
Runs than shuts off after a few seconds
Is this a propane or kerosene heater? If it is kerosene, check your fuel, clean your tank and start with fresh fuel. Check your fuel filter/air filters at the back of air pump. Make sure your ignition system is working.
Dec 01, 2010 | Reddy Heater-30-55,000 BTU Variable
REDDY HEATER 125T WON'T INGNITE
  1. Does the ignitor glow for 5 seconds when the unit is started?
  2. What is the air pump pressure reading?
These are the starting points for troubleshooting a heater that has an ingntor.
Answer these questions and maybe someone can get you started.
Dec 16, 2008 | Desa International RH125AT Utility Heater
Error code ee2
How long has it been since you last had it cleaned. There may be soot build up in it, including the burner pot keeping it from igniting. When was it last working properly?
Dec 07, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
30,000 btu kerosene ready heater
check pressure of the air compressor should be in the 3.0 to 3.5 range. not enough won't suck fuel, too much will blow out the flame. igniter either lights or it doesn't no in between. does the main flame come on?
Jan 05, 2008 | Heating & Cooling
Dayton E51 Oil Filled Utility Heater Logo
130 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
