Question about LG Electronic Window Air Conditioner
Loud Rattle and Leaking
I bought it a few months ago, been running fine. 3 days ago it started making a loud rattling noise and blowing out drops of water all over. Cold air comes out just fine, but I have to keep towels on the floor to soak up the puddles of water, and it is very hard to sleep with the really loud rattling sound all night. Please tell me what I can do to fix it.
  • 1 more comment
  • louis2312321 May 17, 2008
    I have the same problem but I do not know where the drain pipe is to unclog it.
  • supphilly Jun 06, 2008
    Same problem here! Don't know where the drain pipe is or what it looks like! Help! Heat wave starting tomorrow
  • tootiefruity Jun 20, 2008
    ditto. Where is the drain?!?
  • 3 Answers
If the unit has been working fine for a long time and then you suddenly have this issue, the angle you have the unit set at is probably fine, but you probably have a blockage of dirt/mud/sludge/whatever that is keeping it from draining properly. Here's what you have to do...
For safety... turn the unit OFF and UNPLUG IT.
Open the front gate and remove the air filter. Next, remove the entire front gate from the unit (probably at least one screw to remove first - mine was in the middle, just under wher the bottom of the air filter sits). With the gate removed you should have access to locate your blockage problem.
There is a hole that allows the water to drain from the front of the unit (the part that is inside your house) to the back of the unit (the part that hangs outside your house) and eventually out of a drain hole in the rear. Chances are that this hole is clogged. So, when the water fills up in the front drip tray it has no access to drain to the back. Consequently, the water builds up in the fan area which causes the rattling noise and the water being picked up by the fan and blown out of the vent. If left too long, it will overflow the front drip tray and make a mess in your house.
On my unit, the hole was on the far left side (if your are in your house and facing the AC unit) of the drip tray. You can use a piece of coathanger wire, or some other long thin instrument to push the blockage through to the rear. Once this pathway from the front of the unit to the back of the unit is clear, your problem should be solved. You will probably still get the sound and water sputter out of the front for a little while until the water that is in the fan area drains/dries out, but it should return to normal soon.
It is probably best to actually remove the unit from the window and take the cover off of it and really clean it out, but that is obviously a much more involved task. If you have a hose, that's fine and will help. Water won't hurt the unit - just keep it away from the electronics (the controls/display/cord). You should also be carful not to bend any of the tiny metal fins... that's just as bad as (actually worse than) being blocked by dirt/dust. And obviously, allow the unit to dry before you put the cover back on and put it back in your window and plug it in to run it. If you are willing to put in the extra time and effort, you can do a more thorough cleaning job, which would help to prevent the problem from happening again too soon. There's no way to prevent dirt/dust from building up in the unit. Once water/moisture is added to the mix, you're dealing with mud/sludge, which is going to eventually block that small drain path. The only solution is to clean it out once in a while.
I figured this out the hard way. I took the thing out of the window cleaned it (not as thoroughly as I thought) and put it back in and then did it all again. The third time I actually found the hole that was blocked. If it hadn't been such a pain taking it all apart and cleaning it the first two times I would have laughed at myself for missing it.
Good luck! Hope this helps!
Posted on Jul 27, 2008
  • 105 Answers
Make sure the unit is level, this is very important. If it is level, then you have a blockage in the drain tube running from inside to outside. The tube is at the bottom of the drip tray under the cold coil. It may be cleared with a piece of coathanger wire. Be gentle.
Posted on Jul 15, 2007
Waht would cause a loud rattleing noise in my engine?
get it into a garage before something really goes bad then you'll be looking for a new beamer
Apr 29, 2014 | BMW 325 Cars & Trucks
Rod knock upon start
Not sure on model but to me sounds like its a dodgey valve lifter when the seals start to go they cannot hold the oil and when there under pressure they basically empty them selves hence when you turn the engine off and restart you get a rattle sound untill the valve fills again as long as the cars running ok leave it untill you have to replace them unless there easy to do sone are sone are a pain
Jul 04, 2017 | 2004 Nissan Maxima
Rattling in engine bay
check your belts and the bolts around that area, sounds like loose bolts causing something to move and rub
Aug 05, 2013 | Vehicle Parts & Accessories
Engine rattle noise
Have you checked your oil? Sounds like you may have run it way low, the loud metallic noise is probably metal on metal contact inside your engine, add oil and it that fixes it, count yourself lucky, if not need to take it to a shop.
Dec 19, 2009 | 1991 Toyota Camry
My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
Loud noise from 99 Honda Accord
is your ac compressor located on the left side as well and also try your ac if its not blowing to cold the rattling could be your ac clutch on the compressor if that is you will have to get a new clutch kit from your local auto parts store to fix it
Mar 16, 2009 | 1999 Honda Accord
Engine noise at cold start-up.
Sounds like your oil pump inside the engine is not pumping oil fast enough when you start your vehicle its common problem for mitsubishi motors my car does the same thing.
good luck
Nov 04, 2008 | 2002 Mitsubishi Montero
LG Electronic Window Air Conditioner Logo
701 people viewed this question
Top LG Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Steve F
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
