Question about Sony VAIO PCV-RX470DS PC Desktop
Remove outer cover
How do i remove case from sony pcv rx305 please
    Problem Solver:
  • 17 Answers
Have you checked the screws on the back? On most cases, if you look at the front of the case, it's the left that comes off, so look for any screws and any latches under the front face.
Posted on Jan 15, 2009
How do I open my sony pcv-v1
1. Ground Yourself
2. Unplug everything and press the power button for 10 sec to
discharge any residual power.
3. Place PC face down on bench with base over edge.
4. Swing PC unit forward and unscrew the case retaining screw on both
sides of the PC unit, swing unit other way and remove other two
screws.
5. Case can be loosened, pull large cover up and remove both sides.
Parts are then exposed.
6. A shiny metal box covers the memory on the left side of the PC unit. 7. Remove tape that retains it,slide and lift off from the edge facing you.
8. Memory slots are then exposed....insert and reassemble PC.
Good Luck!
May 14, 2012 | Sony VAIO PCV-RX403N PC Desktop
How the heck do you get the side panel off Sony
From the Sony manual:
http://www.docs.sony.com/release/PCVRX670_SR.pdf
Removing the Side Cover
You must remove the side cover to access the system board, add-in cards,
power supply, battery, memory, and internal drives.
1 From the rear of the unit, pull the metal tab shown in the next
diagram. (Upper right corner)
2 Pull the top of the cover away from the unit about two inches, then
gently lift out the cover.
Aug 01, 2010 | Sony VAIO Digital Studio PCV-RX580 PC...
Took the cover off to clean the dust off the fans put it back together it will turn on and fans will run but wont boot
1) Side Cover off; Observe whether the fan that pushed air over the Processor is operating.
2) Remove all ram memory modules, and reseat them.
Doesn't take much to bump a ram memory module ('Stick') loose.
Although they may appear to be correctly seated in the their individual ram slots, it is just added assurance to remove, and replace them.
3) Computer was unplugged from power, and if you reached inside, you did observe Anti-Static Precautions, correct?
Anti-Static Precautions:
Your body carries Static electricity.
Static will fry out (Short Circuit), the delicate hardware components inside a computer.
You must relieve your body of Static BEFORE, reaching inside your computer.
Computer unplugged from power, Touch the metal frame of the open computer case, to relieve your body of Static.
As also has been stated, make sure all cables all plugged in tightly.
This is Sony eSupport > Vaio PCV-RX650 desktop computer >
http://esupport.sony.com/US/perl/model-home.pl?mdl=PCV-RX650&region_id=1
Left-click on Manuals, Specs, Warranty
Under the Manuals heading, left-click on System Reference Manual
Jun 30, 2010 | Sony VAIO Digital Studio PCV-RX650 PC...
How do I remove my DVD burner for replacement from my Sony VAIO PCV-RS720G? I get the two little screws out from the side, but then something hangs it up. Can't find what the hang up is. Thanks. Segalhund...
Segalhund, I appreciate your wanting a solution, but please refrain from stating your email addy.
There are three screws.
Facing the back of the computer.
One at the Top in the middle of the case cover.
One down on the Right side, straight across from where the monitor plugs into.
One down on the Left side straight across from where the monitor plugs into.
The cover is shaped like a hood, and slides towards the front of the computer.
I'm looking at the User Manual for the Sony Vaio PCV-RS720 Desktop PC right now.
This is Sony eSupport, and the download page for the Vaio PCVRS720G User Manual,
http://esupport.sony.com/US/perl/model-home.pl?mdl=PCV-RS720G&region_id=1
On this page left-click on Manuals, Specs, Warranty. (In blue to the upper right of the page)
On this page under the heading - Manuals -
left-click on - VAIO User Guide - in the list.
This is a PDF file. It may take as much as 30 seconds before you see the first page. Suggest you let it download all the way before looking through it.
Page 87 shows removing the cover.
Mar 28, 2010 | Sony VAIO PCV-RS720G (027242658103) PC...
Location of the hard drive
Turn the desktop round so the back of it is facing you.
Remove the screws that are on the bottom left and right, and in the top middle and remove the outer casing by sliding the case towards you.
Once the outer cover is removed face the case so you can see the motherboard.
The hard drive is located behind the front panel of the case underneath the CD/DVD drives.
It should be laid on its side with cables coming from it.
As far as i know the hard drive bay will just slide out but there may be holding screws.
Regards.
Sep 17, 2009 | Sony VAIO PCV-RS312V PC Desktop
How to open sony vaio-pcv-w101/w to replace bad ram?
Try this:
STEP 11
Lift up and remove notebook display panel.
13-taking-apart-notebook.jpg STEP 12
Remove hard drive cover, memory cover and modem cover from the bottom of the notebook. Each cover is secured by one screw.
14-taking-apart-notebook.jpg STEP 13
Here’s how you can remove the hard drive. Remove four screws securing the hard drive caddy to the base assembly. Slide the hard drive down to disconnect it from the motherboard. Lift up and remove the hard drive.
15-taking-apart-notebook.jpg STEP 14
Removing memory modules (if needed). Carefully spread latches on both sides of the memory slot. The memory module will pop up at 30 degree angle. Pull the memory module from the slot by the edges.
Removing modem card (if needed). Remove two screws securing the modem card. Lift up the modem card to disconnect it from the motherboard and unplug cable from the side.
Hope this Helps
DR GEEK MD
May 06, 2009 | Sony VAIO VGC-V617G PC Desktop
Sony Vaio - How to remove side cover?
On Sonys, you have to remove the top cover first. Look in the back and you will see 2 tabs. Pinch them together and remove the top cover, then the side should slide off.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 25, 2008 | Sony VAIO Digital Studio PCV-RX550 PC...
Problem Sony VAIO PCV-W510G
maybe this can help you,please try to replace the fan or you can also clean it.. http://www.docs.sony.com/release/PCVW510G.pdf
Jul 05, 2008 | Sony VAIO PCV-W510G PC Desktop
SONY VAIO PCV V1G
Model:PCV-V1/G
Unplug everthing and place PC face down on bench with base over edge. Earth yourself.
Swing pc unit forward and unscrew the case retaining screw on both sides of the pc unit, swing unit other way and remove other two screws. Case can be loosened, pull large cover up and remove both sides. Parts are then exposed. A shiny metal box covers the memory on the left side of the PC unit. Remove tape that retains it,slide and lift off from the edge facing you.
Ten minutes tops....good luck, much better performance.
Apr 03, 2008 | Sony VAIO PCV-V100G (PCVV100GKIT1) PC...
Sony VAIO PCV-RX470DS PC Desktop Logo
188 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
