Question about Opti -UPS BackUp-Time 525BT (UPS-525BT) UPS System
Opti-UPS 525bt A couple years ago, I swapped the original (7A2) battery for a car battery and had to be careful, because I measured some 90V or so, between the housing and battery terminals. It all went good until the day I accidentally misplaced the setting on my multimeter; instead of the voltage measuring setting, I had it on Amp setting. Result: It shorted the circuit, the house fuses went off and now my 525bt only works via battery supply, running only about 5 minutes after switching on the main switch of the unit. The 5 fuses of the unit are all O.K.; nothing looks burned. I'm a fourty year experienced hobby electronics fan and would need a circuit schematic to find and repair the damage. In the worst case I thought of powering the unit via two 13V/4Amp transformers in (parallel phase)via a bridge rectifier, a 60oooMF/16V electrolytic capacitor and an automotive relay, switching over to battery PS in case power failure. The only problem I then would have is: how to get rid of that timed 5 minutes automatic turn off cycle??? It must be in that IC or is there a timing cap responsible for it? What to do? I would greatly appreciate some advice on that. Maybe I'm able to reward you for your good advice with offering you some joy with my musical twitter-talent? ( http://www.live-styler.de/home/images/jjj-DEMO.wma ) I'm a retired (66) living in Chile and we got lots of power problems...
Hello is this ups a sine wave output or modified sine wave output. Thanks
The manual states when running on AC, it is the same sine wave ouptput that comes in. When running on DC, it is a modified sine wave.
Nov 30, 2010 | Opti -UPS BackUp-Time 525BT (UPS-525BT)...
My Opti-UPS 650ES needs repair. I bought a
tgliang, I appears that the company Opti-Ups is no longer supporting this UPS. Best bet for you will be to get a new unit to replace it. Check the Opti-Ups website. www.optiups.com 12fixlouie
May 20, 2010 | Opti -UPS PowerES 650 UPS System
Numeric UPS not working
when i on my ups it is indicating to fault showing a red light and giving a long beep sound and no output voltage is coming from it do i need to configure?please help me
May 10, 2010 | Opti -UPS BackUp-Time 525BT (UPS-525BT)...
How do you replace the battery in the Opti Vs575c ups system
reverse down the ups four holes will be seen insert the screwdriver and open the ups also open the clamp of battery and replace the new battery take care that +ve is connected to +ve and -ve is connected to -ve usually red is +ve and black is -ve
Mar 30, 2010 | Opti VS575C UPS System
UPS power goes off instantly as soon the external supply stops.
In our office, I have had to replace UPS batteries AGAIN two years after I replaced the original batteries in the units. I had purchased the replacement batteries locally, so I don't know if the brand of replacement batteries was not as good as the original batteries or what. But your weak battery light is not flashing ... I would try a replacement battery (if it isn't too expensive) but I know that some of the older batteries are no longer used in the newer UPS units so if the problem wasn't the battery you are stuck with a new battery and nothing to use it for.
Mar 04, 2009 | Opti -UPS PowerES 1400 UPS System
UPS
All UPS uses some sort of battery to power the unit in the event of a power outage. Like car batteries they also have a life span which can be a couple of months to a year or so. If the UPS has been in service for some time, perhaps it simply needs a replacement battery. On the other hand, if the unit is fairly new and carries warranty, it may be to your advantage to consult your dealer and claim for a replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 10, 2008 | Opti -UPS PowerES 650 UPS System
OPTi ups surge protector
clear and simple. the batteries are bad. they last about 3-5 years usually. "batteries plus" in your area will usually replace them and dispose of the old batteries. In the past I have replaced the batteries myself and taken the old ones to a battery surplus house and gotten a few dollars for the old ones (battery core).
Sep 10, 2007 | Opti -UPS PowerES 650 UPS System
I'm in trouble... blew my UPS :(
You are complicating your power problem. It looks like a surgeon that gets a cold, gets involved in his medical knowledge and decides to implant himself a heatr rate monitor. If you have a serious power problem in Chile, your best bet is to buy a UPS with enough capacity to handle the load for extensive periods of time. American Power Protection has a very good configuration tool on its website (www.apc.com).
Jun 13, 2007 | Opti -UPS BackUp-Time 525BT (UPS-525BT)...
Open Questions:
Opti -UPS BackUp-Time 525BT (UPS-525BT) UPS System Logo
184 people viewed this question
Top Opti Computers & Internet Experts
galvinfranks
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Davit Mamyan
Davit Mamyan
Are you an Opti Computer and Internet Expert? Answer questions, earn points and help others
