I just installed a x8dt3 in a supermicro chasis and I have not been able to get any video from the board. I tried with no RAM no processors and not HD's. Same result. Using on board video. No beeps and no error lights. Not sure what it could be.
SOURCE: SuperMicro H8DCE-O R Motherboard no video
did you plug up toe power to the video card, the problem seems to be that the video card is getting no power, if the power is hooked up properly to the video card, the your power supply is probably not powerful enough.
SOURCE: SuperMicro H8DCE-Motherboard no video
Are you hooking up The 24 pin ATX J1B1 connector and the 8 pin processor power connector JBW1 ? Alot of guys don't realize that new AMD's get power from a special connector on the motherboard..If you don't have this connector on your power supply you will need to get one that does. Hope it is this easy.
SOURCE: I installed a Radeon HD 4350 video card and the
unplug the new card and retry,,
if it works without the card then take the card back to the store
SOURCE: I.have installed Window 7 ultimate
no. 32bit of windows can only use 3gb.
reinstall to win7 64 bit.
