Question about Acer Aspire™ T180 PC Desktop
I upgraded my Ram to 4 new 1gb but does NOT open windows
I put in 4 new PNY 1GB DDR2 800 Mhz PC6400, initially it worked but when I switched it off it won't open windows (vista), when I put the old ram back it started working again, I researched the ram thoroughly and made sure its' compatible as I am no genius, I had never expected this to be too complicated.
  • raymondbuena Jan 22, 2009
    GREAT STUFF, GREAT PEOPLE, GREAT COMMUNITY!!! All is working just fine! MANY THANKS Preachw996 and antiochpc
    President:
  • 1,179 Answers
It could be that one of the new sticks is bad. Try replacing the old RAM one by one with the new RAM until you find the one that is causing the problem. Hope this helps.
Posted on Jan 13, 2009
    President:
  • Acer Master
  • 1,314 Answers
It is possible that one or more sticks are bad. Try them each one at a time and see if it works. If it boots with one, then shutdown and put in another until it doesn't boot. Once it doesn't boot, remove the one you just put in again and test the others as well. Oh and please take a moment to give this solution a fixya rating. Thanks! :c)
I bought a new 1GB ram(DD2) when i insert it it nt work bt whenever i insert it with old 512MB ram then its work bt in bios setting only show the 1GB ram
Maybe 1GB is the maximum amount of memory that your system will hold. And maybe your system likes memory to be in pairs, so when you put the 1GB in by itself it didn't work, but when you put it in with a 512MB it works.
May 18, 2012 | Computers & Internet
Hello! I have a D101GGC motherboard and I want to upgrade my memory, I mean now i have two RAMs at 250MB and i bought one DDR 1GB PC3200 400MHZ CL3 KINGMAX MPXD4. The problem is that the PC doesn't...
Please check the speed in MHZ of old RAM and New 1GB RAM.
Some times if speed wont match this problem occur.
Remove old RAMs and add only 1GB RAM and start the system.
I hope it will help you.
Thanks for using FixYa.
May 31, 2011 | Intel D101GGC Motherboard
I recently purchased Two PNY 1Gb ram to upgrade from original 512mb. When I put both 1Gb ram in the slots, the computer will not boot up. When I take one out and put the original 512 back in with the other...
I don't know your specific model, but some of the Emachines had some memory directly on the motherboard. With the 1Gb and 512Mb sticks installed, boot the machine and report how much memory the system sees. Perhaps the onboard memory is causing you to exceed the 2Gb limit.
Please post the memory size you get here with the above sticks.
Thanks,
Dan
May 12, 2011 | E-Machines W6409 (7234) PC Desktop
Is it possible to add 1GB DDR1 RAM 333 MHZ to INTEl D101 GGC
u can use the 1gb ddr1 ram,if the sound is coming then may there is two problem
1.may be the ram is damage
2.your motherboard is not supporting 333mhz bus support
try to find 400mhz ram instead of 333mhz
Feb 27, 2010 | Intel D101GGC Motherboard
Can I put to much RAM in the motherboard for the Processor?
That additional RAM will be good for your computer so it will be much faster and don't worry everything should work fine there after adding new RAM to your computer....
Jan 13, 2009 | Intel (C733) Celeron A, 700 MHz Processor
Is there any problem in using a 1GB DDR with 400MHz speed in Intel D845GVSR board?
Since Intel says that this board will support DDR with 200/266/333 MHz speeds only.There should not be problem with your board more so that it works fine.
Jul 25, 2008 | Intel D845GVSR Motherboard
Installing Ram in a Dell Laptop
Yo u have 2 slots in u r machine I am sending u details information of updradation in ur machine :
frequency of ram should be
667 MHz Dual Channel DDR2 SD RAM
option 1.
A system ready for the next generation of applications and games 3 or 4GB1 Dual Channel2 DDR2 SDRAM
2.
A system capable of handling Windows Vista® Aero as well as today’s latest games. 2GB Dual Channel2 DDR2 SDRAM
3.
Basic performance for the Windows Vista® AeroTM interface (PCs purchased with Windows Vista Home Premium and less than 1GB of memory will NOT be capable of running Aero). 1GB Dual Channel2 DDR2 SDRAM
4.
Basic performance, lowest initial cost (Windows Vista® Home Basic) 512MB Dual Channel2 DDR2 SDRAM
Jun 21, 2008 | Dell Inspiron 8600 Notebook
Ram upgradation for 845glad mother board
Hi! If you have orignal Intel D845 then you need ram less than 333 Mhz (Around 266mhz or so) and do remember to check that it is advisable not to use RAM of more than 1GB as you won't be able to find a 1GB RAM(DDR1) with 266 Mhz or less.
May 16, 2008 | Intel Motherboard
SAMSUNG 1GB RAM 400MHZ PC3200
RAM has to be
Four 184-pin DDR DIMM sockets
Supports PC3200 (400 MHz) /PC2700 (333 MHz) / PC2100 (266 MHz) DDR DIMM type
Maximum HP/Compaq approved memory module is 1 GB
Maximum HP/Compaq approved memory is 4 GB
It has to be the same.
• If you are replacing a memory module, put the
new memory module in the same memory slot
from which the old memory was removed.
Or
• If you are adding a memory module, install the
new module into the socket nearest the
preinstalled module, and install additional
modules in the next available sockets
Jan 14, 2008 | Computers & Internet
Acer Aspire™ T180 PC Desktop Logo
59 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
