Question about GE Bluetooth In-ear Headset Wireless Headset
GE 21518 Celluar Gateway won't allow use of touch tone menus.
When calling a company which uses a touch tone menu system for customer service, the GE 21518 doesn't properly transmit the tones. The menu system is non-responsive when I press the appropriate key.
This is the "nature of the beast" with this unit. I have found the same issue. It seems to vary based on which cell phone you use it with. The Moto Droid I had briefly seemed to allow the DTMF tones to work pretty well. Otherwise, this is a great product. You'll just have to grab the actual phone to enter the tones. :(
Posted on Jun 02, 2010
NET10 W408g does not allow using the Xlink gateway fully, especially sending DTMF codes to automated systems.
Jim
Been a long time since I have seen this phone but I seem to remember a setting like this. Some phones had a long and short setting too.
Mark
Motorola Support
Activate DTMF tones: Menu > Settings > Initial Setup > DTMF When you dial a number, your phone sends it to your network as Dual Tone Multi Frequency (DTMF) tones. To send DTMF tones during a call, just press number keys or scroll to a number in the phonebook or recent calls lists and press Options > Send Tones
Dec 17, 2012 | Motorola Mobility W408g - Silver net10...
I am trying to put a new message on the after hours message bank, but it won t erase the old message. How do I erase the old message
Here's the simple answer. When you go to record a new message, it will play the old message and offer to let you record a new one. Your system consists of three key pieces, the phone, the KSU (key service unit) and the VOICE MAIL SYSTEM. Guess where the "message bank" is?
In our systems, we use Custom Service menus to play the greetings, but there can also be COMPANY greetings in front of the CS menu. In a TVA system, we use low numbers like 1 for day and 2 for night, only because it's a GUI to set up the menus. In a TVS system, we use 30 for day and 60 for night so the sub-menus have slots.
Try looking for the installation instructions to see if you can find the menu flowchart. In any case, the old message will play before you're given the option of changing it and you must confirm the change with a "2".
Carl
Mar 21, 2011 | Panasonic KX-T7630 Corded Phone
How do I turn off the key pad tone on the impression sgh-a877
The Sound Profile only covers call sounds.
Sound Profiles
This menu allows you to specify how you are informed of
incoming calls.
Selecting a Profile
1. Touch ➔ Settings ➔ Sound Profile.
2. Touch the radio button next to the profile name. The
selected profile activates. Choices include:
• Normal
• Silent
• Driving
• Outdoor
Normal Profile
The phone’s profile defaults to Normal. Use the following
procedures to change the profile.
Editing the Normal - Call Profile
1. Touch ➔ Settings ➔ Sound Profile ➔ Normal.
• Touch the name field and not the radio button to the right.
2. Touch drop-down menu (upper-right of the screen) and
select Call.
3. Select the Call Alert Type field and select one of the
following and touch Save:
• Melody: the phone rings using the ring melody selected in the Ring
tone menu.
• Vibration then Melody: the phone vibrates and then starts ringing.
• Vibration & Melody: the phone vibrates and plays a melody
simultaneously.
4. Touch the Voice Call Ringtone field, touch to select a
ringtone and touch Save.
5. Drag the Ringtone Volume slider to the volume level you
desire (range is 1-7).
6. Touch the Vibration Pattern field, then touch to select
Vibration 1 - 5.
7. Touch Save to return to the Sound Profiles menu.
There is no mention of keyboard tones in the user manual.
Mar 19, 2010 | Samsung SGH-A877 Impression Cell Phone
Won't generate tones from keys when connected
Any other phones on system with the problem?
DTMF or touch tones are generated through the trunk card(s) of the sytem problem. Chances are there may be more then one phone that has a problem.
Also on the outside of things, just try calling the same number from a different phone on the system, and if possible try using the trunk/line that you did with the m7208 in question, same problem? If yes possible trunk issue. If no, then try another phone where the problem set is plugged into.
Another thing you can try is call another service that uses a touch tone menu, using the phone in question, see if you have the same problem.
May 11, 2009 | NorStar M7208 Corded Phone
Can't change to pulse dialing
The Vetech phone will only support tone dialing. It does have a menu option that turns tone on or off but it still will not allow pulse dialing. I had to change the phone service from pulse dialing to tone dialing to get the phones to work. As it turned out, the phone company no longer charges extra for the tone service.
May 11, 2009 | Uniden Cordless Phone
I have a GE 21518 Bluetooth Telephone adapter. If
Caller ID is only sent to devices plugged directly into the "PHONE" jack on the back of the 21518. I'm guessing your TV DVR or Cable Box is connected directly to the real phone line. Maybe you need an RJ-11 splitter so you can plug both your phone AND the cable box in to the "PHONE" output of the 21518. I appologize if you've already tried this.
Mar 01, 2009 | GE Bluetooth In-ear Headset Wireless...
Rotary tone on GE 6.0 cordless phone won't turn off
From the Handset Setup Menu:
1. Press the caller ID-volume ( 5 or 6) button to scroll to the TONE PULSE sub-menu.
2. Press mute/program button to enter the menu. TONE/PULSE 41TONE 2PULSE shows in the display. The default setting is “1 TONE”.
3. Use the touch-tone pad or caller ID-volume ( 5 or 6) to enter 1 TONE or 2 PULSE.
4. Press the mute/program button to confirm. You will hear a confirmation tone and your selection shows in the display.
Feb 06, 2009 | Uniden Cordless Phone
Ge telphone and answering machine
Are all phones on your line having this issue? Is it a GE system with expandable (multiple) phone handsets? Make sure you have touchtone service with your local phone company. If you are getting a dial tone but can't break dial tone when you press a button; do you hear the touch tone? If so, it may be the phone comany line. Provide as much detail as possible such as were the phomes working at first but then stopped or never worked at all.
Aug 20, 2008 | Lands Phones
GE Bluetooth Telephone Adaptor
There is an undocumented solution to link difficult devices. Instead of pushing ad releasing, hold either button down until you get a FAST BLINK and then try linking again.
Jun 29, 2008 | GE Bluetooth In-ear Headset Wireless...
GE Bluetooth In-ear Headset Wireless Headset Logo
289 people viewed this question
Top GE Radio Communications Experts
eradiostore
eradiostore
J.D. Browning
J.D. Browning
Van Allen II
Van Allen II
Are you a GE Radio Communication Expert? Answer questions, earn points and help others
