Question about Honeywell Programmable Thermostat Heater
The blower heat is not working
No heat,blower not working
    Problem Solver:
  • 6 Answers
On what is it that the blower is not working?
Please explain more in detail
Posted on Jan 14, 2009
I have 2008 captiva... My ac blor is not working..
HVAC climate contol , Heat an A/C blower motor not working ! The blower motor works for both heat an A/C . Manual or automatic climate control ? Blower motor is bad or blower motor control module is . videos on youtube on testing blower motor electrical circuits .
Mar 26, 2017 | AC Cars & Trucks
The Front Heat / Ac Work's ! ! ! ...When It Wants TOO
there is a blower relay circuit board located right by the blower motor which sounds like your problem to me i've worked on several that had the same type problem and thats what it was. the two blower motor wires will plug into it and there are two screws that hold it on
Apr 23, 2014 | 1996 GMC Safari
2002 cavalier, heat but blower not running
you may have a bad blower motor or bad resitor
Jan 24, 2013 | 2002 Chevrolet Cavalier Coupe
Replaced Thermostat and now Blower Motor will not run
Sounds like a set up issue on the tstat. You say this is a packaged unit, inside the machine you should find where the tstat wires hook up. Typically red is power yellow is compressor orange is reversing valve white is emergency heat green is blower. Put red and green together, test blower. Then red green and yellow, make sure blower works again. If blower runs both ways it's either the tstat wire or tstat itself. Make sure you are landing wires on dedicated heat pump terminals, make sure in settings you are set up for heat pump with back up electric heat and TSTAT CONTROLS THE FAN. Good Luck. Also if there is a switch on the tstat for gas or electric on the back you want electric.
May 12, 2017 | Heating & Cooling
WERE IS MY HEAT BLOWER MOTOR LOCATED THE HEAT WILL
under the passenger side of the dash right above the passengers feet. With the key on and the blower set to high tap the end of the blower motor with a screwdriver. If it starts to work replace it.
Oct 05, 2010 | 2003 Ford Taurus
Heating broke
Was the blower making strange noises before it quit? If not, does the blower work at all? perhaps only on one speed? If it only works on one speed, look for the resistor that goes with the blower motor. I assume it will be near the blower itself, but can't tell you where. An auto parts store can probably tell you. If the blower was noisy and suddenly quit, you will likely need to replace the blower motor.
Feb 04, 2009 | 2000 Renault 181
No auto fan when heat is on.
check to see if the t-stat is set for gas or electric. should be on the back of t-stat
Jan 25, 2009 | Heating & Cooling
02' LIBERTY BLOWER MOTOTR COMES ON WHEN IT WANTS TO.
Sound like a weak blower motor to me
Dec 12, 2008 | Jeep 10 x 20
No heat...and only 2 out of 3 blower settings
the switches are bad. you need to replace the ac / heat / blower switches.
Oct 23, 2008 | 1999 Chevrolet Silverado 1500
Heating & Cooling Logo
61 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
