Question about Kenmore 63942 Dryer
Drum Spins - NO HEAT (110.63942101)
I'm new to fixya.com and an earlier posting may have been "lost". My problem is with a Kenmore electric dryer, model number 11063942101. The motor runs, the drum tumbles, there's 240vac at the terminal block. I've followed all the t-shooting suggestions that are on the tech sheet that came with the dryer. I've checked all the t-stats, centrifigal switch in the motor (I removed the motor, blew out the lint/dirt and manually ohmed out the switch by moving it in/out - worked ok), voltages, etc. I also did the on-board diagnostics test. At first I thought it may be the fabric care temp switch (5 pos) because when I tested the switch outside the unit, it appeared that the med and med-high positions didn't work. But during the diag test, it "beeped" with each click. Also when I checked it in circuit, the voltages appeared to be working when measured at the board (binary 0 - 4). The heating element reads 9.9 ohm, the exhaust thermistor reads correct for ambient temp. The only thing left is the pc board. I don't want to purchase a new board, if this isn't the problem and there are no schematics for it anywhere. Are there any other t-shooting suggestions to try? Is there a way to test the board? In addition, the heater relay is energized when the temp switch is set to anything but "no heat". There's 50vdc to the coil side and 240vac on the load side. I reseated all the connectors I could find. And while I had the machine torn apart, all the dirt/lint was vacuumed out. I also checked the timer switches and they appear to be correct. Any help/assistance is truely appreciated.
  • 1 more comment
  • Burt Howard Jun 14, 2007
    spurs21...thanks for trying. However since I had the proper resistance on the heater element of 9.9 ohms, that wasn't the problem (don't worry, I didn't buy the part). It turns out that after looking at the circuit again, and "breaking it down" into sections, the problem was not anything that is listed in the troubleshooting guides. It turned out that the heater relay was defective. Once swapped with the motor relay, the heating element begin to "glow". A quick trip to the local appliance parts place, $38 later, the dryer is back-up and running. Thanks again for responding and trying.
  • guitarman7 May 28, 2008
    no heat 110.60902990
  • clarinet1 Dec 29, 2008
    I have the same problem no heat, but I can get at the fuses/thermastat etc. to see which part needs replaceing. How do you remove the front panel?
  • 26 Answers
Try replacing the heating element. This should solve your heating problem. Sign, Spurs21
Posted on Jun 12, 2007
2 Suggested Answers
SOURCE: Dryer Runs, but NO Heat
The new dryer products clog up the fine mesh screen lint trap. Take it out each time and wash it with hot water until you can see the water run through. I learned this the hard way and paid for a service call.
Posted on Aug 19, 2007
Kenmore Elite Electric Dryer -- Diagnostic for electronic control "Start" touchpad is 09. What does it mean?
i donot know what 9is but i think its the moter switch or moter try switch first
Jul 19, 2013 | Kenmore Dryers
Kenmore model 110.63942101 (electric). everything works but no heat... drum spins, timer works. Should I buy heating element replacement kit? does it need to be installed from the back of the dryer...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 19, 2011 | Kenmore Dryers
Drum spins, but no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 10, 2010 | Kenmore Elite HE4 Electric Dryer
Drum spins but no heat?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 20, 2010 | Dryers
Drum rotates, dryer doesn't heat up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
heatman101
Jun 05, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer spins and drum turns, but only cold air c...
heatman101
May 20, 2010 | Kenmore 800 7982 Dryer
Kenmore Dryer 65512 won't heat
heatman101
May 14, 2010 | Kenmore 64742 Electric Dryer
Dryer will not heat. Just spins without igniting.
heatman101
May 11, 2010 | Kenmore 63942 Dryer
Kenmore electric dryer 8662100 drum turns, no heat
you have probably lost one leg of your power supply feed 120volts+120volts=240volts,your motor will operate on 120volts, but the element won't,also if you have 240volts the neutral wire to the element can burn off w/heat and age
Aug 18, 2009 | Kenmore 84152 Electric Dryer
Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Jun 28, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 63942 Dryer Logo
788 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
