Question about Kenmore Elite Oasis 27052 Top Load Washer
Cold h20 not going into tub, and LF light comes on when tub empty
Never used cold h20 before, and when I did, h20 did not fill tub. Used warm,cold...don't really know if cold works....upon spinning or rinsinging,don'tknow....LF light appears. thank u
  • 2 more comments
  • doredalleva Jan 14, 2009
    to djz83
    have to try it out first. have to wait till son gets home to help me. I will definitely let u know. Do u knnow where I can get a booklet that came w/this washer? thank u again
  • doredalleva Jan 17, 2009
    I want to do as u say, but my son won't help me get the washer away from the wall.I know u are right...and big kudos and bigger kudos to you....thank u so much...I'm 70 yrs.old and if I could do this myself, I would...thank u....
  • doredalleva Jan 19, 2009
    I finally got son to help me w//washer and it worked. thank u....but at end of wash I get a HC, and when I want to use only cold h20, i still get hot h20. So the next wash I will turn off hot h20 valve. pls. advise. thank u
  • sexysaphyre Feb 10, 2009
    what if it then shows 43 as the code that follows
    my email is sexysaphyrefly@yahoo .ca and where do i find this water valve screen...i hate sears the idiots ...they came to fix it this morning it originally says LD now it got 1/2 way thru the cycle and says LF THEN BLINKS NUMBER 43 i had a manual now i cant find it ...i will fix it myself
    New Friend:
  • 88 Answers
Is the cold water valve on if so your water valve screen is probably clogged . disconnect your hoses from the machine and clean out the sediment. LF is long fill the rinse is usually cold water .that you do not have. good luck let me know what you find.
Posted on Jan 14, 2009
Galbocca tub with jets
You have some bacteria build up on the inside of your tubing of the tub.
Try some cleaning solutions per directions on the bottle of tub cleaner made specifically for this situation.
Cleaning Solutions
US Parts Center
Aug 22, 2013 | Whirlpool Home
Letter LF appear where the time should read. The washer just beeps and does not finish the load
This is a long fill (LF) check the inlet hoses for the screens being clogged...if it takes longer than 10 minutes to fill ..it cuts off and shows LF ..check that either water valve is not turned off or almost turned off...also, alot of people just use cold...make sure the selector is set for cold/cold if using this cycle...another possible fault is the mixing valve is bad/or going bad..Either way consentrate on this and you'll find your solution
Bruce Denton
Nov 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does the code LF stand for? It keeps stopping half way through the wash cycle and flashes this code.
LF is for long fill.
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Check the following:
? Is water supply connected and turned on?
? Are hose screens plugged?
? Is water entering the tub?
If all these are good and water is going in fast (both hot and cold) you may need a service company to come out and take a look
Apr 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
LF Error
"LF" is a Long Fill error. If the fill time exceeds roughly 10 minutes, the fill valves are shut down and the error code is generated. If the error does not clear, or keeps reoccurring, it is recommended that you doublecheck to make sure your water taps are on all the way and check the hoses for kinks or clogs. If everything checks okay, check the screens on the fill valve for sediment build up. You may need to replace the valve.
Sep 22, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
My maytag neptune washer stop washing with 10 minutes left to go.
If your machine is a FAV6800AWW or FAV9800AWW the (upside down u and f) may be a “NF” for no fill error. The washer has tried to fill the machine with water and has sensed a water fill issue. The control board has shut the wash cycle down with an “NF” error to the display because of excess time to complete the water fill portion of the wash cycle.
Will the machine complete the cycle with Hot water only or Cold water only? I would do a Quick Wash cycle just to test with an empty wash basket.
Regardless of the above test and assuming you have good water pressure for both Hot and Cold supplies to the washer I would do the following. Close the water source valves to the washer and remove the Hot and Cold hose connections at the back of the machine and check for clogged inlet screens. If the water inlet screens are free of restrictions I would go into Service Mode and turn on the Hot and Cold water valves on one at a time and make sure the tub will fill with about 2 inches of water in about 3 minutes in service mode. Check both Hot and Cold inlet valves individually see page 16 of the SM Board Output Test, enter service mode and do the function test for both Hot and Cold Water Valve’s. If the inlet screens are clean and you have water fill restrictions in service mode we may need to look at replacing the water inlet valve assembly. You can turn on the drain pump in service mode to empty the tub or just start a wash cycle and the machine will empty the tub.
The Service Manual for reference. Sears Parts Direct for reference.
May 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer will start cycle then stop and LF starts blinking on the screen
LF means long fill. So the washer is taking too long to fill. Make sure your hoses are connected to the right spot on the water valve. (hot on hot and cold on cold). Also check that the taps are fully open. If this is good remove the hoses from the washer water valve and put the end into the washer tub. Turn on the hoses and check for good flow. They're good? Check the mesh filter in each inlet of the water valve. All clean? Replace your water valve. Good luck!
Apr 28, 2009 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
ERROR H20 STOPS PROGRAM DUE TO LIMITED WATER...WHAT CAN I DO?
The fact that you have 240V to the valve does not prove that the valve is o/k. Determine which is the live wire, and leave connected to valve coil.
You need to remove the neutral wire from the valve, and test with your meter that as well as having 240V going in, you have 240V coming out on the other terminal, if you have not , then you have a faulty valve..Simply replace it.
I assume that you have a neutral feed to the valve, because if you have not, then the fault is probably in the pcb board.
The coils on these valves often go open circuit.
Plz rate my solution.
Thanks.
Dec 22, 2008 | Hotpoint Ultima WF860 Front Load Washer
Water will not shut off, continues to fill
does the water run when you unplug the machine? if so then you have a bad fill valve,
Nov 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer
the h20 valve mixes the water even on cold setting. if you don't have water hooked up to the hot side then the water will come out at the valve. just cap the valve. you can get the cap at a hardware store just ask for a garden hose cap like you would use for a sprinkler hose.
May 10, 2008 | Washing Machines
LF Code
Why not just clean the screens to increase the fill pressure and spend not 1 cent on the repair.
May 08, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
194 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
