Question about D-Link Xtreme N DIR-655 Wireless Router
Connects at G not N
Both units N
    Genius:
  • 1,269 Answers
Your wireless adapter should be an N as well. If your adapter is N and it doesn't connect at N mode, try to set the router to Wide Channel range.
Posted on Jan 13, 2009
What boards are applicable on OSN 1500B?
List of cross-connect board Q2CXL1 1xSTM-1 SCC unit, cross-connect unit, timing unit, and line unit integrated board Q2CXL4 1xSTM-4 SCC unit, cross-connect unit, timing unit, and line unit integrated board Q2CXL16 1xSTM-16 SCC unit, cross-connect unit, timing unit, and line unit integrated board Q5CXLLN 1xSTM-16/STM-4/STM-1 SCC unit, cross-connect unit, timing unit, and line unit integrated board R1CXLLN 1xSTM-16/STM-4/STM-1 SCC unit, cross-connect unit, timing unit, and line unit integrated board R1PCXLN SCC unit, cross-connect unit, optical interface unit integrated board Search SCC
Jan 23, 2017 | Computers & Internet
Receiver shuts off when loud content comes on TV
Hello Jerry, This means that the unit is going into protection mode. The unit will only go into protection mode for 2 reasons. The first reason would be if there is a short within the unit itself. The second reason would be if one of the speaker connections is causing a short. To isolate which of the two is the issue, you would first turn the unit off and unplug all of the speakers. Turn the unit back on with no speakers connected and raise the volume up. If the unit turns off with no speakers connected then we know that the issue is internal and would have to go in for repair. If the unit stays on, that will tell us that one or more of the speaker connections was causing the issue. If that is the case I would check all of your speaker connections and possibly start with fresh copper connections. Thanks, FJD
Feb 24, 2016 | Onkyo TX-DS575 Receiver
No power at interior unit. power everywhere else
If this is a mini split ductless there is a control wire with 3-4 wires inside (normally red, white, blue and green) that is connected from the outdoor unit to the indoor unit. This wire feeds voltage from the o.d. unit to the I.d. unit. If all connections at the o.d. unit are good, then check for voltage at these connections at the o.d. unit. If no power at these connections then a circuit board has faulted. Call a tech. and have a tech support number ready (1-800#) in case your service tech don't have it.
May 12, 2015 | Sanyo KHS0971 9,000 BTU Ductless...
What is the pre out used for
PRE OUT/PWR IN - (1) Effects Loop - Connect PRE OUT to an effects device input, then connect the effects device output to PWR IN. (2) Multiple Amps - Connect the primary unit's PRE OUT to the auxiliary unit's PWR IN. The primary unit is used to control all auxiliary units. (3) Recording or Reinforcement - Connect PRE OUT to sound equipment's input. Both jacks use a TS (Tip-Sleeve) standard type plug for connections. PRE OUT includes onboard tone shaping.
Sep 22, 2013 | Fender Frontman 212R 100W 2x12 Guitar...
Trying to connect Sony wireless audio unit to tv using a jack lead,plugged into unit. And it began buzzing,connected to headphone socket on tv (as instructed)
since it was covered with warranty just return the unit to the supplier or ask them for assistance.by the way what unit have you been hooked up in the tv.
Aug 16, 2012 | Televison & Video
How to use drive and find serial number
HI. Connect power cable to unit and power source.
Connect USB to unit and connect to Computer. Turn on power.
Computer should auto matically load up unit and display on screen along with a menu and instruction for using.
Not to sure about serial number, would a have a close inspection in and around connections side of unit.
May 24, 2011 | Western Digital My Book Essential 1TB...
I have fax problem in my multi-function panasonic printer machine, all the power and rest functions are working other than fax, I am not getting the line dial tone when pressing monitor even the faxline is...
See Page 72 of the User Manual available here:
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Multifunction-Printers/How-To-Guides/model.KX-FLB801.H#ts
I cannot hear a dial tone.
The telephone line cord is connected to the [EXT] jack on the unit. Connect to the [LINE] jack (page 21).
L If you use a splitter/coupler to connect the unit, remove the splitter/coupler and connect the unit to the wall jack directly. If the unit operates properly, check the splitter/coupler.
L Disconnect the unit from the telephone line and connect a known working telephone. If the working telephone operates properly, contact our service personnel to have the unit repaired. If the
working telephone does not operate properly, contact your telephone company.
L The power cord or telephone line cord is not connected. Check the connections.
L If you connected the unit through a computer modem, connect the unit directly to a telephone line jack.
I cannot make calls. L The dialing mode setting may be wrong. Change the setting (feature #120 on page 22).
The unit does not ring. L The ringer volume is turned OFF. Adjust it (page 23).
Hope this is helpful. ;)
Dec 10, 2010 | Panasonic KX-FLB801 All-In-One Laser...
Error llama 7410 0013444 impresora kyocera ecosys fs-4000dn
Drum unit non- installing error
The drum unit is not installed or not
installed properly.
The drum PWB EEPROM does not communicate
normally.
Causes:
- The drum unit is not installed.
- Defective connection drum PWB (YC1) and connect-L PWB (YC3).
- Defective drum PWB EEPROM.
- Defective engine PWB.
Check procedures/corrective measures:
- Install the drum unit
- Check the connection of connectors drum
- Replace the drum unit
- Replace the engine PWB
Aug 04, 2010 | Kyocera FS-4000DN Laser Printer
Camcorder connect to Insignia dvd/vhs copier unit
connect to front press av input button. set it on av 2. make sure your tv input is set to v2-component.
Dec 24, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
D-Link Xtreme N  DIR-655 Wireless Router Logo
56 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
