Question about Sony KV-27S45 27" TV
Picture went out
Sony KV27S22 has been working great for nine years. All of a sudden this evening, the picture got distorted, and then went blank. Now, after shutting it off and turning it back on again, the picture comes back after normal warm up time, but then goes blank again within seconds. What the heck???? Thanks!
  • jjohns217 Oct 05, 2008
    The picure loos fine and then begins to move up the screen with line s running through the picture and then goes completely blank. After a few minutes if turned on again the same thing occurs.
  • 934 Answers
I can think of a few conditions that would fit that symptom, my guess would be problems in the vertical circuit which are somewhat common in that unit model. First I would test R561 0.47 Ohm for an open condition and test and/or replace IC541 with a TDA8172. IC541 is your vertical output. Another suspect would be vertical yoke windings. Maybe not short at the moment but could be shorting intermittently. You would have to have the windings ring tested to prove the theory. And lastly - depending on the distoritions I'd ring test the flyback transformer for intermittent short, sony p/n#1-453-268-11 and test the B+ (high voltage) as it comes up and at the point of failure. Any surging would be dispositive of a voltage regulation failure. Nine years is a good long time but there is no reason that this unit can't operate another 5-6 years. The repair diesn't sound too serious or extremely expensive for a reputable shop. If you need any help locating one you might try the NESDA web site: http://www.nesda.com/locator/state_search.php and I would take the unit to the shop rather than have them come and pick it up - even though it's so heavy- it will save some money. Sorry for the bad news, as a certified tech it's the one thing I least enjoy is giving bad news in a solution. Good Luck Bill
Posted on Jun 12, 2007
I have a Sony TV I bought the end of 2002 and it worked fine except for the last few years. The menu screen all of a sudden appears and i can't get it to go off until it feel like it. I have a universal remote, because my dog chewed the original, but it was doing it with that one.
Posted on Aug 22, 2009
SOURCE:
Sony trinitron KV-27V20 stopped working
Power supply regulator section should be checked in detail. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 640 posts to different brand TVs.
Aug 19, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hi. Sunday evening the picture on my Sony Bravia suddenly went very red and there are blurry lines after action. Type can hardly be read, even the TV menus are hard to read. The next day, hoping...
Hi. Sunday evening the picture on my Sony Bravia suddenly went very red and there are blurry lines after action. TypeHi. Sunday evening the picture on my Sony Bravia suddenly went very red
Aug 03, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Green screen and distorted picture sound is good but no picture
It must be connected with the color circuit of your tv, a board connected to back end of the tube. Could be dust, cob web or carbon deposit shorting a transistor. Popping noise if loud enough can be attributed to high voltage circuit fault and picture tube.
Have it service by a qualified person.
Apr 04, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Picture Greatly distorted all of a sudden by many yellow lines
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Jul 07, 2008 | Zenith D61W25 61" Rear Projection...
Pictures out of focus suddenly
Make sure the lens is clean and does not have greasy residue on it.
May 07, 2008 | Sony Cyber-shot DSC-H5 Digital Camera
My Sony DSC-W50 just started taking dark blurry pics...
same here. had my camera about a year and a half when this started
Mar 27, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Picture distorted and blurry with color
bad convergence amp ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Sony Trinitron: No Picture
It is likely the HOT (horizontal output transistor) and a couple of associated capacitors.
common failure.
the HOT is around 8.00 and some for the caps.
but almost no tv person works for less than 100. and provides a warranty. so you can expect 150. at least for a bill.
Jan 27, 2008 | Sony KV-27V22 TV
Burning smell and distorted picture
One of the components in the horizonatl deflection circuit went bad like a capacitor,the price will depend on the actual part that went bad and your location,the service call in NY could be 300.00 but in pittsburgh might only be 150.00.I still belive is wort repairing.
Oct 18, 2006 | Akai PT4799HD Rear Projection Television
Sony KV-27S45 27" TV Logo
242 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
