Question about Plantronics Audio™ 350 Headset
Microphone fuzz So I seem to have some kind of chronic headset microphone problem. No matter what amount of money I spend on headsets, they ALWAYS seem to be fuzzy on the other end when I use the mic. I don't (and can't) use USB ones, because all my USB ports are used up with various other things. Now, i KNOW it's possible to have clear mic sound because several of my friends have clear sound. I often have to repeat what I say because the fuzz is so bad. Anyway, currently I'm using a Plantronics Multimedia Stereo Headset (Audio 350) with Windows Vista as my OS. I've tried it with various programs like Ventrilo, MSN, built-in game voice chats, etc. and it's still always fuzzy. The sound in the headphones is great though... Could this be some kind of problem with settings? or am i pretty much just doomed to be out of luck with microphones forever?
  • 247 Answers
Try turning the microphone volume down in your sound settings - fuzziness is usually caused by trying to amplify the signal to a higher level than it can carry.
For your own piece of mind, you might also want to check your headset on someone else's machine - that will pretty quickly distinguish between a headset and a computer problem.
A.
Posted on Jan 13, 2009
I am new to skype and don't seem to have a microphone installed in my laptop...is that possible?
You can purchase an external mic. (if you are in a budget // cost is about $10)
I recommend you to spend few dollars more and get the USB type headset. ~$49
.Audio 476 DSP P/N: 81962-01
Link HERE for the Plantronics site.
This headset earned 4.5 / 5 star rating,
This is also Skype certified.
Aug 19, 2011 | Skype IM
I bought a samson se50 headset microphone to go with my GTD Audio wireless system. It has the correct adapter plug to plug in to the transmitter. The plug is a mini XLR plug. The microphone does not...
You need power from the transmitter to power this mic. See your mics specs to determine if it needs "Phantom Power"
Perhaps the transmitter doesn't supply power. Condenser mics may not work. Stay with the dynamic type. IMHO
Jul 29, 2010 | Nady Systems Nady ATM-75 Headset Mic w/...
My headset microphone not working
microphone is a miniature part of the headset....it is spoiled means it cant capture the audio signals and couldnt convert into electrical signals.....it need to be replaced....nothing can be done....
dont forget to rate me....
good luck.....
Apr 15, 2010 | GE (98980) Headset
Nokia 6070 stays in headset mode w/o headset pulled in
Try restoring factory settings which is in settings
Jul 09, 2009 | Nokia 6070 Cellular Phone
Is there a place for my mic to get fixed cheap???
if memory srves me right you can get a mic headset that plugs into the stereo headset jack thus solving the prob, google summit like or similar to mic headset for ds, it should help.
Mar 30, 2009 | Nintendo DS Lite
No sound from headset
MUTE THE SPAKER SOUND AND ADJUST THE SOUND SETTING FOR HEADSET
Jan 26, 2009 | Audio Players & Recorders
Dynex Stereo Headset w/ noise canceling mic: Headset Won't Work!
More than likely it just burned out or the battery is defective.
May 19, 2017 | Dynex Stereo Headset with Noise-Canceling...
No speaking ability
The mute button on these is the little black button on top of the earpiece. It will only be on if you turn it on during a call. If you turn the headset off, the mute button goes off as well.
Check the compaibility 'wheel' on the side of the base station. The most common setting is 1 but some phones use 2,3 & 4. Just try it on each setting until it works. Other than that, check the microphone volume adjust setting underneath the base (ABCD switch) and see if changing that makes a difference. Of course there is always a small chance that the microphone is dead.
Oct 31, 2008 | Plantronics CS50 Wireless Headset
Microphone not working
maybe its a problem with your sound card. Check your microphone settings in Windows.
Dec 11, 2007 | Altec Lansing Stereo Headset with...
Microphone
To figure out which of the 4 wires go where, you would need access/use of a continuity tester (ohmmeter). You have to wing it from the ohmmeter reading to distinguish the ground/common, left, right and mic. Please refer to the diagram below.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 15, 2007 | Radio Communications
Plantronics Audio™ 350 Headset Logo
1,124 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
