Question about Canon CLC 1110 Copier
E005 0200 Hi I have 2 canon 1110 copiers, right now I have an error code E005 0200 , doesnt let me go to the service mode either. From what I read on the web sounds like its a web cleaning issue. Dont have any clue what it is. The copier is in Richmond IN. Is there any expert assistance available over the phone for a fee?
  • Canon Expert
  • 1,326 Answers
That is the problem with your copier, you neeed to reset the error code in service mode. And You need to replace both of the cleaning web, the upper and lower web. Good Luck
Posted on Jan 14, 2009
I got an Error code (E000001-0101) for the Canon iRC4580 series. how do i fix it? need urgent answer
  1. you have to access service mode by pressing these buttons in order.
  2. additional functions
  3. 2 & 8 at the same time
  4. additional functions again (press reset and try again if screen doesn't change)
  5. screen changes to service mode
  6. press copier/function/clear/error then ok in the lower right corner
  7. turn machine off and on. If the fuser assembly is still good it will reset, if not it will need to be replaced (by a tech)
  8. DO NOT ATTEMPT TO DO ANYTHING ELSE IN SERVICE MODE!!! YOU CAN COMPLETELY DISABLE YOUR MACHINE!!!
Feb 18, 2015 | Canon Office Equipment & Supplies
What does the error code E000005-0000 mean?
This is a cleaning web end of life code. Replace the web and reset the counter in service mode. Press the additional function key, then the 2 & 8 at the same time, then the additional function key again. Press copier, counter, MISC, FIX-WEB, then OK. You might as well reset the WST-TNR setting as well. Check to make the waste toner bottle is empty - right side ,lower right of copier behind panel.
Nov 10, 2010 | Canon imageRUNNER 5570 Copier
Error code E000002-0000
try under service mode to clear error.
Press *
Press 2
Press 8
Press *
Choose COPIER
Choose FUNCTION
Choose CLEAR
Choose ERR
OK
Turn off and on.
If these doesnt helps, You need to change the fixing heater ( fixing film assy ).
Oct 05, 2010 | Canon imageRUNNER 2200
Ir 405 copier code as displayed e005. but what is problem i am changed web roller but still e005
Hi
Error E005 means the fuser cleaner roller has run out & may need a replacement. If the error is false it will disappear by following the reset procedure. To clear this error code press * 2 and 8 * in that 2&8 are pressed simultaneously. Go to the web counter and clear the counter back to Zero (0). Machine will now restart your machine & error code will disappear. If this doesn't help then try clearing both web counters in service mode, COUNTER>MISC>FIX-WEB> and COUNTER>DRBL-1>FIX-WEB> perform a Error Clear in service mode FUNCTION>CLEAR>ERR>. Hope this helps... Daniel
Sep 30, 2010 | Canon imageRUNNER 400S Copier
Canon clc1100 giving me e005 error. I didn't have a new cleaning web, so I just replaced the whole fuser. Still giving me the error code. I have read that I need to reset the counter. I can get into...
That must be nice to just replace the whole fuser.... You need to go to the counters & rest the web counter & i believe it is under misc. page and also, you will have to go under funcation & rest the error code, under clear (clr).... Good Luck
Sep 16, 2010 | Canon CLC 1110 Copier
Error code E00002-0081 in Canon IR3170C
you have fixing trouble, to be specific E002 Insufficient temperature rise of the fixing unit.
The non-contact thermistor fails to
reach standby temperature (normally
190 deg C) within 180 sec after reaching
180 deg C.
Try to clear the error by entering service mode:
press *
Press the 2 and 8 keys of the keypad at the same time.
press *
navigate trough service mode : COPIER>FUNCTION>CLEAR >ERR
If these doesnt helps, replace entire fixing assy, its most reliable way to get rid of complications.
Hope that helps!
Aug 19, 2010 | Canon imageRUNNER C3170U Color Copier
When i switch the main power button on, i get an error message on the screen with the code: E000003-0000
these is error code related to fixing heater temperature fault. Because you didnt state the model of copier ill gave you the procedure for most copiers of digital serie of Canon, these service mode procedure doesnt apply on iR 2016/2020/2018/2318/1600/2000....
press *
press 2
press 8
press *
select COPIER
select FUNCTION
select CLEAR
select ERR
OK
Turn off and on the copier.
If these doesnt clear your error you need nto change the fixing film assy ( heater ).
Hope that helps!
Aug 16, 2010 | Canon Office Equipment & Supplies
E00002-0000 error code
clear the error from the service mode
Oct 25, 2008 | Canon ImageRUNNER 3570 Copier/Printer
CANON GP 335 E005 problem
We have fiqured out that the cleaning web needs to be changed therefore we have successfully done this but the error code E005 still appears.
Oct 04, 2007 | Office Equipment & Supplies
Error code E005
if your machine is giving E-005 that means your fixing assembly (fuser cleaning web is not detecting) is bad.
go in service mode by pressing additional fuction + 2 & 8 + again press addtional function
If you find that the E005 code won't reset after replacing the Web, and clearing both web counters in service mode, <COPIER>COUNTER>MISC>FIX-WEB> and <COPIER>COUNTER>DRBL-1>FIX-WEB> perform a Error Clear in service mode <COPIER>FUNCTION>CLEAR>ERR>.
enjoy
Sep 28, 2007 | Canon imageRUNNER 400S Copier
Canon CLC 1110 Copier Logo
395 people viewed this question
old marine
old marine
