Question about Logitech Cordless Desktop EX110 Keyboard
Logitec mouse will not connect via bluetooth. I have gone through the process of pluging in the bluetooth usb adaptor run the the detection process and it still cannot find the mouse. It has been working but recently quit. Any suggestons would be appreciated.
  • Anonymous Feb 04, 2009
    My mouse has also stopped working. I've checked the bluetooth connection, and changed the batteries, but still not connection.
    Any suggestions
  • susie340 Feb 04, 2009
    I'm having the same problem. My mouse won't connect and I've gone through the process to connect and changed the batteries, no luck.
    Any suggestions
    Problem Solver:
  • 5 Answers
Get another mouse... retuen that one of you can... honestly- some tech that should work- may not sometimes- so it's better to buy a different one.
Posted on Jan 13, 2009
How do I sync the mouse up so I can use it?
'Synch the mouse up'? You mean connect via Bluetooth? They are either Bluetooth to Bluetooth or Bluetooth to USB dongle.
Blue to Blue. Switch on the device you are connecting to and enable Bluetooth. Switch the mouse on, when the device finds it, click Pair.
Mouse to computer or laptop. Remove the USB dongle from the recess in the underside of the mouse. Plug it into the computer or laptop, switch the mouse on. Plug and play will connect it automatically.
Apr 08, 2016 | Computers & Internet
Bluetooth adaptor disabled wireless internet connection
There are many things that can go wrong with a wireless connection, the main one is interference, many different objects and interfer with a wirless network, if you have a wireless g one then that takes away most of the possible interferences like the microwave, but bluetooth is a major interference, the only to ways of fixing this is to A. get rid of your bluetooth or B. replace your wireless g with a wireless g and n, g and n will ellimanate almost all interferences your current router can sell for a good amount(if you can prove its new and working i suggest you place it back in the box with manual and all) and by a g and n router how that works is it sends out 2 internet signals one g the other n and if one fails like your g then the n will kick in and run most of the internet but again you would have to get a new g and n router and get new wireless g and n software...or you could just not use your bluetooth.
Jan 04, 2010 | Linksys Wireless-G Broadband Router
Just got the bluetooth keyboard and mouse w/ no manual. how do i set it up?m/s bluetooth keyboard WBR0295 X08-92475 product ID 69418-545-205333 5-00321 and m/s bluetooth mouse p/n X08 - 87659...
Hi.
Before starting, make sure the keyboard and mouse are ON and with batteries.
Whit the PC already ON:
* The first step is to plug in the USB Bluetooth adaptor.
* Once the Bluetooth adaptor is inserted, allow Windows to install the drivers.
* Once Windows gives it the OK, the USB dongle should have a light or even a button. (If you don’t see a button the "yellow" light is the button).
* Press the USB dongle button....this will tell the dongle to start looking for a Keyboard or mouse.
* On the underside of the mouse (and keyboard) should be a a small button.
* Press the button(s) for ~5 seconds, then release.. this tells teh keyboard (or mouse) to look for a dongle.
This should show a connection between the dongle and the keyboard (or mouse).
Or
With the PC Off:
* Just connect the dongle
* Do the button sequence as described above, unit the dongle light goes “solid” again.
* Start the PC and keyboard and mouse should work perfectly.
Cheers,
Ed
Oct 24, 2009 | Microsoft Windows XP Professional
Wirless adaptor only sporadically working
Do you know for sure that the usb port is working properly? Plug in a flash drive or a mouse and see if it's detected. If not, it's the usb port. Try another port. If no usb ports work, post a comment and I'll give you some things to check.
If the usb port works:
Unplug the nic, go to device manager and expand network adapters. Plug in the usb nic. If it doesn't show up in device manager, or if no new hardware is detected, then it's probably dead. Plug it into another pc to confirm.
Hope this helps!
Aug 26, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
VX Revolution Cordless Mouse for Notebooks dead as a door nail...
I see no reason that the mouse should not work. They have the Xop driver and the install software. Download both and also read henote that they are talking about in. red. I didn not download it myself. If this doesn't work you can get a common PS 2 mouse for a small amount  most anywhere including Walmart.
http://www.logitech.com/index.cfm/428/165&cl=us,en?softwareid=4338&osid=1
Dec 30, 2008 | Logitech Cordless Mouse
External mouse freezes when using firefox
Hi Albert
Thanks for the info' Strange one this. Applications such as FixFox do not have any real connection with external devices.
Other than the obvious things such as check the battery in the mouse (you can check that in the mouse/bluetooth settings). Re-pair the mouse and the mac in your bluetooth settings.
You are getting the same problem when you send files via bluetooth. But when you use your track pad it's OK. If you are transfering files via bluetooth htere is a good chance your wireless would be interupted. That would say to me the fault more than likely is communication issue.
I have a couple of wireless mice. A mighty mouse and one that transmits via the usb. I must say the later is quite erratic. The mighty mouse is great. Not that I'm trying to promote apple products.
Before you go to the exspence of getting your bluetooth checked out or getting a new mouse. If you have another machine PC or mac you can plug the mouse into to try and recreate the problem would be good.
Did your mouse come with any mac software? The pairing can be quite tricky.
Sorry I cannot be more helpful.
Paul
Sep 04, 2008 | Apple MacBook Pro Notebook
Wireless keyboard & mouse not working
First download and run regscrub xp and ccleaner to clean up your system then try uninstalling and reinstalling the logitech setpoint software and try the keyboard and mouse again. Let me know if this works.
Oct 23, 2007 | Logitech Wireless Access Duo Optical...
Mouse not functioning
You should have a USB adapter that goes from the Charging base to your computer to make the connection. the wireless is from the base (charging unit) to the mouse.  once you connect your USB it should find the mouse and work. you may need to sync the base unit and mouse to complete the process, by first click the sync button on the base unit then the small sync button found on the bottom of the mouse
Oct 12, 2007 | Logitech MX700 CORDLESS OPTICAL MOUSE...
Logitec Wireless keyboard and mouse
essense702,
I presume the batteries were in correctly.
did you connect them when the computer was off, and let windows find them on bootup.
Also, make sure that you follow directions on how to get them to connect. And, make sure you run the cd that came with it.
Oct 11, 2007 | Logitech Wireless Access Duo Optical...
3com usb bluetooth adaptor wont work at all
The Bluetooth adapter should be able to be used with Win XP's own drivers, try uninstalling the drivers that you got with the adapter and dis connect it. Re-connect your adapter back in and right click on an item you want to send via bluetooth and it will say 'send to bluetooth device'. Please note this will only work with Win XP SP2 not SP1
Nov 16, 2006 | 3Com AirConnect Wireless Adapter
Computers & Internet Logo
76 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
