Question about EliteGroup L7VMM2 Motherboard
Pc doesn't work - one long beep - l7vmm2
I'm with a pc here but it's not working.
When I try to power it, I just have a long beep and nothing shows in the monitor.
How can I try to fix it?
The Mb is l7vmm210
Sorry for the bad English, I'm Brazilian.
Xoxo
Gabii
  • gaby_fr25 Jan 14, 2009
    I'm trying to fix this computer, it isn't mine at all.
    It got 2 memories but I had already tried with both and none of them work.
    I've already tried everything, I'm gonna check these memories in a friend pc now (I don't have ddr 1 slot), but I guess the problem is in the MB. And them, there's no way t solve it.
    Thanks for the solutions
    I really apreciate them
  • DELSLATE Mar 11, 2009
    SAME PROB 1 LONG POST BEEP. FOUND 1 LOOSE RAM SHUT DOWN COMPUTER THEN GOT POST BEEP WHEN RESTARTED.CHECKED ALL CONECTIONS AND TRIED OTHER RAM TO SAME RESULT
    President:
  • 2,351 Answers
Hi gaby_fr25,
Try this, remove your memory & reseat it. (Clean the memory contacts with alcohol, let it dry before replacing & do not touch the contacts with your fingers at any time). (Blow the memory slots out with canned air, if you have some).
Boot the system & listen for the "long beep". If the long beep does not go away than do the same to your video card. (If your using an AGP add in card).
If the long beep continues & If you have more than one stick of memory, remove DIMM 2, (Memory slot farthest from the CPU).
Check for "long beep". Still there? Switch memory sticks. Remove DIMM one, (Closest slot to the CPU) & replace. Check for "long beep".
If nothing above has stopped the "long beep", post here & we'll try another option.
Good luck gaby_fr25!
Thank you for using fixya.
Mike
Posted on Jan 13, 2009
  • Mike Peluso
    Mike Peluso Jan 14, 2009
    As I mentioned I have other means for you to try. (Though I understand you want to try your memory in a second PC). That will help determine if the memory is bad or the MB is bad.
    The objective is to gain display. Since you have already tried reseating the memory & AGP card, lets move to some other checks. I need to know if anything else in the system turns on. Does the CPU fan spin up? Can you tell if the hard disk drive spins up? Is there a green led light lit on the MB?
    The green led on the MB means the MB is receiving power through the 20-pin main connector.
    Check the 3-pin power connector for the CPU fan. Lastly, clear the cmos/bios jumper. Look in the manual to pages 5 & 6. Clear the bios (Wait 10 seconds & move the jumper back to normal).
    If you do not have the manual you can download it from EliteGroup at this link;
    http://www.ecsusa.com/ECSWebSite/Product...
    You will need Adobe reader to view the manual. Go to Adobe & download from this link;
    Waiting on your answers, let me know is the memory works in the second PC.
    Mike
  • 53 Answers
Hi Gabii,
Your motherboard is running on a Award BIOS, the beep code should be beeping not stop until you switch off the power.
You may need to try a few steps here,
1. Switch of you pc and open up you pc cover.
2 . Pull out the memory (RAM) from the slot by pressing down the clips from each edge, be gentle will you push down the clips from each side. Remember how it was seated when u pull out.
3. After that, put re-seat back the RAM back to the slot by pressing each edges in, firmly but not with excessive power.
4. Try to switch on the pc after you re-seated the RAM. If no success, you hv to repeat the procedure again, but this time clean the RAM's contact with a cloth and contact cleaner, then re-seat it back and try again.
*here's the instruction with diagram to show you how to do it.
and video as well
5. If still no sign of success, you might have to unplug other cards, such as your video card, and re-seat them back, then try again.
Good luck mate, comment here to let me know the progress or any success.
Do remember to rate my solution.. thanks (^_^)
    President:
  • 1,179 Answers
It is either bad or improperly seated RAM or a bad or improperly seated graphics card. Try reseating those components & reboot. Hope this helps.
Acer aspire not working
You can try to open your computer then remove the RAM then use a pencil with eraser to clean the gold teeth and then put the RAM back and test it out.
Dec 31, 2012 | Computers & Internet
Ive tried to install a new graphics card in my lenovo thinkcentre pc but nothing shows on the display
Make sure your power supply is big enough and you have plugged everything in. Some video cards require power directly from the power supply with a special 4 plug cable. You can get adapters if your power supply doesn't have the right plug.
Sep 19, 2012 | Lenovo ThinkCentre A30 PC Desktop
How to fix a laptop that doesn't turn on but beeps 1 long beep and 3short beeps
This POST cade is related to RAM problem
one beep, three short beeps
three short beeps, one beep
  • Memory problem: bad DIMM or bad DIMM slot
Try reseating the RAM, if this does not work then remove the RAM module and take it to your friendly computer repair shop and get them to test the RAM for you.
May 12, 2012 | HP Pavilion ze2000 Notebook
Computer just beeps.... will not boot up.... nothing shows up on the monitor
Test your PSU or replace it
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
good luck
Aug 26, 2010 | EliteGroup L7VMM2 Motherboard
ECS L7VMM2 Rev 1.0a motherboard I keep getting 1sec beep
did your new montior come with driver disk ?
if not look for the maker online and see if you can find the drivers for it ..
Jul 12, 2009 | EliteGroup L7VMM2 (L7VMM2 NO CARD READER)...
L7VMM2 wont boot (no post) plz help
Sounds like the CMOS battery on the motherboard needs replacing...i would try clearing CMOS first, replace battery and test voltage at the CPU (through the BIOS) If that dosen't help you likely have faulty capacitors.
If you get it to boot, im sure drivers and BIOS will need updates if it's been stored 2 yrs.
Jun 01, 2009 | EliteGroup L7VMM2 Motherboard
Pc has power but nothing shows on screen. motherboard doesnt beep once like it used to when turned on but green light is on indicating its ok.
dear,
Remove the ram and check, is the motherboard beeps or not..
it should beep as long beeps....and should continue beeping after serveral times until u switch off it...
then reconnect the ram after swiching off power...
remove the data cables of hdd and cd/dvd and then try to switch it on...
if it works fine then reconnect it properly...
Fault can be in Ram or data cables perhaps...
regards,
hope it will fix the issue so dont forget to rate it...
Apr 20, 2009 | Computers & Internet
I have power but no video
Do you get the boot up screen when you power the computer on? If you can get into the BIOS, make sure your primary video is set for the onboard. Hope this helps.
Dec 05, 2008 | EliteGroup L7VMM2 (L7VMM2 NO CARD READER)...
Power Supply for L7VMM2
well,if you are sure that the new power supply is new and ok,than more than sure,if you dont have any response from the mainboard,that it is damaged by the high tension who allready burned your initial power supply.
I suggest you to visit a specialised service because for now its nothing you can do more.but first be sure you have a quite functional new power supply.
bye
Feb 05, 2008 | EliteGroup L7VMM2 Motherboard
EliteGroup L7VMM2 Motherboard Logo
767 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
