Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Replacing wash plate
Model wtw660sbt. I have the new wash plate. How do I remove the old wash plate?
Thanks.
Hate to iron.
  • teamtderbe Jan 19, 2009
    Thanks for the reply. The screw is soooo tight that I want to be sure I am unscrewing in the right direction. Is it the usual -- righty-tighty/ lefty-loosey?
    Thanks.
    New Friend:
  • 88 Answers
You just have to take the cap off the center of the wash plate it pops off. then remove the screw in the center. Good luck.
Posted on Jan 14, 2009
  • Dean Rhymer
    Dean Rhymer Jan 20, 2009
    yeah thats how I remember it.
How to change the cord of the iron ?
Remove the back plate where the cord attaches to the iron... there are 4 screws visible and another 2 screws hidden under the two rubber feet...These are joined together by a rubber strip and can be removed by prying up and out with a small pry.... once the cover is removed you will see where to take the old cord off and replace it with a new one..
May 23, 2010 | Euro-Pro Shark GI490 Iron
Iron leaking and plate dirty
If you have hard water, there will be a buildup of minerals where the rubber gasket on the water tank meets the steam chamber that is built into the sole plate. This will make the rubber gasket surface become hard and no longer seak to the team chamber, resulting in water leaking from the tank onto the outside of the iron.
If you are reasonably skilled with tools and have a Torx T20 driver, you can disassemble the iron and remove the rubber gasket between the tank and the steam chamber and soak it in vinegar to remove the mineral scale. First remove the three Torx screws visible at the rear of the iron and gently pry off the gray rear cover plate. This will expose two screws holding the rear end of the sole plate. Remove those two screws. Then gently pry off the stainless steel nose piece on the front of the iron; this is the curved piece that says "high precision" on it. This will then expose the screw that holds the front of the sole plate on the handle. Remove thqt screw. Pull the black connector at the rear of the iron off the two rods to which it is attached, and you can move the sole plate away from the handle. The rubber piece in the handle that is sort of oval shaped and about 2 inches long is the gasket that is probably causing the leak. Gently remove it and soak it in vinegar to remove the scale, and remove the scle from the round hole where it meets the steam chamber in the sole plate. .When they are clean, reassemble the gasket onto the handle and the sole plate onto the handle, connecting the electrical connections, and replace the screws, It is not simple, but it is doable.
Apr 14, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Sticky substance on iron plate
get some of the Rowenta remover, YOu put it on your sole plate when Iron is warm. I use an old facecloth, put some on the cloth, then drag the iron side ways or back and forth. Then a clean towel to clean, when it does nto remove, i put some directly on the iron, does a pretty great job.. keep up with the stuff. If you are using fusible things when you Iron, you set yourself up with sggrivation, but a teflon cloth from a quilt store or on line,.It is used for applique and works great.
Jan 12, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Need to clean the plate
Limescale remover, like CLR or Limeaway, or whatever they sell at the hardware store.
Sep 15, 2009 | Euro-Pro Shark Rapido Electronic Iron -...
Removing deposits on iron plate
Try adding some CLR to the iron, fill it up with water, and run self clean. Then wipe bottom of iron with an old towel. Repeat with clean water in the iron, to rinse out the CLR and minerals.
Jun 21, 2009 | Rowenta Power Duo Iron
Iron puts out water which stains clothes. Steam is not dependable
Replace your iron. You can try cleaning the old one with either white or the stronger pickling vinegar, but for all the trouble that will be it is easier to just replace your iron. If future use ONLY distilled water, bought at any supermarket or water store, in your new iron.
Mar 27, 2009 | Rowenta Irons
Repalcement plates for Model 270A Toastmaster Waffle Iron?
There is no way you can get replacement plates for you Toastmaster cheaper than you can buy a new one, the most expensive Toastmaster waffle maker I found was $30. the cheapest was $15 shipping will be at least half of that.
Feb 09, 2009 | Toastmaster 287 Waffle Maker
Euro-pro EP1005 iron--iron heats -blower works-but no steam
You may not need a new iron, my wife's iron is doing the same thing. take the top of the ironing board off (you will need a torx t-20 security bit driver), under the tank is a connection that may have rusted out re-connet it and turn the iron on. Once it heats up, check the tank for leaks. The tank may need to be replace as well or try a 5-minute epoxy type glue on the leaks once it has cooled. If the tank leaks you will get not get enlugh pressure building up to get the steam.
Feb 05, 2009 | Euro-Pro EP1005 Iron
Maytag PAVT454EWW pump 21002240
Don't worry about it, you can install the new pump with out the plate. It will work just fine. They must of redesigned it. I get them this way all the time, Catriver
Sep 22, 2008 | Maytag Performa PAV2200
Rowenta Iron
Special screw called "Torx tamper proof" call 925 8271011 and order "Rowenta tool" $10.00 plus shipping-this place also sells Rowenta parts
Apr 09, 2007 | Rowenta Professional DX8800 Iron
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
402 people viewed this question
Dan Webster
Dan Webster
Sal De
