Question about Philips Magnavox Learning Universal Remote
Can't find original remote for Philips Projection TV mdl 55PP9401
They have new replacements at some places, but none of them have the one important button to the function I need access to.
These TVs have a thing called ''Auto IntelliSense Focus'', which realigns the convergence if it gets out of whack. I just had to replace my two convergence chips, and now the three color tubes are not overlapping correctly so the picture is triple image. Normally you just push the IntelliSense button on the remote, and it automatically aligns everything correctly in about 15 seconds or less. Well I am the second owner of this TV and did not get a remote with it. I have been searching high and low for hours today and no one has an original, anywhere I've checked.
The TV was actually made by Hitachi, even though it's sold by Philips in a Philips cabinet.
I need to know (preferably) where I can find a new old stock, or even a used original remote for this 2001 model TV. The new replacements won't work. I don't understand why Philips bothered to make a new replacement remote for this set, but didn't include such an obviously important feature...????
Is there any chance that there is a Hitachi remote that has this IntelliSense button I need? Is there any other way to access this fuction and properly, automatically align the three color tubes?
From what I have determined in my searches, from talking to people who actually had this model TV, the convergence chips going bad was a common problem. It sure seems to me that there should be a bunch of them sitting around in repair shops for parts and having remotes just gathering dust. Why can't I find one anywhere? I have even checked ebay and Amazon, as well as used remote dealers online.
The model number of the TV is 55PP9401.
Model # of remote is RC201601
Part # 312814713082
Any help with this would be greatly appreciated.
Thank you.
Shannon
  • highrground1 Jan 16, 2009
    I will try that as soon as I get my TV repairman guy back over here with his remote.
    Thanks
  • Whiffr Feb 10, 2009
    I am also having the same problem. You can access the IntelliSense from the front panel but it takes the remote to start the IntelliSense operation. I called Phillips and the tech told he I was correct, I need the remote or one of those real expensive universal remotes. I still need a remote and it is not available from Phillips anymore.
There is an IntelliSense option on the on screen menu which can be accessed from the front of the set. However, when you execute that menu option, it tell you to press the IntelliSense button on the remote. I think what is needed is a way to program this function into a programmable remote.
Posted on Dec 03, 2009
    Problem Solver:
  • 37 Answers
If the Menu is legible on screen IntelliSense is available under the Picture tab within the TV's internal menu. You may be able to do it "blindly" by following the user guide available at http://www.p4c.philips.com/files/5/55pp9401/55pp9401_dfu_aen.pdf
Posted on Jan 13, 2009
  • Jordan Jan 16, 2009
    You may be able to navigate the Menu without the remote by using the buttons located on the TV itself. May save you a repair bill.
We no longer have the remote for model 55pp9401 and we have a convergence problem what can we do
Here's the Philips support URL for your TV:
www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=55PP9401&slg=en&scy=US
PDF download of your Owners' manual:
http://download.p4c.philips.com/files/5/55pp9401/55pp9401_dfu_aen.pdf
Here's what Philips FAQ says about your convergence procedure:
Question How do I adjust convergence (align colors)? Answer Note: For best results, the Projection TV needs to be turned on for 15 minutes or longer before adjusting the picture tubes (convergence).
Press the INTELLISENSE button on the remote (under the flap). During the convergence process DO NOT press the INTELLISENSE button again and DO NOT move the Projection TV.
So, I think you're going to need to order a replacement remote.
search "replacement remote" at http://www.philips.com
May 13, 2011 | Philips 55PP9401 55" Rear Projection...
Don't have remote is there another way to line up colors I've already changed the convergence chips but not the resistors
Chances are the new ICs have failed since the 6.8 ohm resistors werent changed a phillips will almost always blow one or two of the 6.8 ohm resistors and if new ICs are installed without replaceing the resistors the new ICs are usually destroyed by the blown resistors. You will need the original remote or authorized replacement to adjust the convergence properly.
May 06, 2011 | Philips 55PP9401 55" Rear Projection...
Need to align without remote is this possible?
To do ANY adjustments, convergence or the others you need a working original remote.
I am sure it is available. Confirm actual complete model number and I will try to get you part number and cost.
SD TECH
May 21, 2010 | Philips 55PP9401 55" Rear Projection...
Intellisense button
If the model number on the set is 55PP9401/55 you have an interesting set----this model says Philips but was made by Hitachi---they made them for Philips for one year while Philips was gearing up to produce their own sets---very good set and is better than the Philips sets that came after it.
It uses (if it is this model) two STK-392-110 CONVERGENCE IC's----both need to be replaced and the set adjusted---no need for an original remote---with the set engaged in the convergence adjustment mode( there is a micro switch on the front of the main circuit board) A HITACHI REMOTE CAN THEN BE USED TO ADJUST THE CONVERGENCE. Hope this was helpful.
Aug 11, 2009 | Philips 55PP9401 55" Rear Projection...
Magnavox energy saver projection tv-cannot remove closed caption
If you can bring up the FEATURES menu and can navigate with the Harmony remote scroll down the the CAPTIONS options. If you can turn display OFF then you should be all set.
If you do not have the manual for this set you can see it at:
Feb 27, 2009 | Philips 55PP9401 55" Rear Projection...
Lost remote / convergance problem
u can not set the convergence without the remote control just look on the web they are between 30 and 60.00 dollars
Oct 07, 2008 | Philips 55PP9401 55" Rear Projection...
Where can i buy remote control for phillips 55pp9401?
get a full universal at your local walmart for less then 20 with full menu and program functions, get a phillips brand and no programming required.
Mar 16, 2008 | Philips 55PP9401 55" Rear Projection...
Philips 55PP9401 55 in. Rear Projection
First, repair convergence problem = replace both convergence
IC's ....STK392-110 sub to upgrade STK394-160E....I use
Hitachi part # CZ 01341.......next, look for discolored resistor
near IC's.....replace with exact value......last = activate
Auto-Intellisense.....................T.
Sep 25, 2007 | Philips 55PP9401 55" Rear Projection...
Philips 55PP9401 no sound no picture
When Replacing the (STK'S Power Pak) for this set you must use OEM parts. After market I.C. will not work!!! They will give you problems like you are discribing. D,TV
Dec 14, 2006 | Philips 55PP9401 55" Rear Projection...
Philips Magnavox Learning Universal Remote Logo
499 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
