Question about Panasonic KX-T7633 Corded Phone
"LINE NOT ASSIGNED" appears on one of my 5 lines.
I tried to program the phone for a "one touch dialing" number, and I must have hit a wrong button because I can no longer use one of my 5 telephone lines in the phone. I get "LINE NOT ASSIGNED" when I try to use that line, and I cannot receive incoming calls on that line.
  • anesheiwat Jan 19, 2009
    I am at the reception desk and I am unable to see if anyone within the office are using their individual extensions. How do I resolve this?
  • 84 Answers
SOURCE: telephone connection problem with DSL
unplug everthing from all jacks in the house. call your # a couple of times. if the line rings, plug everything in 1 at a time, but call again after each hook up. if the line goes dead or is busy, that phone you just plugged in is the problem. [ a short in the phone, computer, answer machine, or any piece of equipment plugged into the phone line.] if the line is busy when everything is unplugged, call your phone company. there maybe a problem with your inside wire.there also maybe a box [called a nid] inside your basment/garage or on the side of your house, where you can plug your phone directly in, bypassing all the jacks in your house
hope this helps.
wg
Posted on Feb 13, 2008
cnavarro
  • 2460 Answers
SOURCE: Speed Dialing
Press PROG press a speed dial button (ie 13-24) dial 9 plus the number press STORE
Carl
Posted on Oct 08, 2008
cnavarro
  • 2460 Answers
SOURCE: KX-T7731 messed up the co button
Remember that PROG 13 you pressed? First, press PROG and touch CO-1's button and make sure it still say CO-1. If not, dial 01 STORE and it will become CO-1 again.
Now, pick up the handset and hang it up so you clear the phone and press PROG 13 1 STORE PROG
Easy when you have the manual :-)
Carl
cnavarro
  • 2460 Answers
SOURCE: I HAVE STILL GOT ALL THE SPEED DIAL NUMBERS IN MY
If your 773x phone is connected to most Panasonic systems, you can press PROGRAM and the place where lines are supposed to be assigned and it will tell you what's under the button with names like CO1, CO2, CO3 etc.
If it says something else, you can make it become outside line access buttons by the command 0+a number 1,2,3 and STORE.
You can do all 3 buttons at once, just keep pressing them and dialing the sequence with a STORE. After you've finished, just pick up the handset and drop it back down to end programming.
Carl
Posted on Apr 26, 2009
carlsbiz
  • 1124 Answers
SOURCE: Can receive calls but cannot dial out on Verizon landline phone
Try punching in the number to call first THEN hit talk.. It should dial and call at that point..
Just like when making a call from your cell phn - dial the # first..
good luck ;o)
Posted on Sep 17, 2009
Phone not ringing in normal mode
I believe this is a programming issue.
To change the ringing assignments on extensions enter programming mode by pressing Feature **266344 and password 266344 if it hasn't been changed. You have to do this from an M7310 phone. The top two buttons on each side will move you through programming. The top right button is the SHOW button and the button below it is the NEXT button. The top left button is the HEADER button and the button below it is the BACK button.
Your first category should be TERMINALS & SETS. Press the SHOW button and using the dial pad enter the extension number. The display should show the extension number or name. Press SHOW three times and the display should show LINE ___.
With options to SCAN or LIST. Pressing SCAN will show the lines assigned to the extension. Use the CHNG option to change how the line is on the phone. RING ONLY - UNASSIGNED - APPEAR ONLY - AND APPEAR & RING. Change the lines you want to ring in NORMAL DAY MODE to APPEAR & RING for this extension and press SCAN to move to the next assigned line. Use this same method for any extension you want to change the ringing on.
Dec 18, 2013 | NorStar M7310 Corded Phone
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    My KXT7433. I have assigned a ext number to one of oue in coming lines, so when it rings i acnnot pick that line up. How do i earse this ext number
    From the idle phone press PROGRAM 99 and the button you messed up. Line numbers are programmed with a 0 in front of it, so if it was line 5 you dial 005 and STORE. Back to a line button :-)
    Carl
    May 26, 2011 | Panasonic KX-T7433B Corded Phone
    I have a PANASONIC KX-DT333 with several handsets. On all handsets we cannot dial out . The message LINE NOT ASSIGNED comes up on all handsets.Also we have had no incoming calls. Callers are all getting a...
    I don't know about a handset, since mine doesn't have a dial, but the phone underneath the handset has to have a button programmed with the lines you use in order to work. By default, the system has some number of Single CO buttons assigned in numerical order from the bottom to the top and left to right. You can test that by pressing PROGRAM, press the line buttons in sequence, and reading the display. They will say CO 001, 002, 003 etc. If they don't, you can always dial 0 001 store, 0 002 store etc and get the line appearance back.
    This solution works in a small system and is very basic. It doesn't take a T1/E1/PRI or group CO buttons. into consideration. Such a solution is beyond the scope of a free forum.
    Carl
    Mar 13, 2011 | Panasonic KX-T7633 Corded Phone
    How do I program a phone number to the one touch buttons on a Panasonic KX-T7730 phone?
    It depends on what you get when you dial "9" on the intercom. If you get an outside line, then the 12 right side buttons on your phone can be programmed for one touch dialing like this:
    On an idle phone, press PROGRAM a button and dial 9 plus the number and STORE. You can program more than one button by just pressing button numbers and STORE. Exit programming by picking up the handset and dropping it back down.
    If you want a specific line, you may be able to dial the specific 8x code to access a line directly, or you can go into system programming and delete the open lines in program 400. Disabling would be the best, because if your 8x line is busy, you can't make the call with the auto dial button.
    Carl
    Mar 08, 2011 | Panasonic KX-T7730 Corded Phone
    How do i make a light light up on a phone
    Each button is assigned by programming. It also has to have a light to light up :-)
    If you're programming an extension, then press PROGRAM 99 the button and dial 1 plus the extension number. If a line, dial 0 plus the line number. All programs are ended with STORE.
    Works for me.
    Carl
    Oct 07, 2009 | Panasonic KX T7436 Corded Phone KX-T7436
    Automated Attendant not on everyone line
    The below texts should help you.
    **Found on page 9-8 of "Partner R6 Install and Upgrade Manual" so your system may vary slightly:
    Use Line Assignment (#301) to assign all the lines that you want the auto attendant to cover
    to extension X.
    **Found on page 4-47 of "Partner R6 Install and Upgrade Manual" so your system may vary slightly:
    To assign lines to a specific extension:
    1. Press [Feature] [0] [0] [System Program] [System Program] [#] [3] [0] [1] at extension 10 or 11.
    2. Enter the extension number to be programmed. For example, to program extension 15, press [1] [5]. The red light next to each button that has a line assigned is on steady; the red light next
    to each button that has a pool assigned flashes.
    3. To remove all existing line assignments, press [Remove] before selecting a line.
    4. Enter the line number to be assigned. For example, to select line 1, press [0] [1].
    5. Do one of the following:
    ■ If you want to assign the line to the first available button with lights, press [Next Data] until the
    display reads:
    Line Assignment 15 L01
    1 Assigned
    1 Assigned is the factory setting.
    ■ If you want to remove a line assignment, press [Next Data] until a display like the following
    appears:
    2 Not Assigned
    ■ If you want to assign the line to a specific button, press 3. A display like the following
    appears:
    3 Select a Button
    Then press a button with lights to assign the line to that button. If you use option 3 after a
    line already has been assigned, the line moves from the old button to the new button you
    select.
    6. Do one of the following:
    ■ To program another line for this extension, press [Next Item] or [Prev Item] until the line number
    appears on the display. Then repeat Step 5.
    ■ To program another extension, press N P and begin at Step 2.
    7. Select another procedure, or exit programming mode.
    Feb 05, 2009 | Avaya Corded Phone avaparp18d
    NorStar T7316E Corded Phone Manual
    1 you can but it must be done via log on to switch with lap top (you may use handset but very tricky)
    2 use feature *4
    Speed dial -
    using
    FEATURE 0
    Dial an external telephone number using a two- or three-digit code. There
    are two types of speed dial codes: system (01-70 or 001 to 255) and
    personal (71 to 94). System speed dial codes can be used from any
    display telephone in the system. System speed dial codes are assigned by
    your System Administrator.
    Personal speed dial codes are used exclusively at your telephone.
    To make a call using a speed dial code:
    1. Press FEATURE 0.
    2. Enter the two- or three-digit code for the number.
    Speed dial -
    programming
    To program personal speed dial numbers:
    1. Press FEATURE *4.
    2. Enter a two-digit code from 71 to 94.
    3. Specify the external line by pressing a line button, a line pool button, or
    the intercom button. If you do not specify the external line, the system
    automatically chooses a line for the call.
    4. Dial the telephone number you want to program (up to 24 digits).
    5. Press HOLD.
    6. Record the code and number you have just programmed.
    Note: You cannot program personal speed dial numbers while another
    user is programming your system.
    May 15, 2008 | NorStar T7316E Corded Phone
    Not working
    Astonishingly, assignment of announcement to phone line is not documented in the user manual. Tech support was totally worthless concerning this issue. I had to discover it by trial and error. To assign an announcement to a specific phone line do the following:
    1) Record your announcement message for a, b, c, ao, etc. as documented
    2) Press program
    3) Keep pressing the feature button until ANNC appear at the bottom of screen, line 1 appears at the top, and the letter 'a' appears in the middle.
    4) Choose the announcement to be assigned to Line 1 by pressing the select button
    5) Press the feature button again. Line 2 appears in the display.
    6) Repeat step 4 to select the announcement to be assigned to Line 2.
    7) Press program button, or take phone off-hook to end the sequence.
    Shame on AT&T for such shoddy documentation, and lack of support for their products!
    Nov 09, 2007 | Lucent 1872 Corded Phone
    Clear speed dial/one touch settings
    There is no way to clear the settings you would have to re-program the correct setting. Did you program one touch speed dial on the line buttons? I do not see how programming a speed dial could effect accessing the CO lines unless you re-programmed the CO line buttons by mistake. If so, you would need to re-program those soft keys to line buttons. The manual you have may not cover this? The phone you have can work on a few different Panasonic phone systems. If you need a more detailed manual you will first need to know which Panasonic phone system you have. The phone part number WILL NOT help you determine which phone system you have. There is a main control unit somewhere (basement, utility closet, etc..)
    Aug 13, 2007 | Panasonic KX-T7431 Corded Phone
    Panasonic KX-T7633 Corded Phone Logo
    2,662 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
