Question about Nakajima AE-740 Typewriter
Doesn't type on paper.
Display arrow is on NP. How do I release that?
  • lstopar Jan 16, 2009
    You were right on the money! The print cartridge was stuck. After fixing that the machine works just fine. Thank you very much. Do you know how I can obtain a manual for this typewriter? It's a great machine and has so many features I could be utilizing, but without a manual I don't know how to engage them. THANKS AGAIN!!
    Scholar:
  • 183 Answers
NP means normal print.  it should be printing. check to be sure ribbon is installed correctly and is moving, you can turn knob on ribbon and look at ribbon to see if it is moving.  see if ribbon is used up. also make sure printhammer is latched forward
Posted on Jan 14, 2009
Tip
On the older Canon 6085 copier
From my understanding there are two types of NP 6085 copiers. To get into the service menu on the older type you will need to open the doors above the 2 paper trays and look on the right hand side for a small hole. Once you find the hole insert a bent paper clip into the hole to depress a switch. If done correctly you will see an S in the upper left corner of the display. Then hit the following *4*. that will put you into service menu.
on Jan 13, 2009 | Canon NP 6085 Copier
When typing, the words are not printed to the page until I hit enter. How do I get it to go back to normal where it prints as I type?
You are in the delay print mode. Press the mode key until the arrow on the display points to NP.
DickyO
Aug 26, 2011 | Olympia Startype 3 Typewriter
How to handle paper jams on bypass tray on Canon np 6230?
in which part the paper has jammed ?
there is intruction on display.
but the first step you must open the front cover.
May 17, 2011 | Canon NP 6230 Copier
Xerox phaser 6130 is stuck in 8.5 x 11 -- we need A4
When loading paper in the Paper Tray set the paper type and size on the Control Panel before printing.
NOTE: If [None] is selected in the Paper Type pull-down menu in the print driver, printing will default to the Control Panel settings. Printing will be performed only when the settings for the paper size and type configured in the print driver match the settings on the Control Panel. If the settings in the print driver and Control Panel do not match, follow the instructions displayed on the Control Panel.
To select a paper type:
NOTE: Paper type settings must match those of the actual paper loaded in the paper trays; otherwise, image quality problems can occur.
  1. Press the [Menu] button on the Control Panel.
  2. Press the [Up] or [Down] arrow button until 'Tray Settings' is selected on the Display Screen, and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select the tray, and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button until 'Paper Type' is selected, and then press the [OK] button.
  5. Press the [Up] or [Down] arrow button to select the correct paper type for the loaded paper, and then press the [OK] button.
  6. Press the [Menu] button to exit.
To select a paper size:
  4. Press the [Up] or [Down] arrow button until 'Paper Size' is selected, and then press the [OK] button.
  5. Press the [Up] or [Down] arrow button until the correct paper size is selected, and then press the [OK] button.
Jul 06, 2010 | Xerox Phaser 6130 Laser Printer
My typewriter won't type what I tell it to until I press tab
You are in the delayed print or line print mode. Press the mode key until the display arrow points to NP.
DickyO
Apr 27, 2010 | Swintec Office Equipment & Supplies
Trying to change the intercom caller ID onthe M7324
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you want to change the name on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
Oct 23, 2009 | NorStar Meridian M7310 Phone
How do I change the printing settings from envelope to paper? I have a Lexmark x642e.
I don't have one right in front of me but it goes like this. Press the menu button. Information menu should be in the display..select it...arrow down to paper menu...select..arrow thru till you see paper type...select...scroll thru/arrow till you see the tray or feeder that you want to change..select..then it will give your paper type selections where you can change the setting. Now like I said..I'm not right in front of the printer. I think the paper menu is a sub menu under the information menu...if not it is its own menu below the information menu. Either way....scroll/arrow around a bit and you'll fiind it.
Hope this helps!
Jul 10, 2009 | Lexmark X642e All-In-One Laser Printer
Aaa
Here ya go:
What you will see
The printer display is not in the required language.
What to do
To change the language on the display back to the required language, do the following:
Steps Action 1 Power the printer off and back on. 2 Press the down arrow button () four times. 3 Press the button once. 4 Press once. 5 Press once. 6 Press once. 7 Press the left arrow button () or right arrow button () until you see the desired language. 8 Press the return button (). 9 Press once to save the new setting
Jun 19, 2009 | Canon NP 6035 Copier
Display arrow pointing to "NP"; Typewriter won't type on paper.
NP means normal print.  to change the print mode hit the MODE button
Jan 13, 2009 | Nakajima AE-740 Typewriter
Nakajima AE-740 Typewriter Logo
71 people viewed this question
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Ron Dufek
Ron Dufek
Jim Keysor
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
