Question about Honeywell Programmable Thermostat Heater
My heating/cooling blower (not the outside unit but the fan in the garage) does not turn off, even when my Honeywell TH8000 is set on automatic. What can I do to have the fan motor shut off?
  • 2 more comments
  • TSandell Jan 25, 2009
    I have the same problem and am looking for a solution. Does anyone know a tech support number for Honeywell? If so please send to pctinas@yahoo.com
    Thanks
  • Anonymous Feb 21, 2009
    Same problem. Just change my Termostat thinking it was defective. The blower will not shut off on auto.
  • knocknow Mar 01, 2009
    Inside blower fan runs all the time on heat, but cycles on cooling. The unit warmes up and shuts down but the blower stays runing. After a hour or so the unit goes back on and it warms the house and shuts off while the blower never shuts off.
  • Scott Magill May 11, 2010
    Is the fan in the on position on the thermostat? It sound like it is on instead of auto. What kind of heat system do you have? Is air hot or cold ? When you turn heat down does fan still run? You can disconnect green wire on back of thermostat. I this a new thermostat that was just installed if so wires are not connected wright. If not you might need new one. You could have a problem with heater to. Does heater turn on when thermostat is turned up and go off when it reaches desired temperature?
    Problem Solver:
  • 28 Answers
Try hard wiring your 24 volt that goes to the outside unit to the yellow wire coming back from your thermostat make sure the yellow wire is on the yellow terminal on the thermostat (honeywell) i have run into situations when this seemed to be the only thing that worked
Posted on Aug 25, 2010
In the zoning system cooling does not get turned off automatically
If the blower not turning off or is the condenser not turning off. Are ALL ZONES satisfied? Is fan in auto position at all zones?
Jul 04, 2017 | Honeywell Heating & Cooling
Coleman Evcon furnace blower runs w/ no call for heat. Temp is 5+ degrees above thermostat setting. (Programmable tstat)
When you say door are you referring to the front door or the furnace door? If the unit kicks on AND off by itself I would say it's in the tstat or the tstat wire. If it were internal I would think the blower relay or heat contactor/relay were getting stuck AND THE FAN WOULD NOT TURN OFF until you flipped the breaker. Good luck
Mar 21, 2017 | Coleman Heating & Cooling
Honeywell tstat not working in auto cool mode
so with system setting cool/ fan setting auto, the condenser runs but the indoor blower does Not? but when system setting cool /fan setting on, the condenser runs and the blower runs?
Oct 25, 2017 | Honeywell Electronic Programmable...
Replaced Thermostat and now Blower Motor will not run
Sounds like a set up issue on the tstat. You say this is a packaged unit, inside the machine you should find where the tstat wires hook up. Typically red is power yellow is compressor orange is reversing valve white is emergency heat green is blower. Put red and green together, test blower. Then red green and yellow, make sure blower works again. If blower runs both ways it's either the tstat wire or tstat itself. Make sure you are landing wires on dedicated heat pump terminals, make sure in settings you are set up for heat pump with back up electric heat and TSTAT CONTROLS THE FAN. Good Luck. Also if there is a switch on the tstat for gas or electric on the back you want electric.
May 12, 2017 | Heating & Cooling
HAVE A HONEYWELL THREMOSTAT TH8000 NEED WIRING HELP HEAT IS COOL COOL IS HEAT
Most of the time the white wire hooks to W and the yellow wire hooks to Y....... W= Heat Y= Cooling In any case if you are getting Heat when you set the thermostat to Cooling....... Turn the furnace off at the ssu or main breaker and then ... Pop the thermostat off of the subase and switch the wires that you have on Y with W and put the wire from Y to W.... Here is some more information on how a typical thermostat is wire in the pdf..... Hope this helps...
Here is a pdf for the installlation manual for a Pro 8000
http://www.hydro-temp.com/help/drawings/honeywell%2069-1894ES.pdf
May 05, 2011 | Honeywell Heating & Cooling
My honeywell Thermostat reaches the heating temp. but the fan will not stop running.And yes the fan is set to auto.It just keeps running and running and running.It stays the same temp but will not shut off...
I want to give a simple explanation before I go any further. On the heating side of a unit even though tthe temp has satisfied the thermostat, the fan will run until it cools down the plenum where the air flows from the air handler. There is a bimetal switch called a fan limit that operates the blower when the plenum reaches the temp set on the fan limit switch. Now if your fan keeps running even after the plenum chamber has cooled down, then you could have a fan limit switch that is stuck in the run position and must be replaced in order to correct the problem.
Dec 07, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
Mystery message "wait" appears above "following schedule" display line on our Th8000. Ac does not come on even when temperature is in range. Fan operates ok. Is "wait" setting one I can reset? Maybe a...
Mystery message "wait" appears above "following schedule" display line on our Th8000. Ac does not come on even when temperature is in range. Fan operates ok. Is "wait" setting one I can reset? Maybe a compressor issue rather than thermostat? Thanks
Jun 21, 2010 | Honeywell Electronic Programmable...
How do you wire a honeywell round mechanical thermostat
What are you trying to wire up?
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Feb 09, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
349 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
