Question about RCA 27F530T 27" TV
Top four inches of screen running horizontal is distorted.
The RCA 27" truflat screen top four to five inches have static lines running horizontally. It makes it difficult to view the top portions of the screen. Most of the heads of pictures are distorted. The TV is only three years old and began the issue about a year ago. I have recently updated the cable and even changed to direct TY, but the problem persist. Help please.
  • 934 Answers
The problem is most likely in the vertical circuit, possibly the vertical IC itself or one of the feeder caps in that circuit. Could be possible poor solder connections on the IC also. Is the problem intermittent? There are a number of common problems with this unit effecting the following parts: Dp027 (27v Zener) P/N 244835 Tp022 (Bc648) P/N 198743 Tp025 (Bc558) Ip001 P/N 257786 Ip050 Ic Voltage Regulator , Zener Diode With 3 Legs Looks Like Diode. Ip030 263567 Dp057 232662 Tp052 198743 Tp020 (2sk2842) P/N 263692 Tp023 (2sc8550) P/N 257827 Dp025 244870 This is an ITC008 chassis built in mexico and the problem you're describing should be an inexpensive repair - but my downside opinion is that with this particular unit you could expect the next problem in about one to two years. Being a certified technician there are few TV's that I would tell a customer to walk away from if they were considering a purchase - but this is one of them. I'm sorry for such a negative review, please don't take it out on my rating for this solution. But if you have it repaired take it in yourself and save a few bucks - and ask the shop to save all the old parts for you. Good Luck Bill
Posted on Jun 12, 2007
White horizontal lines on top of screen
Replace all the electrolytic capacitors in the vertical output section circuit. There will be 5 or 6 of them. Replace the at one time. The fault you see is technically called " vertical retrace lies".
Apr 28, 2012 | RCA 27F524T 27 inch TV
On my RCA truflat tv there are solid white horizontal lines going across the top 5 inches of the screen? Do i need to get it repaired or is it a simple problem?
Hello
Your TVs vertical output section has the trouble. Electrolytic capacitors in that section, 8 numbers the most, should be replaced with new capacitors. Iit won't cost more. OK.
Jun 12, 2011 | RCA TruFlat 27F520T 27" TV
Horizontal white lines 27A43.
You have some bad capacitors. They are located very near and next to your vertical IC. I would guess you would have to replace maybe four of these! Thanks for asking!
Jun 12, 2010 | Toshiba 27A43 27" TV
Wavy horizontal lines on bottom of RCA 36in Truflat TV
The convergance or y-sus board can become faulty. The capcitors do tend to burn out. It is about a $250 + repair for this. Not all parts can be repaired, but they can be replaced. A capacitor tester and multi-meter are about the best tools for the job. If the price you get is over $250, I simply would replace it instead of repairing it..
Sep 13, 2009 | RCA TruFlat 27F520T 27" TV
Horizontal lines then picture starts to fade
The horizontal/vertical ic inverter is dead.
Needa new one.
Aug 02, 2009 | RCA TruFlat 27F520T 27" TV
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
Toshiba 27
you just say horizontal lines / and across a top of your television.I expect your trouble is the vertical line of your television . sound ok? try trouble the vertical section the check the resistor?
Apr 19, 2008 | Televison & Video
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
Truflat 27 inch rca
vertical capacitors beside of vertical ic no other problem the capacitors only
Aug 15, 2007 | RCA TruFlat 27F520T 27" TV
Green screen with almost horizontal zigzag lines
Is good that you hit it and it reacts,very likely you have loose conections in different places but for the distorted picture you need to check the horizontal driver transformer and flyback after that is corrected you need to check the complete chassis for loose conections.Take your time.Good luck.
Sep 07, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
RCA 27F530T 27" TV Logo
119 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
