Question about HP DeskJet 6122 InkJet Printer
Button in front of printer that looks like a tear drop.
Button keeps blinking is that normal?
    Problem Solver:
  • 7 Answers
No, it indicates low ink level in one or both cartridges.
Posted on Jul 22, 2009
How do I change the in on my older epson stylus photo
Old Epson printer has an ink button usually located on the front panel, it will look like a tear drop. Press and release the button and the cartridge holder should go to a position where you can replace the Ink. You may need to press and release the button several times since Epson has a feature of detecting which ink is empty. Hope this helps.
Basti
Sep 16, 2010 | Epson Stylus D92 InkJet Photo Printer
Tip
I followed the steps outlined by nanicool to remove jammed paper from an...
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
on Jun 24, 2008 | HP OfficeJet 4255 All-In-One InkJet...
I had a paper jam and I have removed the paper but I still have a problem. the little tear drop looking light underneath the top button is flashing and it wont print. what does it mean and how do i fix it.
The teardrop looking light is the Print Cartridge Status light.
If you have already removed the paper and still this light is blinking, then make sure you close the top cover. If it stops blinking, try to print again.
If not, then try the steps on this link.
It has the steps on how to make sure that the carriage can move freely.
I hope this helps!
May 14, 2010 | HP DeskJet 5550 InkJet Printer
Hi we dropped our printer it works but comes on and says ink is not in properly. i have pulled out and tried. geen and orange light comes on. same message again
Canon IP 2000 / reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 01, 2010 | Canon PIXMA iP2000 InkJet Printer
Diskjet6122 the light that looks like a tear (right below the X) keeps blinking. Cant get the printer to print after I changed the ink cartridge.
The indicator light blinks, it says you're low on ink in one or both cartridges. If you've changed cartridges and it still blinks, you may have stuck or dirty pins in the cartridge station(s). Use a damp, lint free cloth to make sure the pins are clean and move freely
Jan 20, 2009 | HP DeskJet 6122 InkJet Printer
Cant print. the tear like button is blinking
I have a 6940 color printer and I am assuming the 'tear' buttons are the same. If so, it is an out of toner indicator.
Dec 05, 2008 | HP DeskJet 5650 InkJet Printer
Label not advancing to tear-off perforation
Try this to have the printer auto-sense the size of the labels:
1. Make sure that printer power is off.
2. Press and hold the feed button.
3. Turn printer power on.
4. When the status light blinks, release
the feed button.
5. The printer advances the media to
measure and verify the length of
individual labels or tags. The printer
then prints a status summary and
remains in diagnostic dump mode.
6. To begin normal operation, tap the
feed button. The printer prints "out of
DUMP" and advances a label.
May 14, 2008 | Zebra LP 2844 Thermal Printer
Paper jammed
Usually tear drop means 'out of ink'
Apr 02, 2008 | HP DeskJet 5150 InkJet Printer
HP DeskJet 6122 InkJet Printer Logo
144 people viewed this question
Ben Johnson
