Question about Canon NP 6230 Copier
Canon NP 6230 copier - what does error code e244 refer to?
The unit powers up for 3 seconds. Shows error message e244. Tells you to turn power off and on and then shuts itself down. If you open one of the doors it stays on but that does not allow functions.
Thanks!
  • patti_wisseh Jan 13, 2009
    someone told us it was the dc controller main board?
  • 168 Answers
You have a scanner or lens problem look in the glass when you turn it on both the scanner and the lens should move some
Posted on Jan 13, 2009
Error code 244
Posted on Aug 02, 2009
How can i solve this E244 error code
A E244 error code deals with the scaner. When you turn the copier ON will the scanning lamp turn ON? If it dose and you make a copy and thhe scaner moves & start to make a copy and then codes out. The problem is the BLACK scaner power cable has a crack in the coatting and is arching out to the frame o the copier..... It is not a easy fix.... If the scaner lamp is not turning ON???? You may have a blown Lamp or thermal fuse.... You can still find these parts..... The code will not go away till the problem is fixed.. Good Luck
Oct 21, 2011 | Canon NP 6035 Copier
I get an error e5, e224 with my canon 6330 copier ? what is the problem & solution please?
I TRY TO UNPLUG POWER CABLE AND PLUG IT AGAIN .
THE ERROR DISAPPEARED
Feb 26, 2011 | Canon NP 6230 Copier
It comes on and it ask for ID and then when you put it in it goes to the error and ask to turn off the copier and turn it back on. Canon 6230
What is the Error Code that it displays for start. It will give us a clue what is wrong with the copier. With out it, It would be a S.W.A.G.
May 04, 2010 | Canon NP 6230 Copier
Trouble E065 WITH CANNON 6230
ERROR E065-Composite Power Board or DC Controller
Jan 11, 2010 | Canon NP 6230 Copier
Canon NP 6545 error e210
This code refer to expo unit.The home position sensor possble defected.To reset press the service mode switch sw850 and wait 3 sec,or opem close the front door.
Aug 12, 2009 | Canon NP 6545 Copier
Canon copier make is 6312
E002, fuser is not heating up, you will have to test the fuser lamp/lamps, thermal fuses, and connections.
I could also be the thermistors.
May 19, 2009 | Canon NP 6230 Copier
We have a Canon NP 6050 copy machine. When you put the plug in the socket, machine is only on for less than one second, then automatically shut off by itself.
I forgot one thing, if it turns OFF before it displays the error code Hold the power switch ON till it shows the code...... I'm thinking it maybe a E0200 or E0210 that is a scanning lamp or it could be a broken fixing lamp.... I'm guessing....
Nov 19, 2008 | Canon NP 6050 Copier
Copier failure
an E244 error relates to a communication error between two or more PCB's. Its most likely that your DC controler oard has gone and will need replacing not sure what they currently retail at sorry Hope this helps Cops Pete@wedotoners.com
Oct 09, 2007 | Canon NP 6035 Copier
Canon NP 6230 Copier Logo
373 people viewed this question
old marine
old marine
