Question about Dell Optiplex GX280 (99301) Motherboard
Resetting admin password on setup.
One of our 280s we got in is setup-locked by admin password. We don't know password, nor can we get ahold to supplier to see why it was locked. Dell Optiplex GX280 tower. BIOS version A03. Will reloading/updating BIOS reset the password? I can put in another HDD with windows loaded and try that. Resetting CMOS didn't fix it. Thanks.
-Mike.
  • 1 more comment
  • heero6x6x6 Jan 18, 2009
    The admin password locked the BIOS, and the settings are as follows:
    Boot priority is: 1) HDD 2) N/A 3) N/A
    the SATA 0 is on, SATA 1 is off, both PATAs are off....seems someone did this for meanness, they turned off the floppy, network, optical, everything except HDD, and they wiped the HDD.
    I did the battery/power switch deal and no-go, I will try the jumper part next. How do I do the jumpers? just pull and put back in? or do i hold power button while doing that?
    -Mike.
  • wyzard Feb 20, 2009
    I have the same problem i am using a dell optiflex 280... the thing the only jumpers i can find on the board are two prong not three... the board is a intel fw8201fb,fs171c69, SL7AG. the rom is a SMsC PC47M584-NC, BO49-A02014,8D119426B
  • charafox Jun 08, 2013
    i have problem with my pc dell gx280 i need an admin code plz i neeeeeeeeeeeeeeeeeeeeed it help me
    Problem Solver:
  • 5 Answers
In the model 280 Optiplex, remove the jumper, they have two pins only, turn on the computer, wait for 1 minute. The jumper is located close to the power plug, in the right side, you read PWD, theres is it, i did it and working fine...
Posted on Mar 03, 2009
First, all the info you need is available from Dell at their website. I had the same problem and simply looked up the docs on the dell site. They have diagrams of the mommy board and instructions for about all you need. In this case, password reset: you remove the jumper (power down first) and then power up.
The jumper's location varies depending on the type of case: the gx280 mini-tower that I have has the jumper in the corner next to a rectangular connector; the wiring or which obscures the jumper, but it is there and disconnecting it (and power up) will fix the problem: it did for me.
Mike The K
Posted on Feb 20, 2009
  • moise_kossi Mar 21, 2011
    Just try right now and it is working Thanks for such a great help.
U must turn off ur PC and take out the jumper (there is only one jumper near to ports) and turn on the PC after this the password will remove
Posted on Mar 15, 2009
Remove the CMOS battery and hold down the power button for thirty seconds. This will reset the CMOS/BIOS. If it doesn't the is a jumper on the motherboard that will do the same thing. Replace the battery and start the machine after that
http://www.ksu.edu.sa/sites/Colleges/CCES/default.aspx
Posted on Apr 15, 2009
Hi, had same problem, to remove password and get into bios and boot selecter, just remove the jumper near the power supple, only one jumper so cant get confused, and fairly big jumper to!
Posted on Mar 31, 2009
    Problem Solver:
  • 13 Answers
Remove the CMOS battery and hold down the power button for thirty seconds. This will reset the CMOS/BIOS. If it doesn't the is a jumper on the motherboard that will do the same thing. Replace the battery and start the machine after that.
Posted on Jan 18, 2009
  • 1 more comment
  • David
    David Jan 18, 2009
    The admin password is in the Operating System?
  • David
    David Jan 19, 2009
    The jumper is next to the CMOS battery on most boards. The Jumper is three pins with a 'plug' that covers two of them. Move the 'plug' to the pin that is not covered and the center pin. Do this with the computer unplugged. Leave it there for one minute then put it back on the original two pins. Then plug it back in and the BOIS should be reset.
    If you are not sure which jumper is the CMOS jumper, give me the model number of the motherboard and I will look of the schematics.
  • keanna2005 May 02, 2011
    I tried this and the battery fix, neither of which worked. please help me
I forgot my password to my lock screen on my Verizon Iphone 4, i understand it will erase everything if i factory data reset it but i can't get into my phone which buttons do i press to factory data reset...
Even on the lock screen Apple will help you, when you enter your password you used to setup your Apple account. Resetting only will work with that pass word, so no use trying that if you don't have the pass word in the first place.
If you did setup your Apple account correct, you can ask Apple to help you to setup a new password. I don;t know how you did setup your account, but you must have given them a mail address, where the can send you a reset code, or perhaps you have to answer some secret questions
If you manage to unlock this problem, please setup the 2 step verification for your account. Will save lots of time if you have problems in the future.
Pleas visit the support page from Apple, (in your own language) they really help.
Nov 21, 2014 | Cell Phones
I am locked out of my iview cyberpad
try to get ahold of someone from google tech support and they should be able to reset it for you through there computers.
Nov 10, 2013 | Iview Cyberpad 900TPC 9-Inch Tablet
Don't know my windows password
What the Os do you use?
The experience forgot admin windows password happened to me few days ago. And I searched in the Internet to find the solution. Then I found a windows password reset tool called Windows Password Reset have a good evaluation.
I tried it as the steps:
Step1:Download and install Windows Password Reset from http://www.windowspasswordreset.net
Step2:Burn Windows Password Reset ISO file to CD/DVD,or USB.
Step3:Put in my newly created CD and remove my Windows Password.
It really great help to me reset windows admin password.
Hope it help you too.
Jun 03, 2012 | Gateway Computers & Internet
Cant login to my motorola sbg900 wireless router. i know my username and password and it will not work. I've tried resetting it by holding the button down in the back, but that won't work either. i...
By holding down the button in the back, you may have reset it to factory defaults for the password and username. Try using Admin for the user name and motorola for the password.
Jul 28, 2011 | Arris SURFboard SBG900 Wireless Router...
I have locked myself out of administration. with the security settings not even the last 6 of my mac address works. what can I do?
I don't know that router but hard resetting should fix it,most will just say hold the red reset for 30 seconds will do it but thats not fully true.To completely reset first hold the red reset button for 30 seconds,should be on the bottom,then unplug the power for 2 minutes {must be a full two min's} Thats it most routers will revert to factory settings,that is to say your passwords will not work.Look for your paper work that came with the router the user name sould be in there as well as the password,if not try admin for the user and as the password or leave the user blank and use admin just for the password.As a precaution look for the paper work before trying any of this,having the user name and password is a must.
Hope I have been of some help good luck.....
Jun 13, 2011 | Cradlepoint MBR900 Mobile Broadband N...
I want to get the password
I assume you're trying to login to the admin section to set up your router.
Most routers by default use (username, password):
admin, admin
admin, password
admin, (blank)
If your router has already been setup, but you forget the password, then you can try resetting.
There will be a small button on the back panel of the router labeled "reset". It's quite small, you'll need to use a paper clip or the tip of a pen to push it.
Give the router a few minutes to reset itself and to power up again. It is not reset to factory default settings. Try logging in with the suggestions above.
Mar 07, 2011 | Computers & Internet
I need to figure out how to re-set my Linksys WRT54GX2 Wireless0G Broadband Router With SRX200
This article will guide you how to change the router's password and reset it to factory default.
NOTE: Accessing the router's web-based setup page requires a password. The default password of a Linksys router is "admin". For security purposes, it is recommended to change default password.
Changing the Router's Password
Resetting the Linksys Router to Factory Default
Resetting the Router Using the Web-Based Setup Page.
If any more problem encounter,post or thumbs back.
Nov 02, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
We have a westell, model 327W and do not have the security code or the one we have does not work. Whar do we do?
Access the setup page through a web browser on a wired computer. In the address bar, type 192.168.1.1.
Default Username: admin
Default Password: password
If this doesn't work, try admin for the username and password. If still doesn't work, then you will need to reset the gateway. Take note that before resetting the gateway, you need to know the internet connection settings. Resetting the gateway will restore the settings to default.
Once you are in the setup page of the gateway, go to Configuration> Wireless> then look for the wireless security. It should show you the WEP key.
Enter the wep key on your laptop.
I hope this works! Good luck!
Dec 22, 2009 | Westell Wirespeed VersaLink...
Computers & Internet Logo
5,262 people viewed this question
Alun Cox
