Question about Electrical Supplies
I replaced a fuse but still have no power.
My power blew after to many thing were plugged into one outlet, so I replaced the burnt out 30A GE 125v fuse with a new one but I still have no power. what is the next step to take in fixing my power outage? Thank you, Matthew
  • oceanriver May 11, 2010
    Where do you not have power, at the outlet where you plugged a whole bunch of things, which is very dangerous if you are plugging stuff that use a lot of power on to a single outlet, or are you saying you don't have any power at all everywhere in the house. If it's only in the outlet where you pluggeg the stuff that burnt the fuse, then take the outlet out and replace it with a new one. make sure ALL power is off before doing this. Also check the wires which are hooked up to that wall outlet and make sure they are not burnt from the end that's connected to the outlet. If you see that they are black with soot or melted...or maybe even broken, then cut of the bad part and strip for new wire to be exposed and reconnect to the new outlet. Also make sure you check the wires connected to the fuse box where the fuse you replaced is. Hope nothing burnt or broke inbetween the fuse box and the outlet(s). Hope this helps.
  • floyd giles May 11, 2010
    Have a licensed electrician install a circuit breaker panel as it is no longer acceptable to have a fuse box in use.If your insurance company were to know that you still have a fuse panel they would cancel your policy. If your insurance company has asked you about the electrical wiring and you misrepresented to them as to what you have you will not have any coverage in the event of a fire
    Sergeant:
  • 359 Answers
I QUESTION FIRST THE 30 AMP FUSE , FUSES SHOULD BE SIZED TO THE WIRE IN THE CIRCUIT AS FOLLOWS , # 12 -20 AMP FUSE , # 14 -15 AMP FUSE AND # 10 @ 30 AMP FUSE OUTLETS ARE USUALLY # 14 OR # 12 AND SHOULD BE FUSED ACCORDINGLY , ------ NOW TO GET TO THE ORIGINAL QUESTION AS TO THE PROBLEM , MOST POWER DUPLEX OUTLETS ( WHICH IS THE KIND WITH A PLACE TO PLUG 2 DEVICES HAVE WHAT IS REFERRED TO AS A BRIDGE BAR THIS IS ON THE SIDE OF THE OUTLET CONNECTS FROM THE TOP SCREW TERMINAL TO THE BOTTOM SCREW TERMINAL THIS IS ON THERE FOR THE SPLITTING OF A CIRCUIT SO SAY IN A LIVING ROOM YOU WISH TO SWITCH THE BOTTOM FOR A LAMP AND YOU WANT THE TOP TO STAY HOT ALWAYS TO ALLOW YOU TO PLUG IN SOMETHING THAT YOU WISH TO STAY HOT ALL OF THE TIME AND NOT BE SWITCHED , THIS IS ON THE SIDE OF THE OUTLET AND IF I WANT TO SPLIT I WOULD SIMPLY BREAK THIS INTO USING NEEDLE NOSE PLIERS ******-- PROBLEM THESE BARS ARE ONLY GOOD FOR 15 AMPS AND CAN BURN INTO UNDER THE LOAD YOU DESCRIBE REMOVE OUTLET AND HAVE A LOOK HERE FIRST IF THIS IS CASE REMOVE AND REPLACE ( BE SURE TO MAKE DIAGRAM OF WHICH WIRES CONNECT WHERE AND ALWAYS KILL POWER BEFORE WORKING ON ELECTRICAL CIRCUITS )
Posted on Jan 13, 2009
My argus 300 projector bulb blew new one won't work
yes could have been a power surge at the time, or fan cooler packed it in, the internal housing inside the Projector would have been too hot with the bulb inside it cooling down without the fan, i would double check all parts near the lamp housing and check to see they have not melted or burnt, also worth checking the fuse as well should be a T-250 Fuse bulb
Apr 23, 2017 | Argus Vintage Cameras Inc Projector Model...
Refrigerator does not appear to be getting power, no lights, don't here motor running
If you have no lights or hear the motor running, I would check the house circuit breaker first and measure the voltage at the outlet. If that is within specs then the one thing that could cause your problem in the refrigerator is the power control board P/N: 6871JB2047A
Sep 18, 2011 | LG LFC23760ST Side by Side Bottom Freezer...
TV blew fuse. Replaced with 125v 5 amp from a 33 inch Toshiba that has gone bad. The 5 amp also blew. Purchased new 4 amp fast blow fuse for unit, now nothing happens, i.e., no blown fuse, no circuit...
replacing the fuses with random values is prolly not a good thing...but one thing to check is a big transistor know as the HOT. This will more than likely be clipped or screwed to a heat sink NEAR the flyback (big transformer, has a wire going into the big glass tube). That causes fuses to blow...If this does not work, let me know.
Nov 30, 2010 | Toshiba 13A23 13" TV
I am re-wiring an outlet in my garage that normally goes to an electric dryer. I want it to have 30 amp 120V. Do I just leave off the red wire? And don't they make a 4 hole recepticle that will accept...
Yes on the red wire. I don't know of a 4 hole receptacle but that doesn't mean it doesn't exist. Do you also plan to change your breaker? You'll need to disconnect the red wire and cap it.
Here's a link to some instructions on how to do your project. Good luck!
http://en.allexperts.com/q/Electrical-Wiring-Home-1734/Change-existing-220V-dryer.htm
Mar 14, 2010 | Reliance Controls L1430P 30 Amp Plug
I have a projectionTV Sony mod. KP48V75. During a storm the safety power fuse blew. It was 125V 6.5A. I replaced it with 125V 6A and so far everytime I plug the TV on it blows the fuse. I have been through...
Most likely the storm did damage to the power supply board (the G board in a Sony) which is part number A-1316-388-A for your TV. However the board is no longer available..It most likely has a bad regulator and possibly rectifiers on that board that are shorted. Complete board replacement would be the best solution.
Nov 03, 2009 | Sony KP48V85GRAY 48" Rear Projection...
We had a power surge in our area a little while ago and our tv went. I took the cover off the rear and saw a 6.3 amp 125v fuse right inside where the cord went and ir was burnt. I replace it with the same...
1.Check the power outlet where your TV is plugged.
Also your power panelboard for tripped off breaker.
2. If ever, your TV won't power on, then, it needs to
check your TV circuits. You can start at the power
supply IC for busted part., then to the other section,
(transceiver, audio, and video section)
Sep 30, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Tv problem with a fuse
Your degausing thermistor is bad and needs to be replaced. The part number is D4DDF1R50001
Once that is replaced put a new fuse in put the set back together and you should be good to go. You will need to replace the fuse with the correct size and its part number is
XBA2A00101F
Sep 10, 2009 | Panasonic CT-36SX12 36" TV
Blows main fuse when power is turned on
Shorted power supply/module is most likely problem.
May 27, 2009 | Sony STR-DE635 Receiver
Electrical Supplies Logo
2,058 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
