Television response. Hi guys, my problem is that my t.v. responds occasionally to the remote. Most times not than usually. It's not the remote as i've tested it on my other t.v. and it works fine. can you help? The tv doesn't respond to the remote. Neither the Toshiba remote or the cable remote control the tv. All the batteries are good. It just happened all of a sudden. The buttons on the tv work fine. The tv is 5 years old and still works great. I don't want to spend alot of money to fix it. Hpoe you can help. Thank You
  • berardim Feb 14, 2009
    My Toshiba CZ32V61 (32" std. def.) does not respond to the remote. It started as an intermittent problem; now it does not respond at all. It is not the remote itself or the batteries. How do I find where the sensor is so I can clean it?
  • 227 Answers
Try to locate the line of sight sensor on your TV that does not respond to the remote. The lack of response indicates that the sensor on the TV needs to be cleaned. It does not take much (dust, wax, cleaner residue) to block the signal.
Posted on Jan 15, 2009
LCD2710HDAF television will not respond to remote control
Hi Alan,
Here are a few steps to troubleshoot.
1) Make sure that the new batteries are correctly installed.
2) Make sure that there is a line-of-sight between the remote and the TV while operating.
3)Not recommended- but might work. Give your remote a little shake. If there is a small circuit loose connection it will be adjusted. :P I do this all the time.
4) Buy a new remote. You can buy a universal remote which are available on the market. They are cheap. It will NOT be harmful to your TV.
you can buy a genuine one.
May 12, 2014 | Televison & Video
Rca 42pa30rq
Hi! Hope this will give hint... I understand some televisions nowadays are fully controlled using remote but there is always a standby power button for the television remote function. If the there is no power after turning on using the standby power button please check power cables, supplies and fuses. If the television has a standby power waiting the remote to act on but no response after pushing the remote's power button check the battery and its contact. Goodluck.
Mar 18, 2014 | Televison & Video
I have a Sony KDF-55WF655. I think the IR sensor is going bad. My remote occasionally stops working for no reason. I have tried numerous different remotes, but I get the same problem no matter which...
The IR receiver inside the television is becoming intermittent and needs to be replaced. You might also check the connections on the receiver small circuit board for cold or loose solder joints.
Sep 09, 2011 | Sony Grand WEGA KDF-55WF655 36" Rear...
My Harmony 890 remote has a difficult time inputing numbers
Hi. This problem is caused because the 'repeat' setting on the device that you use to change channels (TV or cable box) is too high.
1. In the software, click 'Troubleshoot' next to the icon for the device that you change channels on.
2. Select '<device> responds to some commands either too many times or only occasionally' and click NEXT.
3. Decrease the setting by one (the default is usually 3).
4. Update your remote and test it.
Apr 25, 2010 | Logitech Harmony 890 LCD Remote Control
Its the IR sensor. You could go the DIY router and solder a new one back on, or buy an add on one if your set accepts it.
Oct 05, 2008 | Toshiba 36A40 36" TV
No response from remote
user manual
FINALLY no need to thank me
User Manual
Aug 31, 2008 | Televison & Video
Remote problem could arise from either tv or remote. First check your universal remote on some other tv and if it is okay your tv's infrared sensor has stopped working. You can get it from the local component shops, take the existing sensor with you. This problem could be from the micro processor in rare cases. Best of luck.
Jan 27, 2008 | Panasonic CT-32SL14 32" TV
Check whether the remote control is working properly or not by using remote checker. Even if it is the universal remote control you have to set the code for the particular model. Otherwise it will not work.
Sep 17, 2007 | Panasonic CT-32SF37 32" TV
Remote control
Without a name, thats almost imposable my friend. Try a Good universal on the manual search. maybe you will get lucky and the remote will work. Good Luck
Jun 14, 2007 | ViewSonic NextVision N4000WP 40 in....
Televison & Video Logo
120 people viewed this question
Top Televison & Video Experts
