Question about Linksys (WKPC54GCU) 802.11g/b Wireless Adapter
Wireless printer My printer is connected to an HP desktop running XP.I'm trying to print form my HP laptop running Vista. It used to work fine. Now when I click print , is says printing but nothing happens. The laptop sees the printer. When I right click on the printer properties everything is grayed out.
    Scholar:
  • 77 Answers
Sounds like you have lost your network. Have you recently installed a new anitvirus of firewall? Share a file folder on your Xp desktop machine. See if you can access it from your laptop. There are several ways this can happen. Let me know if you can see the shared folder and what antivirus or firewall you are running. Ed
Posted on Jun 13, 2007
    President:
  • 2,961 Answers
It sounds as if the printer may not be set as the default printer, so check in the installed printers and check and also check that the printer you are sending the print to is the setup one and not a pdf or microsoft office document printer, this is found on the drop down box when the print option appears. i am also assuming that the printer has worked before from vista to an xp machine as sometimes xp needs a small update to be used with a vista pc on the network
Posted on Jun 12, 2007
I have HP Officejet 6500 connected via USB to office desktop. I also need print from vista laptops on the same wireless network as the desktop. How do you do it ?
Hi, I just completed this same query this week.
to set up my remote network i followed promts from windows and then had to run my windows xp startup disc on my vista laptop.
After that was complete i had to install the hp printer setup cd onto my vista laptop and connect the hp printer to my router using the ethernet cable. I followed the prompts on the vista as the cd continued to install. then at the end of it all it showed i had correctly installed the printer via wireless and asked me to do a practice print which i did and all seems fine.
I can now print from my vista laptop and my windows xp desktop. I hope this helps
Jun 12, 2011 | HP Officejet 6500 AllInOne InkJet Printer
HP photosmart used to print wirelessly from my Vista loaded laptops. printer was usb connected to desktop with XP. Had to get new hd and reload with XP for desktop and now cannot configure for wireless...
As your printer is not wireless itself I assume you shared the printer. To enable this again goto Control Panel on your desktop, select printers, right click your printer and there should be an option for sharing. Enable sharing.
Now using your Vista laptops you should connect to your home network (in your case this is probably a wireless router, as long as your desktop is connected to this router too), goto Control Panel, printers, add printer, search for printer not connected to this copmputer (or network printer).
Hopefully the Vista laptops will then pick it up and install it correctly. You may be asked to install the correct driver for the vista machines. Windows should provide you with instructions on how to do this.
Hope this helps,www.PuterCare.com
Feb 27, 2010 | HP Photosmart 2610 All-In-One InkJet...
I cant plot from AutoCad 2006, using My hp
hmmm.. we only have two computers at my work connected to a router. the designjet has a network card going straight to it. i connect to the router wireless and it reads vista. my boss connects to the design jet thru the router as well with a network card rj cable with xp pro. as for our printer it can be connected via router and does work fine but my boss has it directely connected to his computer and i share it off of his system. then we also have a zerox machine connected via router as well. maybe your router is going out? try a new one or a better one and see if that fixes it. it maybe defected or time for a new one.......
if it was working before then maybe its the router.
Jan 07, 2010 | Autodesk AutoCAD 2006
Printer is connected via USB to a Win XP PC and prints fine. However will only print test print from networked Vista laptop?
I take it you the Win XP PC is on the same network that your Vista Laptop is on and that some how you must be able to share the printer through your XP PC?
I think you are experiencing the many issue that Vista has to offer.
Maybe think of actually seeing about placing the printer on a Network print server. This would solve your issue. I did this with my Brother Laser printer and it works great. I believe the print servers are coming down in price I am using a TRENDnet TP100 and it works great with my two wired network desktop PCs and the two wireless notbooks that both have Vista on them.
Blessings,
A/V Media Guy
Nov 22, 2009 | HP LaserJet CP1215 Color Printer
I have a Dell desktop running Vista 64 Home Premium with a Lexmark P6250 all in one hooked to it via usb cable and shared on my home network. I also have one dell laptop and one HP laptop connected to the...
The printer drivers must be installed on each computer. If computer A runs XP, you must install driver for XP on computert A; If machine B runs Vista, then you must install printer drivers for Vista on machine B.
Hope it helps.
Sep 11, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Using HP laptop running Vista wireless intranet connection to HP desktop running xp and desktop hardwired connected to HP Officejet 6110. Can not get laptop to print on network. All internet and other...
The printer needs to be installed by you as "Adiministrator". When installing the printer you need to hold down the "Alt" button when clicking n Add Printer function. It will then give an option of installing as Administrator.
May 20, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Cannot add printer to PC on network
heres a link for drivers for your machine.....download the proper driver for each individual system and run setup application
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9106&product=EKN033540
Apr 20, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Network Vista Wireless Laptop to XP Desktop & Print Documents
On the desktop machine - go to the printers folder, right click the icon for the Laserjet and choose sharing (enable print sharing). You should be able to name the printer and make it accessible to anyone within the workgroup. If needed you can run the network setup wizard to change the workgroup names on both machines.
On the laptop go to add new printer and choose network printer, you should be able to browse to the desktop machine by name and choose the Laserjet as a printer (whether you want it to be the default is up to you). The laptop will download and install the drivers from the desktop pc to the laptop and set the correct network path automatically.
It goes without saying that the desktop machine must be on in order to print from the laptop in this scenario.
Feb 21, 2009 | Dell Inspiron 1525 Notebook
I have a sony vaio laptop running xp sp2 connected wirelessly to an HP C4385 printer. I can't get it to print in this wireless mode and I can't get a response from the printer when I put the printers IP...
I suggest you network the printer and access it through the wireless access point.
Also, I do not mean to insult your computer smarts, but if you do not have a driver installed, you will not be able to talk to the printer at all.
Aug 14, 2008 | Computers & Internet
Network router printing issue
sure..you can put all the computers on the same workgroup, and form a network
we got fresh wireless drivers here too
Mar 17, 2008 | D-Link Wireless
Linksys (WKPC54GCU) 802.11g/b Wireless Adapter Logo
243 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
