Question about RCA HD50LPW42 50" Rear Projection HDTV
LAMP COMES ON AND GOES OFF
LAMP AND COLAR WEEL WILL COME ON FOR ABOUT 10SEC AND THEN GO OFF THEN STAY OFF FOR ABOUT 45SEC THEN DO THE SAME THING AGAIN AND AGAIN
    Genius:
  • 1,239 Answers
Hi its an bad lamp with an resistor failure on the board...fix it the problem will be solved...thank you
Posted on Jan 14, 2009
    Sergeant:
    Novelist:
  • 326 Answers
Its time for removing and reinserting the lamp and colour wheel.but if still shows the samr then it needs replacement 1 by 1.
http://www.flickr.com/photos/fixyourdlpcom/
click the link for replacement directions.
Posted on Jan 13, 2009
  • 818 Answers
Remove the lamp from the lamp assembly
Remove the back panel.
From the back, slide the main circuit board to the left (loose one screw)
Remove the power interlock on the lamp assembly (2 screws)
Disconnect Lamp assembly cooling fan lead.
Remove the 4 silver slotted screws on the lamp assembly, 2 in the front and 2 in the back.
Carefully remove the lamp assembly from the rear. WATCH the Mirror.
Remove fan, cut leads and solder or **** splice on to the new fan.
Repeat steps for installation
  • Sergio Scalfaro
    Sergio Scalfaro Jan 13, 2009
  • 10,594 Answers
It looks Lamp needs replacement.
TV goes to shutdown because of excessive current consumption of weak lamp and new lamp will resolve this issue.
  • RCA Master
  • 19,396 Answers
The small power board that powers up the lamp is defective, must be tested and eventually replaced.
  • Ginko
    Ginko Jan 13, 2009
    The small high voltage power board that powers up the lamp, often improperly called ballast board, is defective.
    To fix the problem the TV must be taken apart and inspected by a technician , if picture goes intermittently, it is likely a bad solder joint or a loss contact.
    Call a technician before you burn the lamp, and end up spending more money on parts.
  • Ginko
    Ginko Jan 13, 2009
    I do not think it is the lamp, when it is the lamp, usually it does not turn on at all, and you get an error message..
    A lamp is expensive, call the technician .
    Here is the manual :
    HDTV User’s Guide
    Here is how to replace the lamp: ]
    instructions RCA
Will not stay up and running
what brand and model number if DLP TV # BAD LAMP IF LAMP IT'S 3 YEARS OR MORE #2 BAN LAMP FAN # 3 BAD BALLAST (power supply to lamp) # bad color wheel lose connector
Apr 03, 2014 | Televison & Video
Fuel line
1: need tune up, every 60k miles, do that ever?
2: EGR valve stuck open, if wide open throttle power is ok.
3: if WOT power is lacking, weak fuel pressure, clogged fuel filter (that missing tune up again) or clogged injectors.
3: weak spare (dang there goes that tuneup thing again.
and if misfiring 50 more things. is it?
is the CEL lamp glowing key on, and stay out running.
no, the lamp glows, running?, then scan it.
using any scan tool.
Jun 28, 2013 | 1997 Honda Accord
My TV switches of automatically on startup. It started occurring 20 days after I switched a new bulb. At first it would turn off and turn back on for about 6-7 times and then stay on. After a while it does...
sounds like you r color weel is going bad bad thing is that your color wheel in most of the toshibas is in the light engine and can not be changed seperaly so if this is your problem then your looking at 600-900 replacement or 300-400 to rebuild
May 18, 2010 | Toshiba 52HMX84 52" Rear Projection...
Car want stay crack.will fire up but want stay on thinking it may be ignition coil.year 2002 cadilac escalade all weel drive 6.0 engine.I did drive it to the store came back home then went to head back out...
I would check your fuel system first, like the fuel filter and then the fuel pump. it 7 years old and if you have had dirty fuel......... was it ok before going to the store?
Dec 18, 2009 | 2002 Cadillac Escalade
Goes of but keeps clicking then comes back on for a few mins then off again and so on
usually caused by the lamp being burned out, the ballast for the lamp not firing or the power supply board may have failed. first thing to try is the lamp.
Nov 09, 2009 | Samsung DLP HL-P5663W 56" TV
Zenith power will not stay on
Either replace Lamp or Fan is bad.If lamp has been replaced its the FAN, fan must run at all times in order for set to come on and lamp to stay on.
Dec 12, 2008 | Zenith D52WLCD 52" Rear Projection...
My sony tv will not stay on
If you replace the lamp and need to reset the Lamp Timer Reset procedure is: With The Set In Standby Press Display, 5, Vol Up, Power on the remote control Press Jump 3. Or, To Display The Lamp Time Press 2 Nine Times. To Reset Press 3, Mute, Enter. One of these should work on your model. Make sure you replace the bulb first. There is a possibility that the ballast could be damaged by a defective bulb as well.
Jan 18, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
RCA HD50LPW42 50" Rear Projection HDTV Logo
26 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
