Phaser 8550 printer got fault 37,008.44:25860 error message.
That is a main print engine self test fault. Most of the time the electronics module loses a source to cause that problem.
Most likely a print head heater source bad, or the print head. Keep in mind that printer has a 1 year warranty.
The print head , depending on who you go to, can range from $200,to $750, the electronics module, I haven't seen one for less than $1000 . Although if the machine is not under warranty I don't look real hard for one because it is so cost prohibative.
This is a pre heater error.
I would make sure the printer is connected directly into the wall and not into a power strip or UPC as these devices may create momentary AC voltage sags that could cause this error. If power levels going into the printer are good, you will need to contact Xerox for support
Ink count sensor flags are stuck after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41, where x= 5 for cyan, 6 for magenta, 7 for yellow, and 8 for black. (Your error indicates black ink loader failure)
Features on the bottom of genuine Xerox ink sticks actuate the Ink Out Sensor located at the forward end of each ink channel of the Ink Loader. The sensor indicates the passage of ink to provide a count of ink consumption.
Damaged or non-genuine ink sticks may not reliably actuate the sensors. This can lead to false Ink Out messages as well as Ink Stick count faults. Using 8400 model ink in a 8500/8550/8560 models will also cause 9,03x.4x ink stick count faults.
Ink Loader will need replaced and then diagnostics entered to run "Clear ISC Fault" test to clear the error.
IIf
My 8558DP has a 37,004.40 and 13,266.44. Where can I find part numbers, how is the best way to locate parts cheap, is this a repair I can do myself?
