Question about StarTech.com StarView SV211K 2-port KVM Switch
Cannot get out of starview languages menu
Hi all,
I have followed starview instructions to set up super box. Turned on emu key, did an auto scan and 0 channels found came up. I then pressed exit x 2 and I get brought back to the languages menu and cannot get out any further. Any help appreciated.
Thanks
  • michelle_mcn Jan 15, 2009
    Hi Chris,
    Thanks a million for taking the time to try and help me with my problem. Unfortunately no joy! I'm still unable to get out of the Languages page.
    Thanks
    Michelle
  • supertedxxx Apr 08, 2009
    How Do I Exit The Language Menu on The Box Super???? When I press ok on English it brings me into the main menu, then when I press exit straight back into the language menu :(
    Help Please!
  • 827 Answers
You have to put the keys in manually, do as follows:
Press menu button
Press 1570 this takes you into secret menu.
Now hit ok on nagravision
Next make sure your cable provider is listed at top NTL or TELEWEST C&W ect
Now change key 00
(YOU MUST SAVE EACH KEY INDIVIDUALLY - I.E. AFTER CHANGING KEY 00 MAKE SURE
YOU STORE BEFORE CHANGING KEY 01 (TO STORE PRESS OK)
Here's the latest codes:
Here's a visual guide:
http://www.freewebs.com/boxsuper/
Hope this helps
Chris (ziraffa)
Posted on Jan 14, 2009
What is the key emu when talking about starview box ?
before you can access the hidden menu for the emu you must have the latest firmware or update for your receiver if you do then scan after complete scan press menu then 1570 go down to emu turn on with left or right arrow key on remote then press exit exit back to main screen and all should be working
Apr 17, 2010 | StarTech.com StarView SV431USB 4-port KVM...
Starview box(3 YEAR OLD)gone off,follwed instructions to factory
1st have you scanned the correct provider ex NTL, TW etc?
2nd did the scan find any channels or none at all?
EMU is the emulation to unscramble the channels, to access this in a starview press menu enter 1570 to bring up the secret menu, scroll down to Key EMU and use the <> buttons to turn on.
Exit out and select a PPV channel eg Sky Sports 1 and it will update. You are then set to go.
If no channels are picked up with the scan then check the VM website to see if there are engineering works in the area causing the problem.
Oct 05, 2009 | StarTech.com StarView SV211K 2-port KVM...
Box gone off
Do an AUTOMATIC SCAN. but to make sure you get ALL the channels you need to have KEY EMU turned on. To turn KEY EMU on, press MENU, PARENTAL CONTROL, then on the remote press "INFO" "2004" Go down to KEY EMU and make sure it's on. If you press enter on NAGRAVISION this is where you enter the new keys. So choose TW, Key 0 AA B7 D1 D9 CE 8E 83 AF then press "OK" to save. Now change Key to 01 and enter 8E 80 D7 EF 44 93 02 2B Folllow all that and you should be OK
Jun 29, 2009 | StarTech.com StarView SV211K 2-port KVM...
Lost channels
What I did after loads of trial & error trying t follow peoples advice on here so not sure how much of it you need t do (Stage 2) might not be neccessary so try 1) followed by 3) & 4) first ;o) :-
1) Deleted all the channels & reset the factory settings to 0000.
Turned off the box at the plug, left for a couple of minutes & turned back on
2) I reinstalled the software at http://www.4shared.com/file/76886028/fd4ac296/GTRom_the_box_Super_8102e_081129.html?err=no-sess (Not sure if thats necessary but I did so try this if 3 & 4 dont work without reinstalling)
3) Turned on the Box & went into the menu pressed 1570 on main screen to get into the CAS SASTEM & turned the EMU key ON
4) Reinstalled the channels using Telewest (Even tho I'm with Virgin) & voila, it worked & I can get all the channels again ;o)
Good luck - Stace
Jun 17, 2009 | StarTech.com StarView SV431USB 4-port KVM...
I have starview box and its losing stations slowly has anyone got same problem or a solution.i live in dublin south (for ntl)
When my box does this I just re-scan it..that normally works...press menu then factory setting type in 0000 then go to installation and auto re-scan (will take several mins) when done make sure the emu key is on. and you should have all your channels back.
Good luck
Gord
Ps if you need them the NTL codes are
00=B0 B8 4F 04 E6 5F 87 80
01=A3 EB EC 07 D6 49 D2 EB
To input the codes press menu then key in 1570 this will bring up another menu..enter nagravision to input the codes.
Mar 17, 2009 | StarTech.com StarView SV211K 2-port KVM...
Emu
hi press menu then key in 1570 another menu will come up and that is where the emu is good luck
Dec 19, 2008 | StarTech.com StarView SV211K 2-port KVM...
Starview 4 thebox super usb
hope this is of help to you if not let me know .
press menu.
press 1570.
look down list to make sure EMU is set to ON . press ok.
code screen service provider tab should be 5A01.
00. go to the bottom of screen and change the codes saving each code entered.
go to the 00 tab and press right to 01. go to the code tab and change codes saving each code as entered.
0.C0 F6 61 87 91 F9 67 57
1.F0 83 35 E5 28 40 49 B2
Dec 11, 2008 | StarTech.com StarView SV211K 2-port KVM...
Box super starview
has any one got any information for putting codes in starview 3 super
thanks 817440.
Nov 05, 2008 | StarTech.com StarView SV211K 2-port KVM...
The box super
hi i have the super box has anyone got the new code
Aug 16, 2008 | StarTech.com StarView SV211K 2-port KVM...
StarTech.com StarView SV211K 2-port KVM Switch Logo
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
