Question about Garmin eTrex Legend GPS Receiver
Screen on c530 Garmin is damaged. How much to repair?
It fell off the dash and while the screen doesn't appear damaged, when you turn it on, there are cracks showing on the display
  • Garmin Master
  • 638 Answers
It sounds like you've broken the LCD screen below the protective outer cover. It will have to be replaced. I don't know if this website can help you.
http://www.sharc.net/nuvi_repair_warranty.htm I am not affiliated with them.
Posted on Jan 14, 2009
Garmin c530 just gets warm, won't power on, won't charge.
try resetting the unit by popping off the frame around the screen where the reset button is.
Oct 23, 2009 | Garmin StreetPilot c530 GPS Receiver
My Garmin c530 GPS will not turn on
Pull the face off it, press the reset button, this may work,
If it will not reset, or work in the house or the car, the battery will need replacing,
http://www8.garmin.com/support/outofwarranty.html
Around $100 for new battery
Regards.
Jun 21, 2009 | Garmin StreetPilot c340 GPS Receiver
How to reset garmin c530? thanks.
Pull the face off, press reset button under it,
then update it at Garmin's Web-updater website.
If it wiil not reset like this
Press the lower right corner of the screen, while turning on, keep pressing until the message
" do you want to remove all data " appears, click yes
Then re-register it at Garmin, then re-update it at Garmin
Should be good then
Regards
Richard.
May 18, 2009 | Garmin StreetPilot c530 GPS Receiver
Can't register my Garmin c530
Hi
You'll need to enter the serial number of your device, only after that you'll be able to select your c530 device from the list. However, if its not showing there then you can visit this link for update installation of your C530---
Garmin C530 Update
Garmin Product Registration Link
And, if you are unable to install the updates then you can visit this link for more details---
Garmin Support
Please do rate this solution as FixYa if found helpful and revert for further assistance.
Thanks
Rylee
Apr 29, 2009 | Garmin StreetPilot c530 GPS Receiver
Touch screen doesnt work all the time
Pop the face off to reset it, could sort it for you.
Press the power button for over 1 minute to calibrate the screen
and use the Garmin Web-updater to update the software.
Should be good then
Regards
Richard.
Apr 15, 2009 | Garmin StreetPilot c530 GPS Receiver
C530-Dead
Have you tried firmware update for your gps .
If you have not tried it try to update the latest firmware .
By updating firmware your problem can be fixed .
If your problem still exists then try to charge your gps from any external charger and check whether screen is working properly .
If your problem still continues then you need to take your gps to near by shop to get it repaired .
Dec 09, 2008 | Garmin StreetPilot c530 GPS Receiver
Automotive Repair
Is this posted under Garmin C530 GPS receivers for a reason?
Apr 09, 2008 | Garmin StreetPilot c530 GPS Receiver
Garmin C530
There is a Master Reset procedure, but you would lose all of your favorites if you did it. To do a Master Reset, turn the unit off. Press and hold the on button and the bottom right of the screen at the same time. Release the on button when the unit comes on and asks if you want to do a Master Reset. Again, this will ERASE ALL OF YOUR FAVORITES.
Mar 27, 2008 | Garmin StreetPilot c530 GPS Receiver
Garmin c530 won't turn on
Have a c530 I purchased 11/2006. In 12/2006 had 3 instances where I shut unit off and it would not turn on. Garmin had me do resets which did nothing. Had to leave unit to discharge for 3 days, then plugged in USB and it powered up and was fine (for a week or so). They gave me a new unit and at the same time a system software upgrade was available. The c530 was perfect through all of 2007. Then in Jan 2008, the same failures occurred 3 times. I discharged it 3 times and it now works, but for how long? My advice is to get anoher model. I have 5, c330's for over a year and they have had 100% reliability. l
Jan 25, 2008 | Garmin StreetPilot c530 GPS Receiver
Garmin c530 street pilot
My Garmin c350 has a green screen after trying to update it for the first time and my computer will not read that it is connected.
It will not shut off after holding the power button down for 3 minutes
Dec 13, 2007 | Garmin StreetPilot c530 GPS Receiver
Garmin eTrex Legend GPS Receiver Logo
221 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
