Question about Lucent PARTNER18 Corded Phone
Intercom rings and there is no one there, the sound of dialing pr
The intercom on my phone rings for no apparent reason and when handset is lifted the sound of dialing can be heard. What is the problem and how do I fix?
  • hrsron Jan 13, 2009
    This is a Lucent Partner 18d, the second intercom lights up, rings, nothing indicated in the display. When handset is lifted, the number seem to refial in your ear and no one is there.
  • Anonymous May 11, 2010
    While the phone is ringing, it will display the extension that is calling, or the caller ID that is calling. What does your say?
    Champion:
  • 211 Answers
You might have a door phone that was installed and programmed as a door phone extension. Now a physical phone that is connected to a previous door phone port is causing this.
Check your #604 and #605 command
Posted on Mar 16, 2009
ON PHONE KX-T7420 NEED TO CHANGE HANDSET RINGTONE . WE HAVE FOUR IN ONE OFFICE AND ALL SAQME RINGTONE.
The phone has 8 ring tones. From the idle phone, press PROGRAM and dial 99. Press the intercom or a CO line button TWICE and dial 2-8 on the keypad (1 is already default). When you're satisfied with the tone, press STORE. You have to do this for each line and the intercom you want to change and you need to do this at each phone. Pick up the handset and drop it back down to exit programming.
Carl
Aug 11, 2011 | Panasonic KX-T7420 Corded Phone
Display screen shows "Will return soon" Would like
You need to cancel absent message on your phone. The method depends on which Panasonic phone system your phone is connected to. Following are the methods for three different Panasonic phone systems. Once you cancel absent message, your screen should return to date and time, if not then press * until it does.
KX-TA624 Phone System
Press intercom button, dial 750#, lift handset then return handset to cradle to end.
KX-TA1232 Phone System
Press intercom button, dial 7500, lift hanset then return hansdset to cradle to end.
KX-TDA100 or KX-TDA200 Phone Systems
Press intercom button, dial *7500, lift handset then return handset to cradle to end.
Jan 27, 2011 | Panasonic KX-T7633 Corded Phone
I get a constant ringing of the phone. I have it on do not disturb to silence it. I have changed batteries and unplugged the phone. I looked in the manual but cannot find a solutiion.
I had the same problem on my Lucent 854 phone. It could be because the intercom number hasn't been assigned yet. To assign an intercom number, leave the handset in the cradle, then hit PROGRAM (which on my phone was on the bottom row on the far left of the speed dial buttons), then *, then #, then hit a two digit number, then press the intercom button.
If it works, you'll hear a louder ring, then your ringing will stop.
Hope it works for you, because it drove me nuts.
Nov 28, 2010 | AT&T 874 4-Line Phone
How do I change time and date on Toshiba DKT2020SD
Toshiba DKT2020 set work with a lot of different Toshiba systems. That being said this should get you in the right direction.
Date
  • From receptionist station, without lifting the handset, press "Intercom"
  • Dial "#651"
  • Dial the time in YY:MM:DD format.
  • Press "Redial" or "#".
  • Press speaker.
Time
  • Dial "#652"
  • Dial the time in military format HH:MM:SS.
  • Press speaker.
Day of the Week
  • Dial "#653"
  • Dial the day of the week (1-7).
  • Press speaker.
Nov 09, 2010 | Toshiba Lands Phones
How do i use the intercom on this phone? My boss is wanting to use them but we don't have the manual and can't figure it out
Wow. The Partner 18D phone has two buttons on the lower left of the faceplate in the middle of the phone that are seperate from the 5 rows of 4 buttons. Those are your 2 intercom buttons. If you press one of those and pick up the handset, you'll get intercom dial tone. Your extensions are numbered 10 to whatever. By default, dialing zero will ring extension 10 and you can see what extension called in the display.
Carl
Oct 21, 2010 | Avaya 700340193 Corded Phone
If you want to "make an announcement" using speaker phone using intercom, how do you do it
When you intercom the extension, insert a STAR ("*") before the extension number.
EX:
Dial intercom 12, will ring 12.
Dial intercom*12, will page the phone and go straight to speakerphone.
IF the far end user has their "MIC/HFAI" button lit, they will need to do nothing, they can just talk.
IF not, they will need to lift the handset, OR, press the "MIC/HFAI" button, to be head.
Oct 05, 2010 | Lucent PARTNER18 Corded Phone
Hi: I have a Panasonic KX-T7420 phone. When one of the incoming lines is ringing and I pick up the handset, it picks up the intercom and not the incoming line. Is there a way to get the thing to answer...
There are 2 things that would prevent you from being able to answer a ringing phone by picking up the handset. Your phone has to be ringing, and you need to set preferred line ringing on incoming calls.
The second part is easy. Press PROGRAM 99 and dial 22 STORE on your phone. Now when a call rings on your phone you can pick it up. If you can't, then your phone is not ringing.
Ringing is set in system programming.
Carl
Aug 04, 2010 | Panasonic KX-T7420 Corded Phone
ANSWERING INTERCOM
I'm out in the field and not at my Partner system, but I think you can either program a button or dial 626 on the intercom.
To program a button, press FEAT 00, the button, Intercom 626 and when that phone rings, pick up your handset and press the button.
Carl
Apr 24, 2009 | Avaya Corded Phone avaparp18d
Ring tones on KX-T7433
Wow, this is your lucky day :-)
From each phone, press PROGRAM 99 and the INTERCOM or CO buttons TWICE, then dial 1-8 and STORE. (default is 2). You can now make each line and intercom different, or each phone (up to 8) different. After you finish with each phone, just pick up and drop the handset back into the cradle to end programming.
The feature is called Ringing Tone Selection.
Carl
Apr 02, 2009 | Panasonic KX-T7453 Corded Phone
Phone ringing after power failure
I believe you have to reset the intercom system, meaning you need to reassign one or all of the phone's intercom numbers. To assign intercom # ( found on page 10 of the manual which you can download online)
1 Do NOT lift handset
2 Press the following 3 buttons (in order) PROGRAM, STAR, and then POUND
3 Enter two digits (the number you want the phone to be)
4 Press the INTERCOM button and you will hear a tone - then youre all done.
Aug 03, 2008 | AT&T 954 Corded Phone
Lucent PARTNER18 Corded Phone Logo
116 people viewed this question
Top Lucent Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Computer Repairing
Computer Repairing
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
