Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Possible defrost problems
Only weeks after arrival the ball bearings on crisper broke. Drawers still worked so I worked around it. Then lettuce froze no matter where it was in the ff compartment. Then icemaker mold quit filling even though water supply was ok. Another work around by making cubes. Then started getting er ff. Called service and eventually discovered a retrofit of the air way was recommended. Worked ok for 3 days then ff compartment regularly measured 58 degrees. Finally forced replacement of fan motor, mother board, LED boards (2), ice maker, frost sensor, etc. This finally occured yesterday and it seems to be working, but I'm not holding my breath and am in a billing dispute from protection agreement people.
  • worthatri Feb 04, 2009
    They finally replaced pcb, lcd (2 boards) and they have helped but still not working consistently. Ice making still sporadic, but so far so good thanks for all the help.
    Problem Solver:
  • 11 Answers
THEM MAIN PCB AND FAN MOTORS . SHOULD FIX THIS BROPLEM . TGHEY UPGRADED THE RELAYS IN THE BOARD .WITCH SEEMS TO WORK . THERE MIGHT BE SERVICE FLASHES OUT THERE WITCH WOULD COVER THE COST
Posted on Feb 04, 2009
  • alberto06053 Feb 05, 2009
    sometime even thought the the evap motor turns on . there is a sensor built in that measures rpm .. if still haveing issues replaced evap motor
Soft fruits, lettuce, cucumber in fridge turn to mush but jars and bottles stay cold
Crisper drawers were made to be a 4 degree lower temp
try turning up 1 number
Jul 01, 2015 | Smeg FAB10RR Retro style Red 114 l...
Crisper drawers freezing
probably defrost problem.
Oct 14, 2013 | Refrigerators
Can I take the freezer door apart and wrap the water line with more insolation
No, you can't. The line goes into the mold of the machine with no access there.You have either an air leak in the dispenser area, around the ice shoot possibly, or the resevoir, which is located on the refrigerator side in the lower area behind the drawers is freezing, which is most likely the case. There are vents on the lower section for the crisper drawers. If you take out the drawers you'll find a roll of 1/4 " tubing which they call a resevoir that cools the water down. This is probably frozen,and you can insulate this, but I would raise the temperature in the fridge side or close the vents to the crisper area.
May 08, 2012 | Whirlpool ED2FHEXN Side by Side...
Water dispenser just stopped working. Ice dispenser still works and the refrigerator has a new filter
two possibilities
1) the water valve is defective it has one inlet from the house plumbing,two outlets, one for i/m one for water dispenser
2) the reservior that chills the water is frozen, it is located behind the lower crisper drawers in the ref. to see if its frozen remove crispers and shelves and tap on it , if hollow sounding it's not froze if solid sounding its froze. to thaw it turn off unit for at least a hour
Jul 21, 2011 | Kenmore Side by Side Refrigerator
Water accumulates under the crisper drawers
You have a restricted condesate drain . You need to disassemble the rear of the freezer, defrost and clean condensate drain. Freezer probably got too cold and froze the condensate in the pan. Which means turning the thermostat to a warmer setting or recalibrating the thermastat internally to a warmer setting or replace thermostat to prevent from happenning again
Apr 05, 2011 | GE Refrigerators
I have an ED2KHAXVS02 model and the ice maker works but no water out of the refrigerator. Any Ideals on how to fix the problem
Could be a bad water valve or the reservoir has froze. do you have things freezing in the crisper drawers?. If so try turning the temp down a little. The reservoir is behind the crispers.
Mar 21, 2011 | Whirlpool GS6NBEXR Side by Side...
The food in the refrigerator drawers (crisper and meat) are freezing and the waterline froze. What is causing this and is it worth repairing?
I have Ge GSS25XSQA SS side by side and the food in the refrigerator drawers (crisper and meat) are freezing. Also the ice dispenser is frozen closed. The water dispenser still works.
Want can I do to fix it. Would dirty coils have anything to do with this?
Terry
Nov 10, 2010 | GE GSS25SGPSS Side by Side Refrigerator
Freezing my lettuce in crisper , so how do i change the temperature so my vegetables don't freeze. i do not have a producy manual.
Magtag has dropped the ball on this one... The temp at the top and the bottom of the units are varied. Try turning your temp gauge down just a fraction until the lettuce doesn't freeze. I also suggest getting a temp gauge (cheap) and placing on your top shelf to monitor. Temp should be around 40 degrees.
Aug 22, 2009 | Maytag Refrigerators
Refrigerator crisper drawers are freezing veggies
Shut the air flow into the crispers if you can. If not, turn the refrigerator temperature warmer by just a few degrees. The air into the fridge from the freezer is channeled into the crispers.
Jul 01, 2009 | GE PFS22SISSS Stainless Steel French Door...
Refrigerator has water under the crisper drawers
There is most likely a plugged drain in the freezer section. The easist solution can be to empty the refrigerator and unplug it over night. If this is not possible then the back or bottom should be removed to allow access to the drain and a hair dryer can be used to make defrosting go faster. still takes a while, if there is access in the back of the unit that can be the cause of the plug.
Jun 19, 2009 | Refrigerators
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
70 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
