Hp 6210 Printer - Connected to pc, but need to change cartridge
Printer says - connect to pc/ install software to change printers?
Do I need to install something else?
Thanx
Nicky
  • 19,396 Answers
Yep, you need to download and install driver software from here first.
Select software and drivers
Start installation with rinter USB unplugged, the software will tell you when to plug in the printer.
Posted on Jan 13, 2009
My printer is a HP- 6210, Message: "remove and
Hello Cliff, welcome to FixYa.
Hard Reset the printer by doing the following:
  • Remove all the ink cartridges.
  • While the printer in ON, unplugged the power cable from the power source.
  • Disconnect the USB cable at the back of the printer (if your printer is connected through a USB cable)
  • Restart your computer.
  • Connect back the USB cable.
  • Plug the power cable to its power source.
  • Turn ON the printer if it does not turn ON automatically.
  • Install the ink cartridges.
  • If the printer prompts for an print head alignment, please do so.
If the problem persists, replace the ink cartridge. The cartridge might be defective since you already have tried to clean the contacts.
Keep me posted.
Jas
Sep 28, 2011 | HP Photosmart 2610 All-In-One InkJet...
Computer says hp 6210 is offline
Make sure your printer is on.
Then check your connection between your PC and your Printer. Make sure your connectors are not loose.
If nothing happens, try restarting your printer together with PC.
If its not able to detect check your connections with your printer by clicking Windows icon then "devices and printers".
Once there right click on printer icon and see if it is enabaled.
If your Printer connection is actually connected to another PC or in other words in a network. Make sure that the PC that the printer is connected to is on.
Good day.
Jun 19, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I hve been trying for hours to install HP OfficeJet 6210 printer w/o disk. Nothing works. Help!
Hi:
Try install the printer drivers first, do not connect the printer to the Pc until after the drivers or software is installed, when driver is finished then conntect the printer to the computer and you should get a new hardware message saying installing device, then it should device is ready.
Dec 23, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Can I connect my HP all in one device to my computer?
Yes you can connect HP Officejet 6210 All in One printer to your PC using USB Cable.
You need the Software to install.
Click on the Download link below to download the printer software/drivers If you don't have software disk.
Choose the operating system to download the software.
Download Drivers
Instructions :
Disconnect the USB cable before Installation of Software
Download the software and run the file to start installation
At a particular point, it will prompt you to connect the USB Cable to PC Port. ( Make sure the Printer is Powered On )
Continue to complete the installation.
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 16, 2010 | HP OfficeJet 6210 All-In-One InkJet...
I need to intall my printer hp to my new pc how can I install it?
Please make sure before installing the printer device should not be connected to the system
1. Put the driver cd into the system cd drive.
2. Auto run will start & prompt you to click the install drivers
3. Keep it clicking NEXT it the install the drivers
4. Please reboot the system & them connect the device..
Them you will be able to use your printer
Oct 15, 2010 | HP OfficeJet 6210 All-In-One InkJet...
My computer crashed, i have the hp 6210 printer, but do not havve the software disk, how can i install it?
  1. Click here to download the software from HP website.
  2. Select your operating system.
  3. Click on "Full Feature Software and Driver" to Download and install after the download completes
  4. Make sure that Printer is not connected to Computer while installing.
  5. Connect only when the software prompts
Regards,
Riztech
Apr 04, 2010 | HP OfficeJet 6210 All-In-One InkJet...
My HP Officejet 6210 All-in-One keeps rejecting my color cartriges. I am willing to just print in Black, but it blocks all print jobs. Any ideas on how to by-pass the color cartrige block?
uninstall the software by going into add/remove programs. Then look at the color cartridge and make sure its an original HP cartridge and not one of the 3rd party type of color cartridges. Try to use originals if you can so you don't run into the printer rejecting them.
With the operating system clean of the software go thru the steps in this guide to make sure everything is being installed properly:
http://h10032.www1.hp.com/ctg/Manual/c00238458.pdf
This will make sure that the cartridges are installed and that the software is being reinstalled so nothing is corrupted.
If the printer is still blocking print jobs or rejecting cartridges then you know that its either a printhead problem or a main board issue, either way you would have to get the printer replaced.
Jan 11, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Printer
follow this link download your driver its safe I did it 100 of time http://welcome.hp.com/country/us/en/support.html
Dec 07, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP 3940 Printer not connected
The "remanufactured" cartridges can cause the printer to stop working by making a electric failure in the printer circuits. Those cartridges should be avoided now that HP makes extremely cheap and fragile circuits, not like the cartridge burner's HP's 600, 700, 800.
Jan 17, 2008 | HP DeskJet 3940 InkJet Photo Printer
Install software for HP Officejet 6210
Your driver can be downloaded from this webpage: Driver Update. I hope this helped.
cheers
Brian
Oct 18, 2007 | HP OfficeJet 6210 All-In-One InkJet...
182 people viewed this question
jasbo
jasbo
