Question about Dell A920 InkJet Printer
I can't locate where I open the ;printer to change the cartridges
Can you show me?
  • Anonymous Jan 29, 2009
    how do I open the printer to get to the cartridge?
  •  C. Dante
    C. Dante May 11, 2010
    What exactly are you trying to do?
    What do you want to change?
  • 13 Answers
If you lift the front of the printer up, from just above where the paper comes out (but below the scanner lid), the whole top section of the printer comes up a few inches, hinges from the back. A blue plastic pillar on the right hand side then supports it so it won't fall down again.
If you do this with the printer switched on, the print head assembly will drive out to the centre, so you can lift the clips that hold the cartridges in.
To close the printer, lift from the front again to take the weight of it, gently push the blue support pillar backwards and the printer can be closed.
Posted on Jul 10, 2009
Tip
How to change toner in laserjet printers
First Turn the printer's power off. Some power button is located on the control panel on the top of the printer, on the right side. Open the printer's top cover by pressing the top cover lever, which is located on the bottom side of the top cover. Lift the cover all of the way open. Locate the toner cartridge. It will be right in the center of the printer and has a handle on the top of it. Grab the handle and pull the cartridge out. Hold the replacement cartridge at its side and gently rock it back and forth. This will help to distribute the toner equally throughout the cartridge.Remove the paper cover from the top of the cartridge.Insert the replacement cartridge into the printer and close the printer's top cover.
on Mar 31, 2010 | Office Equipment & Supplies
Cannot find opening to install new ink cartridges
Hi
Please open the lid which is located on top of the printer. Also see this picture of Lexmark X4650 Printer showing the open lid and cartridges. Just remove the cartridges and install new ones
After downloading the drivers save them and install them. Hope this helps...
Daniel
Dec 29, 2010 | Lexmark X4650 InkJet Printer
How to change the ink of an epson stylus sx215
press the index sheet button and the scan button at the same time, you then get setup menu. use" >" to select "change ink cartidge". the ink cartidge will move to the opening position. lift the grey plastic clip at the back, and it will open towards you. then they just pull out
Jan 07, 2010 | Epson Stylus Multifunction Inkjet Printer/...
The red light on left is blinking. What does that indicate? I have a deskjet 904C. There are three light The left one is blinking, the middle is okay and the right is the green one, that shows me the...
Hi:
If you open the door on the top of the printer, while it is powered on, the ink cartridges will move to a spot that shows you the status of your ink.. There are little cartoon pictures of the cartridges with smiles or frowns to tell you if you have an empty color or black cartridge.
Nov 04, 2009 | HP DeskJet 940c InkJet Printer
UNSURE HOW TO CHANGE BLACK TONER????
There is a button you can press to free the carousel, and turn it round to show the black cartridge, it is located to the left of the carousel opening just under a little picture showing how to get the toner cartridge out,
Jun 17, 2009 | Konica Minolta magicolor 2300DL Laser...
Trying to change black toner but can only get blue out, cant get to the black one
There is a button you can press to free the carousel, and turn it round to show the black cartridge, it is located to the left of the carousel opening just under a little picture showing how to get the toner cartridge out, any problems email me on derekkneeshaw@yahoo.co.uk I will send you a photo of where the button is
Delboy
May 06, 2009 | Konica Minolta magicolor 2300DL Laser...
How do I access the ink cartridge to change it?
Open the front of the printer, cartritge should locate on its own to a position directly in front of you,printer must be switched on.When carriage stops plase your finger on top of the cartridge and press down,firmly,and pull towards you.it is easy!
Good Luck.
Jan 02, 2009 | HP PhotoSmart C4180 All-in-One Color...
Dell A920 InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
