Question about LG LB8000ER Air Conditioner
Air conditioner is not blowing cold air
Okay, so it is slightly blowing cold air, the fan is working, it's not frozen, it just doesn't seem to kick in and cool down the way it normally does. Its like it is just blowing air, but with no force! I have cleaned it, but no go. There is no water collecting in the bottom either. So how bad is it????
    Scholar:
  • 125 Answers
Is the compressor running ? If it is not running, try to adjust the thermostat to lowest temperature. If the compressors does not run then th ethermostat is defective.
Posted on Jun 12, 2007
  • 883 Answers
It has very low amount of freon left. best economical decision is replace unit.
Bryant plus 90
try replacing the run capacitor
Sep 03, 2013 | Heating & Cooling
Air conditioner shudders, stops blowing cold, then resets every 5 mins
Cleaned the filter this AM and closed the door but now a red
light keeps flashing.
Jul 19, 2013 | Sharp Cv-p12lx 11500 Btu Portable Air...
Hi, I have an amana ap125hd portable air conditioner and for some reason is doesn't produce cold air anymore. Then fan blows and the compressor kicks in, but to no avail, no cold air. I took the unit...
replace it,most likely the freon leaked out,if the compressor is running and the fan is blowing but not getting cold most likely you have a leak in the sealed system.
Jul 09, 2011 | Kitchen Ranges
Air on heat pump not cool outside unit humming but not kicking on
This could be an inoperative condenser fan.System will kick off on high pressure without proper air flow.The hum indicates voltage is present. Providing the fan motor is not locked up and will spin,Check your run capacitor which helps boost the motor voltage initially and will get it turning.If the cap is good,you may be faced with motor replacement....good luck
Aug 19, 2009 | Carrier 38CKC042 Air Conditioner
The AC turns on but is not blowing cold air. The fan seems its on but no cold air. Please help.
Possibly the unit is frozen and low on freon. Turn the unit off and put the fan off of auto to on. It should defrost! After doing this, you will need to call a professional to check to unit and recharge it with freon. If it continues to happen, there may be a leak somewhere! Good luck!
Aug 03, 2009 | Carrier Heating & Cooling
Air Con Unit Not cooling the room
Alright, I'm obviously not there, but you could be low on refrigerant/Freon, and what is more likely, your AC is suffering from some sort of obstruction or debris, as noted in this handy diagnostic article that explains how it could cause your AC not to blow as cold air as you would like:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Does_Not_Cool.htm
Hope this helps.
Brad
P.S. As to the loss of your operating manual, try to see if you can get another one directly from the manufacturer by contacting it.
Jun 04, 2009 | DeLonghi Pinguino PAC-02 Air Conditioner
Air compressor does not kick in unless ambient temp is > 80
Do not operate low fan and maximum temperature as the coils will freeze up stopping air flow.
May 21, 2009 | Whirlpool Electronic Window Air...
Compressor not kicking on
What type of thermostat are you using? When was the last time it worked ? Do you just get fan on cool mode, or does fan only run on fan mode?
Aug 08, 2008 | Dometic Rooftop RV Air Conditioner
LG LB8000ER Air Conditioner Logo
1,988 people viewed this question
Top LG Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Steve F
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
