Question about Lucent PARTNER18 Corded Phone
Lucent Auto Attendant won't allow extension transfer to voice mai
We have a voice messaging system with day and nite schedules, during day the attendant message won't allow incoming caller to select specific extenition to be transfered to voice mail. States that is invalid extension. How do we fix this problem.
  • 2 more comments
  • hrsron Jan 13, 2009
    The systems says Welcome to Partner Mail VS
  • mkorusek Mar 20, 2009
    I sort of have the same problem except my calls are going to voicemail and then transfers back to the receptionist again. I verified that it says "direct extenstion transfer" on both. Can you help?
  • mkorusek May 11, 2010
    Our voicemail says Partner Mail VS
  • Anonymous May 11, 2010
    When you log into the voicemail, what does it say?
    Welcome to Partner messaging?
    Welcome to partner voice messaging?
    Welcome to merlin messaging?
    Welcom to Merlin mail?
OK, now you will need to log in and modify selector codes.
When you dial into vociemail, and it asks for the mailbox....
99#
1234#
It wont prompt you, but enter "9"
then is lists out the selections, with 3 being AA, so...
press 3 AA
press 1 for day
press 6 to modify menu
press the selector code (1) it probably says that its a selector code transfer or something.....
listen for the propmts and make it a "Direct extension transfer)
if you have the same problems with pressing extensions in the 20's, modify selector code 2 also.
When done entering selector codes, press star(*) pound(#)
then press pound(#), and that will save the selector codes
hang up...As long as selector codes 1 and 2 say "Direct extension transfer" you should be good.
Posted on Jan 14, 2009
Program "Do not disturb" on business phone
From the manual: You need to program a button with FEATURE 01.
Do Not Disturb is available only on system telephones.
Do Not Disturb requires a button with lights. When the Do Not Disturb feature is on, the light
is also on, indicating that the telephone will not ring.
¦ Use Do Not Disturb when you do not want the auto attendant or the voice messaging system
to transfer calls to you.
¦ Use Do Not Disturb if you are assigned to a Hunt Group and you leave your desk, so calls to
the Hunt Group will skip your extension and ring immediately at the next available extension
in the group.
¦ To avoid missing calls when Do Not Disturb is not needed, turn it off
Carl
Mar 16, 2010 | Lands Phones
Lucent Partner 18D - Caller ID not working
The caller id information is sent from your local telco provider after the first ring and might not be able to be extended to the individual sets, try backing off the ring to answer on your voice mail from 2 to 3 rings to see if the information is then passed on. The Voice Messaging System message is being sent from the system showing who transfered the call to you. You should also notice that the ring pattern when that message is displayed is a standard ring followed by a beep meaning a transfer is taking place.
Nov 20, 2009 | Lucent PARTNER18 Corded Phone
Change Auto Attendant message to Rollover Calls to Ext. 10 and 15
**use with care ** if it is a "Partner System" here you go. if unsure do not do this. it is simple but one wrong keypress will cause ... mmm problems. so just hang up if unsure. dial intercom 777 , then * to get main greeting, if ok then * again then enter extesion should be prompted. press 0 # then password , default is 12345678 #. if it is good dial 9 (administration) then 3 (auto attendant) then 1 , 1, 6, * , # then 1 to record and follow prompts.
Oct 10, 2009 | Lucent PARTNER18 Corded Phone
Guest mailboxes will not answer
Programming on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
Enter #301
The display will say Automatic VMS Cover Extension:
Enter in the extension number of the phone that has the guest mailbox
The display should say 1 Assigned, if not press 1
press feature "00" to logout
Oct 07, 2009 | Lucent PARTNER18 Corded Phone
Avaya Lucent Partner Auto Attendant
Nope. You are stuck with that. If you want you can change the button that they press, to say....9 or something...make that a selector code transfer and it wont say "receptionist" any more.
Let me know I can help change the button press....
Mar 13, 2009 | Avaya Lucent Partner 616 Phone
AT T 984
I was told by an AT&T rep that the auto attendant can forward calls to another 984 phone to leave messages for that person. Your original OGM (out going message) on the designated Auto Attendant phone should state greeting and the names and the extensions. The caller presses the buttons for the person they want to reach and their call is forwarded to that extension. That extension, if unattended, will have an OGM telling the calling who they have reached and to leave a message. This feature can only transfer calls to other 984 phones only.
Jan 06, 2009 | AT&T 984 Corded Phone (att00148)
Voice message, reprogramming extensions
How did you program the voicemail so a caller can not leave a voicemail to a particular extension? Line ownership? SO a call goes directly to a milbox?
How can you reprogram the voice message????? Which one, for a particular user or the main Auto attendant greeting????
You have to know the admin login to change a mailbox password.
For that, you need to know which voicemail system this is.
When you log in to check your mail, the lady says, "welcome to Partner......"
Please fill in the blanks.
Nov 18, 2008 | Avaya Lucent Partner 616 Phone
Change voicemail
You are talking the auto attendant that picks up when someone calls in to the system and no one answers?
Which model voicemail is it. It will TELL you when you dial in to check your voicemail, ...."Welcome to Partner messaging" or welcome to partner mail" or "welcome to Partner voice messaging"
Jun 20, 2008 | Avaya Lucent Partner 616 Phone
Merlin Legend (Lucent) phone--changing vm list of extension
I do not fully understand you message but it sounds like you want to get into administrator programming of your voice mail.
I don't deal with voice mail programming. My only suggestion is to try and determine exactly which voice mail model you have and find the "administrator" or "programming" manual for the voice mail.
All manuals are available free at www.avaya.com
Apr 25, 2008 | Lucent PARTNER18 Corded Phone
Lucent PARTNER18 Corded Phone Logo
278 people viewed this question
Top Lucent Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Computer Repairing
Computer Repairing
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
