Question about Canon PIXMA MP160 All-In-One InkJet Printer
Canon MP160 all in one
The paper has just decided to stop feeding now. It only pulls from the right corner side (looking at the printer) and then gets jammed. I have only printed 3 or 4 pages on this thing, so I can't believe it is jamming already. Do I need to clean something out? Or is this a return it for the warranty issue.
  • 12 more comments
  • dana molnar Jun 12, 2007
    I have done a thorough search and tried using a piece of cardstock from the otherside to see if there is anything there, I just don't see anything. I guess its back to the store!!
    Thanks!
  • Anonymous Nov 02, 2007
    My Canon MP 160 printer is printing but the print-out is slightly
    tilted to the left - i.e. the margin on the left side is slightly
    higher than the right side. I am getting frustrated, as I have bought
    the printer only few weeks ago and printed less than 15 pages!
  • SamLongo Nov 06, 2007
    I have the exact same problem. I have only used my printer a couple of times and now it seems to feed and jam on the right side. I literally got so frustrated I held the printer upside down and shook it around. I also reset the margins on the page. I can't believe it worked, but it did. Try it, see what happens.
  • K Dog 21 Nov 20, 2007
    Just wanted to chime in and say I have the same exact problem after only a few pages. Don't buy one of these things. I'll try the shaking method, then the BFH.
  • Anonymous Dec 09, 2007
    O wow- I just moved the paper to the left and put the margins at 1 inch all round, and it worked. It seems that if the right side is avoided, everything will be ok.
  • Anonymous Dec 13, 2007
    Same problem here. I can't even believe that I was able to print anything from it at all for the past three months, because now it just seems impossible that it can print anything if it only pulls paper in from the right hand corner. What happened?
    You would think that printer is symmetric and there would be a white roller on the left side as well as on the right, but that is not the case. I've observed the printer as it takes, or tries to take, paper, but the motion is too abrupt to make sense of what's going on. The part faces the paper flips up quickly and snatches the paper. But it's still not doing a good job. Is it to slippery?
  • dancequeen Feb 24, 2008
    i do too
    but i dont know how to adjust the margins
    do u mean make it smaller in word?
  • dman28 Apr 19, 2008
    Same thing as all the others paper jam on the right side no wonder london drugs was giving them away with the purchase of a laptop. the ink also collects every time it jams causing quite a mess. Anyways im going to try some of these remedies hopefully they work.
  • monee Apr 22, 2008
    i cant get my paper to feed and on the display screen it's flashing E and 3.
  • Anonymous Apr 23, 2008
    Same problem here, flashing E and paper only pulling from the right.
  • Anonymous Jan 07, 2009
    printer wont feed paper keep saying load paper press start button and caution light comes on
  • Cherrell_lee May 05, 2009
    My printer was acting the same way and I took it apart lol I stuck my ID through and out popped a sun flower seed lmao. So I ouls suggest running something through like cardboard or something hard of plastic like an ID card.
  • yahbadabadoo May 09, 2009
    hello all,
    i'm having the same problem.
    it seems that the paper feeder just rolls in the paper at the right side..
    how many rollers should the feeder have?
  • sojnol May 11, 2010
Ran my costco membership card through the left side and a wad of paper popped out. I was pissed until I jabbed the card through. Just take your credit card/plastic card and jab it through the slot til it pokes through the white rollers inside. Slide it from side to side and jab up and down til whatever the thing is pops out. Hope it helps! it saved me from failing a paper!
Posted on Feb 18, 2009
  • r187am Mar 21, 2011
    Thanks, used your idea and cleared up the problem immediately. Great idea
    Scholar:
  • 29 Answers
Don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Yesterday someone replied to my problem, i tried it this morning and its fixed 1st time.
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
Posted on Mar 02, 2008
    Your solution was great! I even used a Costco card. Out popped some little trinket I never saw before. I couldn't see it until I pushed the card through. Thanks to all
I had the same problem, and after reading the solutions from this website, I figured out what to do. I turned the printer upside down and saw that there was a AA battery stuck inside. It wasn't stuck in a visible area, so I didn't know at first, but after I removed the battery, the printer worked fine.
Posted on Jan 11, 2009
I had the same feed problem and based on the advise given here, I used a piece of card stock (thick paper like you use to make business cards). I sent something to print and pushed on the card stock until it finally pulled thru, clearing whatever it was that was blocking the paper on the rollers.
Printer works fine again!
Posted on Jan 10, 2009
I had the same problem. Paper only pulls from the right corner side. There was something stuck on the left side. I couldn't see it but it made sense. I ended up putting a card and rotating the mechanisism reverse and a plastic part came out. Thanks for helping.
Posted on Sep 15, 2008
Try putting a credit card through the top where the paper goes. Then see if you can push the credit card through to dislodge whatever paper/material is stuck. The credit card should come out where the paper normally comes out, along with whatever was stuck in your printer.
Posted on Nov 05, 2008
I had the same problem, so i was just toying with my printer and i saw a goldfish cracker sticking out of the paper feed, so i turned the printer upside down and picked it out. and presto it took paper in again! so try tilting your printer upside down and maybe something lodged in the paper feed will fall out
Posted on May 07, 2008
    Novelist:
    Champion:
  • 254 Answers
Before returning it, look for something, anything lodged in the paper path. A small piece of paper, staple, or something broken off from the printer itself. Otherwise, if you find nothing, return it.
Posted on Jun 12, 2007
Thank goodness everyone shared how they fixed it! The first thing I did was turn my printer upside down and out fell a tiny strap that broke off my camera case! Thanks for all the help!
Posted on May 18, 2010
    Problem Solver:
  • 25 Answers
Fiend your solution direct from Canon. Here is your solution...
http://www.canon.com/printer/prob676ijt65/solution
a1
Posted on May 21, 2009
Printer pulls paper in from one corner
this problem occurs only when one side of the paper spooler is jammed and stuck. the spooler pulls the paper causing the paper to rotate inside the printer and getting stuck.
take professional help in clearing the jam and freeing up the spooler.
Mar 15, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Printer won't feed paper
The unit does not power on.
(1) Check the power cord
connection.
(2) Check the connection between
the SPCNT board (JPSU1) and
power supply unit.
(3) Replace the power supply unit.
General
errors
Oct 09, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Paper jams on right side of printer
hi,
paper feed assembly allignment problem.
pls contact to any printer specialist for allignment.
Aug 18, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printer "grabs" only a corner of the paper, then cannot pull it completly into inside
Also check that the paper guide in the feed tray is tight up against the edge of the paper. If it is not, the paper can skew as it is picked up and then jam on the way in.
Jul 24, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error E3 when no paper jam
MP160 PIXMA paper feed jam E3 error. I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180. With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper. The usual c-clunk sound that indicated the feed roller has been engaged was not there. The screen warning said to remove jammed paper and the printer showed an E3 error.
The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front). The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads. Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points. Its not a quick fix.
When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier. The lever is actuated by the ink cartridge carrier when it moves to the right. If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer. Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
Jun 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My pixma mp 150 keeps feeding to the right only
its the common problem of dust getting blocked in the gears of the left side which pulls the paper.just get your printer serviced to avoid further damage.
Dec 07, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper does not feed - GRABS RIGHT SIDE
gears below the paper feeding tray are damaged or some dust particle have blocked the gears try to clean it by blowing the dust use normal greece (oily substance) between the gears so that they can move frequently to pull the paper, and if the gears are damaged you have to change the gears.
Aug 03, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper feed
Hello Dear,
Both the printer has something stucked in the ASF Auto Sheet Feeder Assmbly of the printer try removing it your problem will be solved but if it persists you need to take it to the Canon Care get the printer serviced.
Regards,
Joseph
+91 9352008418
May 28, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper Jams
most likely there is paper or something stuck in that corner
use a flash-light an carefully inspect the area
hope this helps
thanks for rating
Jan 09, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper will not feed properly/one side of paper not feeding in straight
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
542
Dec 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
1,744 people viewed this question
old marine
old marine
